Previous in Forum: Control Boards for Electrical Energy   Next in Forum: Just Out of Curiosity
12 comments
High Current Passes Through Neutral
02/26/2014 2:55 PM
hello every one,
yesterday and today i faced such a big problem in power station
we just receive a generator after rewinding
when i load it on load bank generator operated normally up to 500 kw .
once we connect it to power station we notice that high current passes through neutral causing grounf fault trip to generator
you kindly should know that all neutral are connected together and earthrd directly.
i chech the internet found that the pitch factor may be the cause but i couldn't get the pitch factor for old generator from the vendor to compare it with new rewinded generator.
so
i need help to know the actual reason of the problem and how i get pitch factor and how to treat this problem.
Thanks
Adel
Re: high current passes through neutral
02/26/2014 3:10 PM
Treat it as any professional would.
Call in a competent electrical engineer to trouble shoot and fix your problem.
02/27/2014 12:18 PM
not you...thanks for commenting...not
common knowledge...less common than common sense
02/26/2014 3:10 PM
What were the readings from the insulation test that was carried out before its being bought into use?
02/26/2014 3:19 PM
is the generator wye connected? Voltage? Actual phase current readings? When you say current was high, it does not give any information. Do you have loads connected phase to neutral?
02/26/2014 3:20 PM
Did the rewinder make a mistake when rewinding the generator? (Perhaps).
What does the power station's Chief Engineer have to say on the matter?
02/26/2014 5:48 PM
He is the station's Chief Engineer
02/26/2014 3:21 PM
Some dimensioned numbers would be a good starting point.
Re: High Current Passes Through Neutral
02/27/2014 7:06 AM
Well, Thanx all for ur concern.
firstly when we start troubleshooting this problem we do megger test to check generator, then we test it on dummy load bank (resistive load without neutral ).
when the generator tripped when put it in parallel with other generators we raise the setting of ground fault to complete testing.
we confirm that there isn't neutral current on other generators before loading the rewound generator.
neutral current before loaded generator are (19,7,25)
We confirm that no big single phase load causing neutral current.
So now we load generator found high current in generator ((180A))
and high current through other generators neutral (45,95,50)A
So please kindly advise us to know what root cause of the problem and how could it be serius problem and how we can solve it
Please also check this link
http://www.mirusinternational.com/downloads/EGSA-PL-SO11-Mirus-Article-b.pdf
Any advise will be appreciatted
Thanx
Adel
02/27/2014 12:34 PM
This may be an issue with the terminations within the newly wound motor.
What values did you get when you megger'd each winding? At what point were the measurements taken, at the output terminal or at each winding termination in the case?
But...
I would compare the LCR stator winding measurements. This will give you an idea of the pitch relationship of the windings. Turn the motor over one complete revolution and measure the LCR values at equal points over the 360 degrees. Do this for each phase relationship. Plot your results through a simple Excel run chart and look for inconsistencies in the phase to phase relationships.
Research locked-rotor impedance.
India - Member - New Member Engineering Fields - Electrical Engineering - New Member Technical Fields - Technical Writing - New Member
02/27/2014 11:11 PM
dooola2020,
very good article, which you have linked, it also suggestes the probable cause of the problem and the solution to get rid of the Problem..
Thank you for sharing this Article..
Secondly we do not connect the neutrals of the Generators in Parallet Operation, rather we connect the Neutral of Biggest (Capacity) generator to Earth and the neutrals of all others will be kepy floating..
Regards..
02/27/2014 11:40 PM
Well, that's a unique way of doing it. Kinda makes synchronization difficult, though, eh?
02/28/2014 6:48 AM
Once more than one source is connected to the load, only one of their neutrals needs to be connected, otherwise high neutral currents will ensue.
If in doubt, consult a qualified Electrical Engineer locally.
Register to Reply 12 comments
Anonymous Poster (1); dooola2020 (1); jack of all trades (1); lyn (1); PWSlack (3); The.Tinkerer (3); vishram lele (1); wareagle (1)
