Previous in Forum: Ask Gland Packing   Next in Forum: HVAC Question
Internal Design Pressure
04/12/2014 10:20 AM
For valve bolting calculation in ASME B16.34 we consider pressure as a class designation ( such as 150, 300, 600,900,1500 & 2500). In ASME section viii div.1 for valve joint bolting calculation can we consider the internal design pressure (P) same as class designation?
Anonymous Poster #2
Re: internal design pressure
04/12/2014 2:08 PM
No....
ASME VIII clearly defines the design pressure. It is the maximum pressure that the system is expected to sustain at maximum pressure... plus a margin if desired.
You are aware the ASME B16.5/B16.34 pressure class designation IS NOT THE SAME as the maximum allowable pressure for the flange ?
A "Class 150" flange can, with the right combination of materials and temperatures, sustain much more than 150 psig.
You understand how this works........right ?
Re: Internal Design Pressure
04/14/2014 5:20 AM
No, as there is no mention of temperature.
04/14/2014 6:09 AM
If design pressure is not given for valves can we consider 90% of maximum allowable working pressure as a design pressure?
04/14/2014 9:45 AM
"We" can do whatever "we" wants. However, it would be inadvisable to do anything without consideration of the temperature!
