Previous in Forum: Conveyor Pre-Start Alarm   Next in Forum: Ungrounded Phase Voltage
Electricity Question
03/03/2014 2:58 AM
hi
can some one tell how many amp is 1 kw in 240 volt power factor 0.8
Re: electricity
03/03/2014 5:40 AM
Single-phase or three-phase?
India - Member - New Member Engineering Fields - Electrical Engineering - New Member Technical Fields - Technical Writing - New Member
Re: electricity
03/03/2014 6:19 AM
Simple Electrical Formula..
kW = SQRT (m) V I Cos (Phi)
m = no of Phases
V = Voltage
I = Current
Cos (Phi) = Power Factor
Re: electricity
03/03/2014 6:23 AM
Corrected for Multiplication by 1000 for converting from Kw
kW = SQRT (m) V I Cos (Phi) 1000
m = no of Phases
V = Voltage
I = Current
Re: Electricity Question
03/03/2014 4:53 PM
Loads of people can.
03/03/2014 7:11 PM
From CR4 FAQ's which you should have read before posting:
  • Do your own homework. CR4 is not a homework cheat site. While some here might relish the opportunity to sharpen up old rusty skills by working the homework problem, consider the following and consider it well. If you cheat on your homework by using someone else's answers, you are only cheating yourself, because the purpose of any homework or other academic assignments is to help you learn - by practice, repetition, and self-discovery.
Good Answers: 804
03/04/2014 6:46 PM
Unless you are in school fora degree in management, in which case the purpose of the homework exercise is to get some other fool to do your work for you...
03/04/2014 7:09 PM
Not much hope for OP in either case, I fear.
Register to Reply 7 comments
JRaef (1); lyn (2); PWSlack (1); Tornado (1); vishram lele (2)
