Previous in Forum: 415v 2 Phase 16 Amp Demag   Next in Forum: Electrical Motor Starter in Star Delta
How to Connect Inverter with RCBO ?
04/16/2014 7:56 AM
I have main connection of 4KW , I wanted to put a RCBO - 32 A ( 30 mA - 2 pole - Siemens) , I also have a inverter of 800VA , which will auto connect to my lighting and some smaller loads i.e loads like refrigerator,Water Pump,AC , Iron , water Heater,Microwave will be excluded from inverter.
My electrician suggested like the RCBO will be put on the mains , and the inverter will be feed into individual MCB's. I felt like this will make the RCBO to trip as there will always a difference of current RCBO will detect.
Please let me know if I am correct . if correct how do I protect my circuit using RCBO , at the same time , I should be able distribute the inverter power to appropriate appliances.A small example will be of immense help to me.
Looking forward to your help
Sujit Roy
Good Answers: 102
Re: How to Connect Inverter with RCBO ?
04/16/2014 11:14 PM
Sketch please.
04/17/2014 7:12 AM
Follow British Standard 7671.
If there is a difference in current and the RCBO trips on the difference, then there is a fault downstream that requires immediate disconnection and rectification before reconnection as a load.
If the RCBO trips on overcurrent, then there is too much load connected to that particular circuit for the wiring to withstand long-term.
If in doubt, consult a qualified Electrician.
Register to Reply 2 comments
