Previous in Forum: How Do I Design And Calculate The Stress Of My C-Channel   Next in Forum: Impeller Balancing
Risks Of Canned Motor Pumps With Molten Sulfur
03/27/2014 1:44 AM
Dear friends,
Our Client wants to change the existing Centrifugal pumps for molten sulfur service into canned motor pumps. The present Centrifugal pumps have a lot of problem with Mechanical seal.
If canned motor pumps is used for molten sulfur service , what all problems may be occured in future. My major concern is molten sulfur in motor.
Please provide your valuable suggestions.
Re: Risks of canned motor pumps with molten sulfur
03/27/2014 2:09 AM
You need to learn how to use the internet effectively!
http://www.mt-online.com/septemberoctober2008/understanding-canned-motor-pumps
Comes up and more.
Re: Risks Of Canned Motor Pumps With Molten Sulfur
03/27/2014 9:46 AM
I suggest that you find a new line of work.
If someone is paying you to select a pump and you have to go on-line and ask total strangers on an anonymous forum what to do you are cheating the poor client.
You should be ashamed of yourself and get a menial job with no responsibilities.
03/30/2014 12:13 AM
Why are you here. The purpose of this forum itself is to share the knowledge. If you cannot contribute anything, even to give a right internet link, I suggest you better start a vegetable shop
03/27/2014 1:57 PM
I believe that this is theoretically possible but the added operational control requirements will be much more complicated. Canned motor pumps are intended for material that is liquid at room temperature. Sulfur will get inside a canned motor pump. Sulfur melts at about 115°C. To prevent quick degradation of the bearings you may need a temperature interlock on the motor that turns the motor OFF if the sulfur soaked bearings get bellow 120°C. The stator motor windings must now have some very high temperture insulation because the winding resistance will just be adding more heat to these motors.
03/27/2014 7:59 PM
What telephone discussions have taken place so far with canned motor-pump suppliers, please?
Good Answers: 32
04/02/2014 11:35 AM
I don't see the practicality of a "canned motor pump" where the molten sulfur comes in contact with the windings. Depending on the pumping requirements I would think that a "sealless" pump would be a better bet See: http://www.springerpumps.com/blog/pump-sulphur-with-sealless-pumps-by-cp-pumpen/ where the use of a magnetic coupling eliminates the need for a coupling. Since no operating conditions were given it's hard to get too far in depth as far as a recommendation of other than a general nature. I do remember that it was a dog of a service back in the 60's-70's when I was doing refineries and chem plants.
Spinco
Register to Reply 6 comments
IdeaSmith (1); lyn (1); mratheesh05 (1); PWSlack (1); redfred (1); Spinco (1)
