Previous in Forum: Best Way of Marking a Chain?   Next in Forum: Producing Ethanol From Carbon Monoxide....Done
20 comments
More... Navy Rail Guns
04/08/2014 9:35 AM
looks like the navy has decided on s design of this devastating weapon that can fire a projectile easily in excess of 100 mileswe'll see it soon http://www.utsandiego.com/news/2014/apr/07/navy-railgun-sandiego-display-july/
Re: More... Navy Rail Guns
04/08/2014 9:55 AM
Just make sure you have the leads hook-up correctly.......
04/08/2014 10:13 AM
if its phased wrong it just shoots backwards
Good Answers: 26
04/08/2014 10:14 AM
Yea! But can it outshoot my desktop rail gun? I use it to run off pesky management.
Good Answers: 102
04/08/2014 11:11 PM
let's see it in action...
Good Answers: 122
04/09/2014 9:40 AM
Now I know where your management's are located.
If only I could find out where my manager's went.
04/08/2014 3:10 PM
Yay! More weapons!
common knowledge...less common than common sense
04/08/2014 9:34 PM
Indispensable if you have an incoming missile.
04/09/2014 7:10 AM
nifty technology...i suspect it will be applicable to satellite launches in the near term and perhaps be applied to space travel in the not to distant future...to me its an amazing technology directed first at weapons but the possibilities are fascinating.
04/09/2014 8:49 AM
not exactly. launching stuff into space is tricky. the lifting force involved in lifting a payload to orbit are completely different that firing a 23 pound projectile down range. current satellite designs would not withstand the sudden violence. you'd be hurling space junk
Good Answers: 102
04/09/2014 9:50 AM
Surviving the acceleration may be a limiting factor for space launch payloads.
03/01/2017 2:06 AM
When I was a kid back on L.I. I had a toy I really got a kick out of: A rocket that was launched when you released the water pressure in the rocket body. Enough reminiscing, now back to the future.
  • What if you have a hybrid launch system? Starting horizontally with hydraulic propulsion, then air propulsion [ala Elon Musk's "Spruce Goose"] at an increased angle of attack, and at the final stage electromagnetic propulsion,more vertically.
  • Feasible?
  • Could astronauts become acclimated to the G-forces like divers ( assumption here) become acclimated to the pressures of depth?
"If a tree falls in the woods, and there's no one there to hear it, how will the environmentalists react?" — Anonymous
Engineering Fields - Electrical Engineering - New Member Engineering Fields - Power Engineering - New Member
04/09/2014 11:26 AM
the article says is uses (article says "produces") 32 mega-joules of power.
if it is to fire once ....
1 joule = 0.00028 watt hours
32 mega-joules = 9 KWH of power. so.....
a standard 1 MW genset (fits easy in a 40' connex) should let it fire 100 times a hour.
BSEE but always learning
Good Answers: 32
04/09/2014 11:54 AM
Saw a demo of it and they said that the impact creates such a fire ball on impact that it will take down any incoming missile. They didn't explain if there is a guidance system in the projectile or if the aiming system is so accurate that it's guaranteed to hit the target. Not quite sure of how it would have such pinpoint accuracy unless they re-incarnated Sargent York into the aiming mechanism.
Spinco
04/09/2014 2:40 PM
at over 6 times the speed of sound........ that's a lot of potential energy
Good Answers: 150
05/20/2014 8:34 AM
In my experience rail gun rails erode quite quickly, I have to wonder how many times it can fire before they have to replace the rails.
Who is John Galt?
05/20/2014 8:52 AM
That's the cost of doing business........
No different that replacing the cables on the catapult on a Aircraft carrier............ if it isn't being replaced
Good Answers: 150
05/20/2014 9:05 AM
My point being that continuous bombardment is not going to be possible, they will have to constantly swap out the rails. the high power rail guns I've seen generally have to replace rails after every other shot....or more often.
Who is John Galt?
05/20/2014 10:15 AM
OH............ that worse swapping out the barrels on the MG-42 machine gun.
Good Answers: 150
05/20/2014 10:26 AM
"The MG 42 has a proven record of reliability, durability, simplicity, and ease of operation, but is most notable for its ability to produce a high volume of suppressive fire. The MG 42 had one of the highest average rates of fire of any single-barreled man-portable machine gun: between 1,200 and 1,500 rpm, which results in a distinctive muzzle report."
you could at least get a few thousand rounds through that one before having to swap barrels, and the barrels weren't so big you needed a crane to handle them either.
Who is John Galt?
05/20/2014 11:09 AM
Hence the nick name of "Hitler's Zipper" or "Hitler's Buzzsaw"
with a Rate of fire of 1,200 rounds/min (up to 1,800 rounds/min for some versions), on D-Day, that ammo runner, must have been pretty tired.
Register to Reply 20 comments
1capybara (1); Fredski (2); lexx7887 (1); martin wolf (1); phoenix911 (5); Rixter (1); Rorschach (3); SHOCKHISCAN (1); Spinco (1); texasron (1); The.Tinkerer (1); Wal (2)
