Previous in Forum: Vacuum Breaker for an Open Tank Loop   Next in Forum: Rectangular Tank Design
India - Member - Rajasekar
Atmospheric Tank
02/20/2014 12:31 PM
Hi,
I have one query regarding the atmospheric vessel (horizontal cylindrical) design pressure to calculate the shell/dish end plate thickness by ASME Sec VIII Div 1.
The vessel internal design pressure will be considered as full of liquid if the client not specified any internal design pressure. And the vessel has opened to atmosphere (vent nozzle considered in all the vessels).
But, I received one comment from one of our client saying that the internal design pressure shall be consider in the calculation is 1bar + Full of liquid. Is it correct or please clarify me.
Re: Atmospheric Tank
02/20/2014 1:17 PM
The client is incorrect.
This isn't an ASME Sec VIII Div 1 pressure vessel, anyway.
02/20/2014 1:44 PM
1bar is vented tank....atmospheric pressure unmolested....
02/20/2014 2:01 PM
Do your clients know how you get answers to their technical questions?
And technical guidance to perform your job?
India - Member - Mechanical Engineer Engineering Fields - Petroleum Engineering - Mechanical Engineer
02/21/2014 2:31 AM
There are 2 things to be noted.
ASME SEC VIII Div 1 is for pressure vessel. You generally do not design atmospheric tanks using SEC VIII. The code for those (atmospheric tank) is API 650 for vertical cyclindrical tanks for Oil, AWWA D100 for Water and API 620 for Low Pressure tanks.
And yes for atmospheric tanks, there are instances where the design of tank shall be considering pressure of atmosphere + the maximum liquid level in tank. They shall also be checked for vacuum conditions.
Varun Passi
02/21/2014 8:54 AM
Good Answers: 137
02/21/2014 9:41 AM
1 bar gauge or 1 bar absolute?
Register to Reply 6 comments
Codemaster (1); lyn (2); SolarEagle (1); Tornado (1); varunpassi (1)
