Previous in Forum: Thermo-Eletric Shutter Alone   Next in Forum: Stranded vs. Solid
Want to Prepare Piping Tolerance Sheet
03/10/2014 1:54 PM
Hi Every Body
I want to prepare piping tolerance sheet. Please give me guide line which data will be needed from power piping ASME B31.1 etc
Re: Want to prepare Piping Tolerance Sheet
03/10/2014 2:00 PM
Ahhh,..... what is your responsibility where you work?
03/10/2014 2:15 PM
dear phoenix911.......I am working in descon engineering Ltd as a piping design engineer....
03/10/2014 2:26 PM
First off, I like to welcome you here to CR4.
Unfortunately, you may have started off on the wrong foot,..... figuratively speaking....
The point that you will hear, as you being a piping design engineer........ and how you phrased your question.
It is the responsibility of a piping design engineer to do this work. The members here are more than willing to help, but they do draw a line when no effort is put out for a request that is clearly the responsibility of the requester....
Do you understand?
But we are a forgiving bunch............
I suggest you at least do some preliminary research and then bring it up for opinions....... because we have a lot of that. you'll get more information that way.
Good Answers: 59
Re: Want to Prepare Piping Tolerance Sheet
03/10/2014 2:51 PM
If you're looking for ASME B31.1, you can purchase it here.
03/10/2014 4:02 PM
Am assuming that you mean dimensional tolerances?
Dimesions of steel tubes and pipes
Good Answers: 104
03/10/2014 7:30 PM
If you are talking about wall thickness tolerance, that is referenced in the material standard. If you are talking about fabrication tolerances, I think your study of B31.1 (and 31.3) will show that specific tolerances are not given. The Piping Fabrication Institute has issued ES-3 "Fabricating Tolerances".
03/17/2014 3:37 AM
What kind of tolerance sheet are you referring to? Fabrication tolerance? Design tolerance? Dimensional tolerance?
Having worked in piping fabrication, I can refer PFI standard PFI-ES3 where tolerances are given.
There are dimensional tolerances for piping components, they will be given in respective dimensional standards (Pipe B36.10, Flange B16.5, etc.)
"Design tolerance", I guess you have to guide me you are a Piping Design Engineer
Hope that helps
Register to Reply 7 comments
bigg (1); hayaz9380 (1); lyn (1); phoenix911 (2); SavvyExacta (1); shaff (1)
