Previous in Forum: ASME Section VIII Div. 1 - Reducing Head Thickness Due to Pressure on Convex   Next in Forum: Problem of Foam in Liquid Line
16 comments
Bubble Appears After Steel Cord Belt Splice
02/21/2014 10:04 PM
Hi there,
After a recent re-splice on our Steel cord belt, we observed a bubble appears. The belt dimensions are 1800mm width, ST2500.
Any idea if it's common to observe a bubble after the splice or how critical it can be??
Cheer
Re: Bubble appears after Steel cord belt splice
02/21/2014 10:13 PM
Well,
With so much information, I am overwhelmed.
It will take a long time to digest the copious amounts of information you provided on the details of the repair.
I'm being cynical because we don't read minds and we don't have x-ray vision.
02/22/2014 10:59 PM
Redfred - I would assume that the rubber would form the bubble because steel would need to be about 1500 degrees before a bubble could form in it, so I think we can safely assume that he is referring to a bubble in the rubber
02/23/2014 2:34 AM
X ray vision systems may be useful in locating the steel "cords"
02/21/2014 10:30 PM
I thought a steel cord was called a cable. For a bubble to form in steel you've got to get really hot.
02/21/2014 10:40 PM
It's much easier to get bubbles in the rubber overlay.
They're called voids. Air inclusions. A sign of poor processing.
AP#1 does not understand this. Anonymous posters are a strange lot. They are......................................................different.
02/21/2014 11:11 PM
Just thought that I'd have some fun obfuscating the microscopic information we did get.
02/21/2014 11:12 PM
Have you met sam12 ?
02/21/2014 11:16 PM
Wow man, it's like Deja Voodoo all over again.
Reply Off Topic (Score 4)
02/22/2014 10:31 AM
You'd better copyright that phrase, or else I'm gonna steal it!
02/22/2014 3:33 AM
Yer doin' it wrong....
Re: Bubble Appears After Steel Cord Belt Splice
02/23/2014 2:17 AM
Is it a bubble, or a "wave" that does not lie flat near or at the splice?
02/23/2014 2:35 AM
If it is a wave,the problem is that the belt splice was not cut squarely on both ends,or
not parallel when cut or spliced. This will result in one end of the splice being
longer than the other, causing a wave to form on the longer of the two cuts.The longer
cut is being forced into a shorter space.Both cuts should be exactly the same length
across the width,whether diagonal or straight.If not adjust the angle accordingly.
An effective method is to make one cut, then overlap it onto the belt at the next cut,
and trace the first cut onto the belt.Make the second cut on this line, and variations
will be eliminated or minimized.Place both cut ends together before splicing and
examine for irregularities, and correct if necessary.
A diagonal cut is preferred to a straight cut because it gives a smoother transition over the rollers, and a longer splice line is stronger.
Good luck.
02/23/2014 8:09 AM
It will also depend on why the splice was used on this belt in the first place. If this splice is there to repair a belt failure then the steel weave maybe compromised near but not at the site of the tear. I believe the steel cords can snap much like why dried spaghetti breaks at multiple places when fractured.
Once again we know virtually nothing about this problem. The most obvious, critical mysteries to me are why a splice is being used in the first place, how new is this belt and what is the job of this belt?
Good Answers: 123
02/23/2014 2:21 PM
I also had a bubble at the belt splice of my tire on my go cart. I just filled the tire with concrete, and then groung the bubble off. Good as new.
Bob
02/24/2014 6:29 AM
There's no bubble in the CR4 pet crystal ball. Sadly, it's at the mender's at the moment.
What did the belt's original manufacturer say during the tellephone call?
02/24/2014 1:26 PM
MikeMack747
Reply to Forum Thread 16 comments
bob c (1); HiTekRedNek (2); lyn (3); MikeMack747 (1); Peter Boutelje (2); PWSlack (1); redfred (4); SolarEagle (1); Tornado (1)
