Previous in Forum: Calculation of CFM of a Blower   Next in Forum: How Do You Find the Max Allowable Stress in Tension of a Material
14 comments
Use of Mechanical Engineer in Industry
04/03/2014 5:39 AM
Why mechanicle enginner use in cement industry?
Re: Use of mechanicle enginner in industry
04/03/2014 5:45 AM
Why not?
Why not use spell checker?
04/03/2014 7:09 AM
Cut them some slack. It is their first post. Did you know what all of the buttons of our editor do the first time you posted?
04/03/2014 8:42 AM
I called Slacky, but he has not shown up yet!
Sometimes I just have the feeling people think of just "A" question to get into the forum, regardless what question it is.
Usually the browser comes with a spell checker nowadays. So one has only to watch the underlined words and correct them.
And the answer is no, I did not know what the buttons all were.
04/03/2014 5:57 AM
Good grief....
04/03/2014 5:58 AM
To look after the mechanical bits?
Good Answers: 18
04/03/2014 6:02 AM
Hi Prajyot,
It takes machines to manufacture things and engineers (of all persuasions) to keep them going.
John
Best advice I can give as you get older "Never miss an opportunity to relieve yourself"
04/03/2014 7:14 AM
To design and maintain the machines that make up the cement industry there is plenty of mechanical engineering work to do. To operate these machines does not require a mechanical engineer.
04/03/2014 8:19 AM
Because it's needed for a number of reasons.
In the finish product it's self you need a good foundation, .... no pun intended...... from equipment to make the forms, mix the concrete or even the pour.
A structural engineer is needed here, as well as a materials engineer.
My girlfriend's son-in-law is a structural engineer, and they are using a Styrofoam foam type product in the concrete, he had to observe while it was being constructed. Lighter weight, with a little loss in strength.
Also, you need engineers as well as scientists to teach the next generations of structural engineers.
Owen Withey, a professor of mechanics at the University of Wisconsin-Madison, back in 1910 had the foresight to do a study on concrete, I believe it started out as a 50 years study, but due to the amount of cement samples he made, it was extended to a 100 hundred year study.
Here is some info. It's an interesting read.
By the way Prajyot, Welcome to CR4.
04/03/2014 8:44 AM
they're thick headed
04/03/2014 1:49 PM
- - - In order to test the concrete ?
Stress relief ? Bang head here.
Good Answers: 181
Re: Use of Mechanical Engineer in Industry
04/03/2014 4:34 PM
They have their uses, but after 24 years in cement manufacture I gave up trying to find out what.
United States - Member - Go Tigers! Engineering Fields - Mechanical Engineering - Specialty - Mechanical Vibrations Fans of Old Computers - UNIVAC - Man I shoulda bought a Whirlwind!
04/06/2014 11:12 PM
Probably because someone needs to remind people that Sn=F/a and Sb=MC/I and that's just the normal stuf :)
"Your theory is crazy, but it's not crazy enough to be true." - Niels Bohr
04/07/2014 1:37 AM
Every manufacturing plant is made up of main processing machines and supporting utilities.
Just like a doctor is required for looking after the well being of humans in every village, a Mechanical Engineer is required for looking after the Machines and Utilities of every manufacturing plant. Call them "Plant Engineers", "Utility Engineers", "Maintenance Engineers" or just "Mechanical Engineers"
India - Member - New Member Engineering Fields - Mechanical Engineering - New Member Engineering Fields - Piping Design Engineering - New Member
04/09/2014 2:40 AM
Hi,
i am Mechanical engineer working for construction firm. i had the same question before joining, but now can't even think why i am here. there is a work for mechanical engineer in every industry..Believe me, you'll be loaded with your mechanical stuffs..
--ntr
(engineering)...is the art of doing that well with one dollar that any bungler can do with two..
Register to Reply 14 comments
fattmaxx (1); Fredski (1); IdeaSmith (2); jesw55 (1); LongintheTooth (1); ntr (1); phoenix911 (1); redfred (2); shaff (1); TonyS (1); Tornado (1); user-deleted-1105 (1)
