Previous in Forum: What Does BRISK Stand for Under "Project Estimating" Context   Next in Forum: Activated Sludge Process
11 comments
Make An Electrode
04/14/2014 12:31 AM
hi All
is any one know to use carbon and PTFE to make cabon electrode?
Re: make an electrode
04/14/2014 12:37 AM
Drill a hole in the PTFE. Stick a carbon rod of the same diameter through it.
04/14/2014 1:03 AM
sorry, it's carbon and PTFE mix together, and make the carbon like a piece of paper
04/14/2014 1:33 AM
Then mix the carbon with the uncured PTFE mix and let it cure in thin layers.
04/14/2014 1:55 AM
how can i make it as roll material? how much water i need to add?
04/14/2014 3:04 AM
What do you know about the process at all and why would you add water?
Are you proposing to use PTFE flakes and carbon to make a kind of paper?
Better describe what you are trying to achieve.
04/14/2014 3:46 AM
i mix 60% weight liquid PTFE /(water) 5 times weight of carbon and carbon together.
mix for 30min
spray dry the blanding
i want to not use the spray dry.
04/14/2014 6:33 PM
What we have here, is failure to communicate.
You want a conductive teflon sheet?
Rod?
What?
04/14/2014 10:01 PM
PTFE is just bond, i need the carbon like paper.
Re: Make An Electrode
04/14/2014 7:19 AM
Yes. One instrument manufacturer comes to mind (name withheld).
04/14/2014 10:08 PM
This sounds more like a brush than an electrode, although the borderlands might be indistinct. In any event, a realistic description is needed.
04/14/2014 10:11 PM
Teflon makes no sense, especially as a binder.
araki (4); IdeaSmith (2); lyn (2); PWSlack (1); Tornado (2)
