Previous in Forum: Switched High Voltage Current Source and Sink   Next in Forum: Expansion Joint In Mat Foundation
12 comments
Pressure Calcualtion on Side Walls of Fishtank
03/21/2014 12:20 AM
Hi ,
I want to know ,how to calculate Pressure acting on side walls of a tank...Example my tank size is 1X1X1Mts dimension and filled with water completly.I need to know how much pressure is acting on each side walls and the bottom floor of the tank.
can any one share me the formula and document if available....
Thanks in advance.
Re: Pressure calcualtion on Side walls of Fishtank
03/21/2014 12:31 AM
One metric tonne per square meter on the bottom; zero at the top; linear interpolation between.
Good Answers: 109
03/21/2014 1:11 AM
What if there is fish I there?
03/21/2014 1:18 AM
Usually their specific gravity is close enough to 1 to consider them as just water.
All bets are off if they are frozen and just chucked into a dry container.
Good Answers: 109
03/21/2014 2:05 AM
03/21/2014 2:20 AM
I'll be doing just that this weekend--my plant freezes about 300 tons of herring per day for about 15 days in a year. Hectic while it lasts.
03/21/2014 12:50 AM
One gallon weighs 8.4 pounds. One cubic foot weighs 62.4 pounds.
You can take it from there, right?
Oh, atmospheric pressure is 14.7 PSI.
03/21/2014 8:08 AM
the 14.7 is at sea level, what if he lives in Denver???
03/21/2014 10:47 AM
His fish will die.
03/21/2014 4:02 AM
03/21/2014 7:34 AM
Pressure is a function of depth. Force on the walls is the integral of pressure with respect to depth from the bottom of the liquid to its surface.
There are simple solutions for simple geometries.
Re: Pressure Calcualtion on Side Walls of Fishtank
03/21/2014 3:25 PM
Anybody that's asking this question must be making a case for thin walled fish tanks. While I don't like the weight of the glass I always wish it were twice as thick.
03/21/2014 3:28 PM
you just need this
Register to Reply 12 comments
Fredski (2); IdeaSmith (2); JE in Chicago (1); lyn (2); PWSlack (1); SolarEagle (1); Tornado (3)
