Previous in Forum: Make An Electrode   Next in Forum: How Make A Silica Gel(SIO2) Tablet
Activated Sludge Process
04/15/2014 10:39 PM
we are oprating 2 mld tannery effluent waste water treatment plant.aeration tank inlet parameters values are as givenbelow ph-8 TO 8.5,tds 20000 to 23,000mg/,cod 3500 to 5000 mg/l, aeration detention time is around 38 hrs.right now we cant cod,bod reduction ,and microbes also not growing,oulet of sec very turbitity. dissolved oxygen values very low in aeration tank ie lesssthan1.00.even we try to increase the do values with addtion of liquid oxygen still we cant get constant reduction values,[lz advice to me
Re: activated sludge process
04/15/2014 11:15 PM
Seek local, professional help, soon.
04/15/2014 11:27 PM
Throw in 50 kilos of dog food, to give the good-guy bacteria something to chew on.
Good Answers: 42
Re: Activated Sludge Process
04/17/2014 2:56 AM
You need to review the process waste water segregation of the tannery like chroming, sulphide treatment baths washings etc.
Another major important factors are temperature of the effluent not to exceed 40 degrees Centigrade, Extreme pH values of the effluent say too acidic or too alkaline.
If you have any primary treatment please mention the type of coagulants your plant is using & level of color & turbidity of primary clarifier exit water.
Very high salinity levels can also be a bothering factor, which may hinder bacterial growth.
Details of process of tanneries , inclusions & exclusions, segregation & above mentioned points are critical factors.
Your open details perhaps can bring forth inputs to the solution discussion.
Nature is so graceful and naked. Human possession is ridiculous.
Location: Washington (the state), 2 blocks from the Columbia River
04/17/2014 11:00 AM
If you need to increase dissolved oxygen level, I don't think liquid O2 is the way to go. Think about the goldfish in your fish tank - you don't add liquid O2; you use a bubbler pushing a lot of little air bubbles into the water. Suggest you try a larger "bubbler" to increase dissolved O2 in the "water". And you want lots of little bubbles, not a few big ones so there is more overall surface area to allow the O2 to dissolve into the water.
The reward for a job well done is another job.
Good Answers: 179
04/29/2014 1:08 PM
There's not enough information presented to make any determination.
Complete Mix or Plug Flow Activated Sludge process?
F/M ratio? Nitrogen and Phosp. Concentrations? Are you sure that your microbes are getting enough nutrients?
Return Activated Sludge Return Ratio and rate from the Secondary Clarifier?
Type of aeration disc? Fine or coarse bubblers? Have they been lifted and cleaned of any clogging recently? Induced air rates?
What does the biomass look like under the microscope? Has anyone done this yet?
Is there any evidence of high constituent concentrations such as heavy metals and/or chemicals in the waste stream that would case such a disruption?
MLSS? MLVSS? VSS?
DO values?
Mean Cell Residence times?
I could go on and on with questions....
CaptMoosie (1); JL Dowell (1); lyn (1); s.udhayamarthandan (1); Tornado (1)
