Previous in Forum: TV, Speaker all is Flat now !!   Next in Forum: RFID
8 comments
Define the Phenomenon?
06/17/2007 9:05 AM
My antiglare screen makes an outward kick,everytime i turn on my crt monitor !PLs anybody explain the phenomenon!
Re: define the phenomenon
06/17/2007 10:01 AM
My guess is it's probably the static charge built up on the antiglare screen. At switchon the sudden high voltage on the tube (or maybe the de-gausing voltage) is creating an electrostaic force against the antiglare screen.
(Someone will probably shoot me down on this one, but I've packed my 'chute.)
06/18/2007 2:41 AM
It is,n,t degaussing voltage as this is ac(has to be to demag the shad mask)- it would be the eht of 25 to 32 kv( dep on screen size), which comes in a rush as you turn - you can feel this by putting the back of your hand to the screen- interestingly, I also use anti- radiation screens, but have never noticed any movement- the screens can be plastic or glass, but in every case should be earthed- they come with a lead for this purpose- just connect to an earth on your setup.
06/18/2007 2:58 AM
Sounds good to me...
Could this be the cause of my baldness...my hair is now all stuck to assorted VDUs?
06/18/2007 6:16 AM
More likely it's your Avatar thinking with its fingers (or is that toes) has attracted the hair away from your head
06/18/2007 7:22 AM
You have hair on your head????
All my hair has emigrated to my chin, ears and nose...
John.
United States - Member - I am a Yankee Doodle Boy. Engineering Fields - Manufacturing Engineering - Old School is the best school. Safety - ESD - Safety Mgr that keeps the peace Hobbies - DIY Welding - My Motto:
Good Answers: 26
06/18/2007 9:43 AM
Legally or illegally???
If necessity is the mother of invention then is laziness the mother of necessity?
06/18/2007 3:44 PM
Right, and if so, why won't this antiglare screen have a proper discharge (earthing) cable going from the screen to the PC chassis, to avoid this in the first place?
Mine does.
Re: Define the Phenomenon?
06/18/2007 6:19 AM
If your antiglare screen contains magnetic material, I imagine it would be attracted by the antigaussing signal, and bounce of the CRT. Similarly, I would have thought the EHT would attract your screen.
Perhaps you could check for the first by trying your screen with a normal television that doesn't use such a large degaussing signal.
Register to Reply 8 comments
Anonymous Poster (2); double_j_b (1); Electroman (1); Neil Kwyrer (1); user-deleted-1105 (2); Yuval (1)
