Previous in Forum: How to Remove the Ethanol in Active Carbon   Next in Forum: What Does BRISK Stand for Under "Project Estimating" Context
12 comments
Permeance of Kraft Paper
04/11/2014 9:18 AM
Does anyone know where I could get a reasonable permeance value for ordinary kraft paper? I just mean the brown paper used to make grocery bags and such, rather than asphalt impregnated paper or plastic-sheathed paper facing for insulation.
I assume there's some variation depending on thickness and soforth, so a range would be acceptable, too.
Re: Permeance of Kraft Paper
04/11/2014 9:47 AM
Look for moisture vapor transmission rate of kraft paper.
I don't have time.
Not sure why you'd want this, since it'll be high.
04/11/2014 12:32 PM
Yes, the high rate of transmission makes it suitable for packaging things that you want to dry out, which I do.
I'm looking for a quantitative way to describe and compare this suitablility. Unfortunately, information that I find in general search results tends to be from the building industry, where what they often refer to as "kraft paper" is either asphalt-impregnated or has a plastic layer, which isn't directly applicable to my needs. So, I thought I'd see if somebody else knew a more direct route to the permeance of plain-jane kraft paper.
04/11/2014 12:49 PM
MVTR of Kraft paper is not a quality that would be considered as important as air porosity in a paper bag.
I doubt anybody will have tested it.
I'd contact some paper manufacturers and ask them.
04/11/2014 1:21 PM
That sounds like a good idea. Thanks for the input.
04/11/2014 10:08 AM
I can tell you that double bagging for refrigerated and frozen foods is a good idea....but plastic is better...I personally use the canvass type....
04/11/2014 1:22 PM
Good to know. Thank you.
04/12/2014 4:53 AM
Contact any cable manufacturer who makes paper insulated lead covered cables. The insulating papers are kraft and Brugg, Prysmian, NKT, Pirreli may help you.
04/15/2014 9:04 AM
I'll look into it, thanks for the suggestion.
04/12/2014 9:55 AM
Is this any help?
http://wmich.edu/pci/faculty/Publication/fleming/06SEP10.pdf
04/15/2014 9:05 AM
Ah, here we go! I'll have to do some figuring, but I think I can get there from here. Thanks!
Good Answers: 150
04/14/2014 7:49 AM
I can tell you that insulation with kraft paper backing in 30 year old houses that I've renovated is eaten up by insects (roaches usually) and brittle as hell. So I'd call 30 years an upper limit.
Who is John Galt?
04/15/2014 9:07 AM
I'll keep that in mind. Thanks for the info.
Register to Reply 12 comments
CGR (6); IQ (1); lyn (2); Rixter (1); Rorschach (1); SolarEagle (1)
