Previous in Forum: Atmospheric Tank   Next in Forum: External Nozzle Load Calculation Based on ASME Sec.VIII
India - Member - Rajasekar
Rectangular Tank Design
02/20/2014 12:35 PM
Hi,
How to design the Rectangular Tank in negative pressure (Vacuum Pressure).
Thanks
Raj
Re: Rectangular Tank Design
02/20/2014 12:49 PM
Is this a test question, or did you lose your notes?
02/20/2014 1:31 PM
Get inside it and pretend there is internal pressure from the outside.
02/20/2014 2:00 PM
Baffle plate interior support structure....
02/20/2014 2:02 PM
Do your clients know how you get answers to their technical questions?
And technical guidance to perform your job?
02/20/2014 4:14 PM
Eh? I'ma delivera da pizza, dats all....
02/21/2014 5:37 AM
If there is a pressure difference between the inside and the outside other than that represented by the level of liquid inside it, then it isn't a tank; it's a pressure vessel and should be designed according to pressure vessel codes and not tank codes. Go figure.
Register to Reply 6 comments
lyn (2); PWSlack (1); SolarEagle (2); Tornado (1)
