Previous in Forum: What Next for Graphene? A Space Elevator?   Next in Forum: Permeance of Kraft Paper
14 comments
How to Remove the Ethanol in Active Carbon
04/10/2014 9:49 PM
Hi All
does any people an tell me how to remove the ethanol in the active carbon, i have use 4H@100drgeeC in the baking oven. but in the out gasing test also can find more than 100Ng/g. i want to reach 20Ng/g.
Pathfinder Tags: remove active carbon ethanol
Re: how to remove the ethanol in active carbon
04/10/2014 9:59 PM
Leave it in the oven longer.
Leave it in the vacuum chamber longer.
Set it on fire.
04/10/2014 10:06 PM
thank you, i need to run this as mass production. the time 4h is the longest. may be the cacuum chamber is a good suggestion.
04/10/2014 10:05 PM
Maybe you need a different type of activated carbon?
http://homedistiller.org/activated_book1.pdf
Good Answers: 141
04/10/2014 10:18 PM
You can do it fast with backflushing steam through the carbon bed. This is a common used process in the industry to recover solvents and alcohols. Separation of the condensed steam (water) is done with a density filter. You will have to build in a safety level (in your separation column) because ethanol mixes partially with water.
Plenty of room here
Good Answers: 88
04/11/2014 9:09 AM
Is there some forced air movement during ovening or you just wait for the temperature to do the job? S.M.
04/14/2014 12:14 AM
there is forced air flow.
Good Answers: 109
Re: How to Remove the Ethanol in Active Carbon
04/11/2014 6:57 PM
I am not sure of the reason you are trying to remove the ethanol from the activated carbon. Activated carbon is relatively cheap compared to trying to regenerate it. So replacement with new carbon is easy and cheap. If you want to extend the life of the carbon for filtration purposes, one method is to inject hydrogen peroxide prior to the filter. The peroxide will catalytically activate the carbon and in effect give more adsorption sites. The effective filtration runs can be extended by a factor of ten. It works quite well on all types of carbon. If it is spent carbon that must be cleaned prior to disposal, you may want to just consider time as a form of treatment. All you will need to do is store it under covers and perhaps again you can inject peroxide into the pile. With time biological processes will destroy the ethanol and other organic contaminants attached to the carbon. Bacteria are very adaptable but the reason to add peroxide is to prevent other decomposing contaminants from forming alcohol.
I have not tried to regenerate AC for many years. It was impossible to meet criteria laid out and we simply resorted to using virgin activated carbon. If I am off base with your targets, ignore my post.
04/14/2014 12:19 AM
in my process i need to use ethanol. but in the last FG parts, the customer has request for ethanol content.
Good Answers: 203
04/11/2014 9:21 PM
Try spray drying it. All measures must be taken to prevent flashing of the solvent and to condense it. The material is put into a vortex like chamber at the top and swirls down at a adjustable rate and with an adjustable heat. The dried powder is collected at the bottom into containers. For some applications an rotary valve must be used to prevent vapors from exiting through the powder collection section.
This is how many dry adhesives, foods such as lemonade, etc. are made. This method is normally used to separates the solid in solutions but there is no apparent reason why it couldn't be used for your processing goal.
http://www.youtube.com/watch?v=u2LhmpDUjKk
http://en.wikipedia.org/wiki/Spray_drying
http://www.niro.com/niro/cmsdoc.nsf/WebDoc/ndkk5hmc6zSprayDryersSprayDryers
Good Luck, Old Salt
04/14/2014 12:24 AM
i use spray drying to reduce from 50% weight to 300NG/G.
04/12/2014 5:45 AM
Just curious. Why is it necessary to get down to 20ng/g?
04/14/2014 12:21 AM
it's customer request
04/14/2014 6:14 AM
You need to create conditions of lower pressure and higher temperature to cause the ethanol to evaporate into the surrounding air, and more time to let it happen to get down to the required level.
Juggle these in combination with things available to you.
Or just mix it with some fresh carbon to average out the density/concentration.
04/15/2014 9:26 PM
thank you, i have found a microwave dry machine to run DOE. thank you!
Register to Reply 14 comments
araki (6); dvmdsc (1); horace40 (2); kevinm (1); lyn (1); old salt (1); SimpleMind (1); SolarEagle (1)
