Previous in Forum: Use of Mechanical Engineer in Industry   Next in Forum: Structure Design For Spherical LPG Tank
8 comments
How Do You Find the Max Allowable Stress in Tension of a Material
04/03/2014 9:13 AM
I am looking to find the max allowable stress of a material called X5CrNi18-10, however I am just wondering how you would find the max allowable stress of any material in tension ? any help is appreciated.
Re: How Do You Find the Max Allowable Stress in Tension of a Material
04/03/2014 9:22 AM
by testing it to verify your calculations
04/03/2014 9:52 AM
OMG! I pity us all, if you are an example of the future generations.
A search engine produced "About 13,500 results (0.27 seconds".
Read a book. Use a search engine. Ask the instructor. Ask a fellow student.
From the FAQ's, which you didn't bother to read: Look for answers before you post. Search CR4 or use a search engine to see if you can find the answer to your question.
Do your own homework. CR4 is not a homework cheat site; however, if you have questions about understanding concepts or how a portion of a problem is derived, these types of questions will be accepted.
04/03/2014 10:11 AM
Maybe this is how kids do homework these days.....just ask someone for the answer.
J B
04/03/2014 10:49 AM
It is a real shame that these kids such as undergrad_mech are so lost that they don't even know what they are doing.
"of a material called X5CrNi18-10" leads one to believe that this lost soul doesn't even know what they are working with.
Undergrad mech indeed.
Youth is wasted on the young!
04/03/2014 4:43 PM
Stretch it until it breaks. Divide the maximum stress by 4 (or other code-mandated factor).
04/03/2014 6:35 PM
Easy. Put a test specimen in the post to Fredski, as in #1 above, so as to make use of that piece of equipment.
04/04/2014 2:15 AM
X5CrNi18-10 nearest UNS specification material is S30400. Maximum allowable stressis 138 MPa at temperature between -30 degree C to 40 degree C. As the temperature increases, the allowable stress decreases. So you have to specify a temperature to get correct value. The above data is in accordance with ASME Section IIP-D Table 5A.
04/07/2014 11:20 PM
You're question is ambiguous. Are you asking how to physically determine what the max stresses are or are you asking where you can find these value as in a document of some sort?
Register to Reply 8 comments
Fredski (1); IRSHAD (1); JBTardis (1); lyn (2); PWSlack (1); TerraMan (1); Tornado (1)
