Previous in Forum: Do We Expect Hub Movement on Key Connection   Next in Forum: Want to Prepare Piping Tolerance Sheet
Thermo-Eletric Shutter Alone
03/10/2014 3:12 AM
Somebody seen a thermo-eletric shutter like ones on exhaust fans, but made alone - without a fan ?
Re: Thermo-eletric shutter alone
03/10/2014 4:21 AM
Yes, they are made. Some other possible terms might be "motorized dampers" or "motorized louvers". The corrected spelling "thermo-electric" might also help.
Re: Thermo-Eletric Shutter Alone
03/11/2014 5:57 AM
They are used in glasshouses here to adjust the ventilation by temperature. Some do not need any electricity, I believe they work by warmth expanding and contracting some part of the mechanism. Is that what you need?
Search under "automatic greenhouse vents".
I found this:-
http://www.baylissautovents.co.uk/
Best of luck.
03/11/2014 6:33 AM
Did not know there are such - self-controlled by ambient temperature - thank you. Only I don't know why there are not simple ones for air ducts - ones like I described above.
Register to Reply 3 comments
Andy Germany (1); Tornado (1); Yuri B. (1)
