Previous in Forum: Emulsion Not Performing   Next in Forum: Saturn's Little Moon Enceladus.
46 comments
Good Answers: 145
What's on My Coffee Cup?
04/03/2014 2:50 PM
What's on my coffee cup?
Around 1989 I got something on my coffee cup and it is very permanent. I wish I knew what it was because the durability of it is very impressive. If anyone has any ideas I would love to hear them. This has bugged me for years. First, I'll include a photo of the marks on the cup. Then I'll provide a few details.
The coffee cup is a glazed ceramic cup. Once upon a time many truck stops had racks of them with various first names for $1.99 each. There is nothing special about the cup except for this very unusual mark. The mark has been on the cup for 25 years and hundreds of washings. When you rub your finger over it there is no indication of there being anything on the ceramic glaze. The ceramic is not scratched, damaged, abraded or in any way altered. The marks seem to be the same size, shape and darkness that they were 25 years ago. I would love to have in my bag-of-tricks the ability to do this but I don't recall what the material was.
I recall the marks being made but I do not recall the material. It was either after a re-org or a layoff. I piled a lot of things in the back seat of my car. The coffee cup was in a box on the floor behind the driver's seat. I had some sort of a plastic or rubber sheet or plate to the side of the cup and more things stacked on top of them. As I shifted weight in the drivers seat or hit bumps in the road the back of the driver's seat would press on whatever the sheet or plate was and cause rubbing on the coffee cup. The total pressure was probably somewhere between several ounces and a pound or two. If it was the re-org then it was winter (Florida, 70F +/- 10F) and if it was the layoff then it was summer (Florida, 90F +/- 15F).
At the time I did many electrical and mechanical things. It could have been a structural foam enclosure or card cage, it could have been rubber or plastic sheets or plates. I recall it happening, at the time I knew exactly what it was, but at the time the marks were just something I would need to clean off and therefore it didn't go into long term storage in my brain. The coffee cup stayed stored in a box for a year or two and the next time I saw it I had forgotten what the material was.
The flatness of the top of the marks was caused by the range of driver's seat generated motion being somewhat fixed. The width and uneven bottom of the marks was caused by the coffee cup rotating on a somewhat uneven pile of stuff in the cardboard box. Something light was resting on the cup's handle and as the pressure on the cup cycled the cup would rotate a little.
I have not attempted to remove the mark with chemicals. So far I have been more interested in being able to make the mark again than remove it.
Basically, I don't know of anything other than epoxy paint that would create a mark as permanent as this. And, since this mark was applied with a rubbing action the material could have been obtained in small diameter rods and used like a pencil or crayon on ceramic (and probably glass, stainless, etc.)
Any ideas what material could easily make a permanent mark like this?
Thanks,
Bruce
Re: What's on my coffee cup?
04/03/2014 3:45 PM
My guess is that it is a metal.
Have you tried erasing it with a pencil eraser?
Good Answers: 145
04/03/2014 5:11 PM
I'll give it a try.
Re: What's on My Coffee Cup?
04/03/2014 3:56 PM
My WAG is that this mark is actually in the ceramic and has always been there since firing. This is a defect in the clay. Now there use to be a white, high gloss paint that covered this defect and you did not notice the camoflage work when you bought it. These marks appeared once the paint was removed.
Good Answers: 145
04/03/2014 5:14 PM
It's been 25 years but I have a clear memory of being confident that there was a transfer of material. I'll try to use whatever chemical I might have to remove some of it. If I remove some and have a clean, shiny white area where cleaned then a transfer would seem to be confirmed. If dark then rubbing off white would be a strong possibility.
04/03/2014 3:59 PM
You've surely heard tales of people finding images on a piece of toast, etc etc. e-bay the thing and you could get a hundred more to experiment with .
What stuff/methods have you tried ?
Good Answers: 145
04/03/2014 5:22 PM
I wish it was an interesting image. It is much harder to explain why I am interested in something that doesn't look like a religious symbol, hot babe or cute little bunny.
I haven't tried removal or reapply. Over the years the school of hard knocks has trained me that nothing that goes on like a pencil will stick like this on such a smooth surface. I shouldn't care about it since I'm not in an industry and don't have a hobby where I really need the answer. Whenever I have to use a Sharpie to make a less than permanent mark on something smooth I kick myself for not being able to remember what made this mark.
04/03/2014 4:13 PM
If the cup was in contact with a newspaper ( wrapped in it ) ant the temperature was elevated ( as on the dash of a vehicle ) the ink from the paper could fuse into the glaze. It then becomes a permanent addition. The ink is more mobile than the paper fibers, so the ink would transfer before the Glaze would stick to the paper itself.
Good Answers: 145
04/03/2014 5:23 PM
Good idea but I don't know if the floor of the back seat would get hot enough.
04/03/2014 4:49 PM
It looks like an epoxy paint that has been rubbed into the surface with some force....
04/03/2014 5:15 PM
...of course plastic can be hard to remove....it might have been rubbing on some hard plastic....
Good Answers: 145
04/03/2014 5:30 PM
My memory is that it was a solid sheet or plate but it could have been epoxy painted.
The marks seem to chatter a little rather than being continuous and smooth. If the seat was pressing against the material and the movement was a series of bind and slip motions then I guess the pressure at the point of contact could be pretty high.
This might be about as close as I am going to get.
04/03/2014 6:33 PM
The marks may be metal or perhaps a very small particulate like printer ink.
Ceramic glazes can be marked by metal when one of two common flaws occur with the glaze.
The glaze might be porous (even though it appears shiny and smooth) but sufficiently hard. This allows what are known as cutlery marks. The metal from cutlery (or other metal in contact) is being worn off and imbedded in the porous material.
Alternately glazes that are not fired to high enough temp or have bad composition can be soft.....though I doubt this is the problem with your particular piece.
You should try to examine the marks under high magnification. I think porosity on a very small scale is likely to be involved.
Good Answers: 145
04/04/2014 8:16 AM
"Porous but shiny and smooth" seems to fit. It seems a little odd since it looks smooth but if this is a common defect then all the other pieces of the puzzle seem to fit.
Ethyl alcohol doe not have any effect on the marks.
Acetone does not have any effect on the marks.
I spent about 3 minutes with a razor knife trying to scrape some of the mark off. To my unaided eye I removed nothing. I also didn't seem to add any marks or deposits to the glaze.
I don't have access to a microscope now. I might have one available to me in a week or two.
Microscopic pores seems odd to someone like me that knows nothing about ceramics but warm (hot car in Florida) plastic (or epoxy or other coating) rammed into microscopic pores in the glaze does seem to be a 100% good fit to everything I have observed. It would also explain why this same material isn't available (won't work) as a common marker for ceramic, glass and metal.
Thanks for the suggestion. Now if I just knew which storage box holds my microscope ....
04/04/2014 12:12 PM
You might try adding some marks with metal softer than what is used for razors. Razors are typically very hard. A fork from silverware should be a decent test; see it you can notice faint marks when you rub it with some force in the general area of the marks. The marks may be much lighter and probably a slightly different color, but should be pretty hard to remove.
Look closely. If you can't make marks with something like a typical fork, it doesn't bode well for the porous glaze explanation. If you can then I think you are right that it is just a matter of what happened to be ramming against it in the car ride.
Good Answers: 918
04/03/2014 8:35 PM
Take a little Barkeeper's Friend on a damp sponge and I bet it comes right off.
Good Answers: 145
04/04/2014 8:23 AM
Thanks but having the mark on the cup doesn't bother me. Not knowing how to make marks this permanent is what bothers me. A Sharpie or paint would have come off years ago. This won't rub off, wear off, scrape off or fade. It is resistant to chemicals. As near as I can tell it is a sample of the material "unobtainium" that management typically expects to be incorporated into their new design.
Mmm, maybe KrisDel(R) or LynDoor(R) would like to buy it, reverse engineer it and sell bulk unobtainium on their web stores.
04/03/2014 8:43 PM
just looks like a positive lead test, I wouldn't worry
Good Answers: 145
04/04/2014 8:25 AM
It does look like that. I think I'm OK since every night at 10 PM the classic rock station gets the lead out.
04/03/2014 11:06 PM
I've seen that happen to cups that are stored such that they rub together. Might be the glazes rubbed together and formed the mark. Just a guess.
Good Answers: 145
04/04/2014 8:32 AM
That is close but it was the only ceramic item in the box. I remember when it happened but since it was on office clean out day I had more important things on my mind than a coffee cup. The cup went into a storage box and I do remember the back of the seat pushing something against the cup but I don't remember what.
Basically you are right except it was not another ceramic item. I think that your suggestion and the microscopic pores suggestion from above are both on the right track. And with the microscopic pores on a shiny surface suggestion the marks could have been made by many types of plastic or paint.
I was bothered by what seemed like a magical answer in the plastic. It seems like my target was off and the "magic" is the microscopic pores in the ceramic. That would explain what I was not understanding.
Good Answers: 109
04/03/2014 11:30 PM
Put the cup in a microwave oven. If it gets too hot to touch after a minute, it is likely a metal as has been suggested. Many cheap ceramics can have unwanted metals and some can be toxic. Lead, Barium, and cadmium have been found in some ceramics. Although most ceramics in North America do not use toxic metals in manufacturing dishes or cookware, Imported dishes may still have them. It is possible the metal has migrated to the surface after you purchased it. Yes it should be fully ingrained in the surface and not easy to rid or impossible. I suggested a microwave test because it is easy. Good ceramic will not get too hot, metals are better conductors and will make the surface very hot after placed in a microwave oven. If I am correct, just throw out the cup. My best guess.
Good Answers: 102
04/04/2014 12:22 AM
Cooties
Good Answers: 145
04/04/2014 8:35 AM
Isn't the color a little too dark?
Good Answers: 150
04/04/2014 8:51 AM
depends on the racial makeup of the cooties...
Who is John Galt?
04/04/2014 5:44 AM
Do you think it's just a coincidence that the colour (US color) is the same as that of the printing?
Good Answers: 145
04/04/2014 8:37 AM
It might not show in the picture but the printing is brown and the marks are dark gray. I also have a spot with dark gray marks on top of the brown printing. This pretty well eliminates the "scrape off" ideas but pores in the final glaze seems very reasonable even if impossible for me to see.
Good Answers: 150
04/04/2014 8:05 AM
I'm guessing that microscopic examination of the cup will show microcracks in the glaze due to differences in thermal coefficient of expansion between the substrate and the glaze, allowing some sort of ink (I'm guessing printer's ink from newspaper as well) to wick into the cracks and get under the glaze.
Who is John Galt?
Good Answers: 918
04/04/2014 8:12 AM
I believe you are correct. That's how it works, but it simply fills into the voids of cracks and pits.
It's paint or ink from whatever it was rubbing against.
Barkeeper's Friend and a little elbow grease will probably clean it up.
Good Answers: 145
04/04/2014 8:40 AM
I never would have guessed that but I now think that there is a very good chance that microscopic cracks or microscopic pores (or both) are the answer.
I basically asked the question because it seemed like I was barking up the wrong tree but I couldn't find another tree to bark at. You and several other responders helped me understand it.
Thanks to all,
Bruce
Good Answers: 150
04/04/2014 8:48 AM
But the fact that the cup is riddled with microcracks in the glaze also means that if there ARE toxic metals in the ceramic, then your coffee may be leaching them out and slowly poisoning you too....
Who is John Galt?
Good Answers: 145
04/04/2014 10:42 AM
I'm not a coffee drinker. The cup has rotated back and forth between soft drink duty and a desk top holder for resistors, capacitors, ICs, etc (yes, I know it is not ESD safe). I'll retire the cup from Pepsi duty and it will be able to devote full time to pencils, paper clips, resistors, etc.
Good Answers: 150
04/04/2014 10:50 AM
Well, the lead in the solder on the leads of the components probably isn't helping in that regard either....=b
Who is John Galt?
United States - Member - New Member Engineering Fields - Mechanical Engineering - New Member Popular Science - Weaponology - New Member Hobbies - Target Shooting - New Member Safety - ESD - New Member Technical Fields - Education - New Member
04/04/2014 9:28 AM
I can't believe y'all can't see it. . .
-A-
question everything
04/04/2014 12:43 PM
Try a site like the Marble Institute of America…Removing stains--I know that marble is porous, but they list the chemicals and treatments for various stains, whether organic, metal, ink, oils, etc…You will get an idea of what material removes what type of stain--Look at the poultices, that use talc, and acetone etc, covered and left for a period of time, that draw the offending stains out. We have used them successfully for many countertop stains, that cannot be removed in any other way. Worth a shot, maybe...
Good Answers: 145
04/07/2014 11:58 AM
Thank you,
Bruce
04/04/2014 2:51 PM
I believe you have discovered the dark matter that makes up so much of the universe, but has not yet, (until now!) been spotted.
Turn that over to NASA and see if you get a reward!
MikeMack747
Good Answers: 444
04/04/2014 3:41 PM
Porous glaze in contact with a black sponge rubber mouse pad backing. Some of those old mouse pads would get sticky in a combination of high humidity and temperature.
I would also suspect printers ink, not the usual kind but the stuff from early laser printers. That stuff is microscopically fine and has had chemically active plasticizers as part of their proprietary formulation. I remember having that stuff fuse to many surfaces including formica and glass, especially if it was not perfectly fused to the paper and it sat in contact with a surface for a long time under pressure, temperature and humidity.
Good Answers: 145
04/07/2014 12:22 PM
I think this is close and about as close as I am going to get.
I have a memory of it happening but at the time it was just a small thing that went wrong on an overall bad day. Before asking this question I had assumed all shiny glazed ceramic surfaces were smooth. Once I found out that some are porous then that was the magical part I was looking for.
It was not a mouse pad. It might have been a structural foam Multibus I card cage but we only had light gray cages and this was darker. I remember it being some sort of a flat plastic or rubber sheet/plate that I was taking with me but I don't remember what it was.
04/04/2014 9:40 PM
Could it have been the metal bar that forms the framework for the car seat?
Good Answers: 145
04/07/2014 12:26 PM
No, this was mid car seat. The back of the seat moved something in a rocking motion. The pile of things on top of the coffee cup and plastic/rubber sheet was applying pressure.
What had bothered me over the years was that I thought I had accidentally discovered a neat and very permanent way to mark on a ceramic surface. Once it became likely that a defective ceramic glaze was a key component then the dark mark was just another stain.
04/08/2014 12:44 AM
Schmutz.
04/08/2014 12:49 AM
<unsubscribe>
04/09/2014 12:55 AM
I notice in the photo that there appears to be a border around the letter C, where the marks stop and continue inside the letter? as if the lettering on the cup are stencils? this suggests extra thickness stopped the mark occurring? So if the cup had been painted white and then stenciled with the lettering, this may mean that the marks you can see maybe the original pottery, tapping the cup may spread a soft paint to expose it. Just a thought.
Regards JD.
Good Answers: 102
04/09/2014 1:11 AM
Bruce wanted some ideas on how to replicate the observed very permanent marking on glazed ceramic surface process if and when required.
I have a souvenir cup that was post glaze printed with a photo and it's very permanent. I kinda recall there was a moderate heating step in the process. Maybe a clue there.
04/14/2014 9:26 AM
this was amazing.
Life does not stop and start at your convenience, you miserable piece of..............
Good Answers: 21
04/23/2014 8:21 AM
Permanent marker, once the cap has come adrift ?
Register to Reply 46 comments
-A- (1); Anonymous Hero (2); BruceFlorida (16); C-Mac (1); El Duderino (1); Fredski (1); Hilton (1); jdretired (1); JIMRAT (1); kevinm (1); Kris (1); LongintheTooth (1); lyn (2); MikeMack747 (1); RAMConsult (1); Randall (1); redfred (1); Rorschach (4); SolarEagle (2); Tom_Consulting (1); Tornado (1); truth is not a compromise (2); Wal (2)
