Previous in Forum: Gone Carting!   Next in Forum: Breaking into a Honda CRV
15 comments
Good Answers: 11
1995 Subaru SVX Fuse-Blowing Mystery
04/23/2014 12:42 PM
OK, so I've got my daughter's SVX-LS stuck in the shop after it left her stranded on the road some months ago. Just died with no warning. Cranks but no life.
Discovered so far that it is blowing a fuse which feeds power to the ECM, A/T Module, Fuel Pump Relay, an MFI (??) Diode, and all of the ignition coils. I put in a new fuse, and it pops as soon as I turn the key.
So far, I have isolated each one of these items with no revelations. Next thing is to become a contortionist under the dash to trace and examine the wiring.
My question to the brain-trust is if it is feasible to connect a continuity meter between the line side of the fuse socket and the chassis, then look for resistance changes as I wiggle, move the bundles of wires.
My thinking is that it may narrow down what bundle of wires contain the offender causing a dead short.
Would very much appreciate any suggestions, as my knowledge base of auto electronics is not that strong.
Thanks in advance!
People Living in Competition, All I want is to have my peace of mind - Boston
Re: 1995 Subaru SVX Fuse-blowing Mystery
04/23/2014 1:24 PM
My question to the brain-trust is if it is feasible to connect a continuity meter between the line load side of the fuse socket and the chassis, then look for resistance changes as I wiggle, move the bundles of wires.
Might work, but most of the wires are going to be bundled together pretty tight in the harness. You might have to do a lot of unwrapping and then re-wrapping.
You might try checking for a short on the key switch first before that pain.
Edit: Check for burn marks where the bundle(s) go through the firewall. The grommets get dried out, crack, and then normal vibration chews through the insulation.
04/23/2014 1:48 PM
Good Answers: 88
04/23/2014 1:57 PM
Temporarily replace the fuse with a big 12V 55/60W halogen lamp like the ones used for car headlamps, using appropriate cable extension and suitable connectors resembling fuse legs. Put the halogen somewhere that you can see it but won't start a fire when lit and switch the ignition ON. All you have to do is find what makes the halogen emit white light. S.M.
Good Answers: 67
Re: 1995 Subaru SVX Fuse-Blowing Mystery
04/23/2014 8:18 PM
Does she recall passing a Chevy Cavalier?
*Any* Chevy Cavalier?
04/23/2014 10:40 PM
Cavalier cooties jumping ship?!
Good Answers: 67
04/23/2014 10:57 PM
04/24/2014 3:07 AM
you mean: did she hit one?
04/23/2014 8:26 PM
I would bypass the fuse and hold the wire completing the circuit by hand, in the daylight wait for smoke, at night look for spark....feel for heat with hand if nothing sighted....make sure you have isolated everything you can first though...I would put an amp probe on there first, for a visual on the short...or as someone suggested, a light...You're going to have to make a repair anyway, why waste all day looking for it....Don't leave it shorted too long or you could damage the battery....just a few seconds at a time...
04/24/2014 4:30 AM
Like it, my thoughts too......
Good Answers: 25
04/24/2014 1:30 AM
Connect a twelve-volt buzzer or Sonalert® by wiring/soldering its terminals to a "blown" fuse with short lengths of wire. Plug the "adapter" fuse into the fuse block, and, if a short is occurring in that circuit, the noisemaker will, uh, make noise as soon as power is supplied. Disconnect and wiggle things until the noise either stutters or stops, and you will have found the short.
Please, note that this won't work if the circuit requires more than just a bit of power; the circuit impedance/resistance, even if operating correctly, will be low enough that the buzzer will sound. In that case, the devices supplied by that circuit must be disconnected before fiddling with the wiring.
04/24/2014 3:16 AM
Alarm bell went on when you said : "Daughter".
I would quizz her if she hit something (like a Chavalier haha) or anything.
A cable sqeezed under plastic will not be noted unless you know where it was hit.
Other than that what does the code reader come up with? I know you have it in the shop, but what are they saying?
04/24/2014 4:34 AM
I had this on a Mazda about 40 years ago. I could not get at the wire without taking the engine and gearbox out. The wire ran from the ignition switch, thru the firewall to the engine....the short to frame was between firewall and engine.
Got the car schematic, cut the wire at fault at both ends and ran a new one, problem solved.
Took a whole weekend of work!!!
Good Answers: 11
04/24/2014 7:13 AM
THANKS to all who offered good suggestions! I have the schematics that allowed me to isolate vulnerable downstream components. It's been sitting in my workshop waiting for weather to break. I didn't ask her if she was within a half-mile of a Cavalier at any point, and I'll look into that too!
Fans of Old Computers - PDP 11 - New Member
Location: In a mushroom field somewhere in Canada. Kept in the dark and fed sh--, well you know.
04/24/2014 7:49 AM
Yes, use a continuity tester. See below. They will come with instructions on how to use. The needle point allows you to pierce wires without ruining them and to get into tight spaces.
Here's a circuit to build one for an audible tester
Dirt is for vegetables. Pavement is for racing.
Good Answers: 444
04/25/2014 11:03 PM
I've had good luck with one of these. Based on the readout you get an idea if it's a dead short, intermittent, through a coil, light bulb, etc.
Register to Reply 15 comments
Andy Germany (2); AverageJoe (1); Ed Watts (1); europium mkII (2); Fredski (1); IdeaSmith (2); Kilowatt0 (2); RAMConsult (1); SimpleMind (1); SolarEagle (1); unclefastguy (1)
