Previous in Forum: Activated Sludge Process   Next in Forum: Detachment Test: Ideas?
11 comments
How Make A Silica Gel(SIO2) Tablet
04/15/2014 11:26 PM
hi everyone
does any one know how to use silica gel(SIO2) powder to make a tablet by press? which bonder can be used?
Re: how make a silica gel(SIO2) tablet
04/15/2014 11:29 PM
Black widow spider excretions.
04/15/2014 11:32 PM
Water.
04/15/2014 11:33 PM
Cheapskate.
04/15/2014 11:56 PM
Well, I believe that araki "Howto" (all his posts start with How to) is looking to save money. Any way he can.
Spiders are uncooperative.
04/16/2014 12:10 AM
That's for sure. We once had a black widow in our basement. My wife whacked it with an ice axe, so we posthumously named it Leona Trotsky.
Re: How Make A Silica Gel(SIO2) Tablet
04/16/2014 3:58 PM
Sort of like a mud pie.....
http://thegingersnapgirl.blogspot.com/2012/01/non-mississippi-mud-pie.html
04/16/2014 10:58 PM
Nothing.
Just use a Palletizer Machine to Extrude Palettes
04/17/2014 12:53 AM
Ethyl silicate...
Good Answers: 117
04/17/2014 9:03 AM
In other words nobody has a clue!
04/17/2014 9:23 AM
From Wikipedia:
Preparation[edit]
A solution of sodium silicate is acidified to produce a gelatinous precipitate that is washed, then dehydrated to produce colorless silica gel.[5] When a visible indication of the moisture content of the silica gel is required, ammonium tetrachlorocobaltate(II) (NH4)2CoCl4 or cobalt chloride CoCl2 is added.[5] This will cause the gel to be blue when dry and pink when hydrated.[5] An alternative indicator is methyl violet which is orange when dry and green when hydrated.
From me: Thus, if you wish to make a tablet of this material, you would simply add a small amount of the sodium silicate liquid to a powder forming a paste, then acidify (muriatic acid is sufficient for this) accordingly to the quantity of sodium silicate employed, the form the tablet from the paste in a tablet press. I suspect that less than 1% sodium silicate addition might be necessary to achieve useable results. One may also need to re-heat the resulting tablets to remove excess moisture/HCl.
I also like the idea one of the other respondents had of using ethoxy silicate. That idea has merits and should not be discounted too early.
Good Answers: 117
04/17/2014 12:51 PM
I stand corrected! Somebody DOES have a clue! Yaaaaaay
Register to Reply 11 comments
James Stewart (1); lyn (2); MUKULMAHANT (1); SolarEagle (1); Tornado (3); yesyen (1); Yusef1 (2)
