Previous in Forum: How to Make Demineralized Water for Super Heated Steam Boiler?   Next in Forum: Internal Design Pressure
Ask Gland Packing
04/12/2014 9:50 AM
What's the difference between "gland packing" and "packing gland". Does those two terms refer to the same thing?
Regards,
Re: Ask gland packing
04/12/2014 10:45 AM
"A gland is a general type of stuffing box, used to seal a rotating or reciprocating shaft against a fluid. The most common example is in the head of a tap (faucet) where the gland is usually packed with string which has been soaked in tallow or similar grease. The gland nut allows the packing material to be compressed to form a watertight seal and prevent water leaking up the shaft when the tap is turned on. The gland at the rotating shaft of a centrifugal pump may be packed in a similar way and graphite grease used to accommodate continuous operation. The linear seal around the piston rod of a double acting steam piston is also known as a gland, particularly in marine applications. Likewise the shaft of a handpump or wind pump is sealed with a gland where the shaft exits the borehole.
Other types of sealed connections without moving parts are also sometimes called glands; for example, a cable gland or fitting that connects a flexible electrical conduit to an enclosure, machine or bulkhead facilitates assembly and prevents liquid or gas ingress."
http://en.wikipedia.org/wiki/Stuffing_box
Gland packing....
https://www.youtube.com/watch?v=xrB1IpCXNQ0
04/12/2014 11:01 AM
Then, there's this"
• Static Radial Applications
Common Fixed Seal
Dynamic Reciprocating Applications
Moving Piston/Cylinder
Static Axial Applications
Face Seals
Metric Gland Design
04/12/2014 11:59 AM
so is it correct to assume that "gland packing" refers to the packing rings as in the picture above where as "packing gland" refers to the entire assembly of the stuffing box including the packing, gland follower, etc.? please correct me.
04/12/2014 12:45 PM
Yes....
04/14/2014 5:21 AM
Correct.
Anonymous Poster #2
Re: Ask Gland Packing
04/13/2014 8:27 AM
English definition differs as word is used as 'noun' or 'verb' or 'adjective',
"gland packing" could be the material used, or "gland packing" could be the could be the act of placing the material,
on the other hand, "packing gland" is a device for sealing a shaft...you get the context from the placement of the words in the sentence, that is what makes translation of languages difficult.
Anonymous Poster (2); lyn (1); PWSlack (1); SolarEagle (2)
