Previous in Forum: Stablize an Unstable System with Open-loop Controller   Next in Forum: Shock From Solar Panel Cable
SCADA CPU Recommendation
05/05/2014 2:27 AM
Gentlemen,
In our rendering plant the environment is very stick, which effect the control room also. The SCADA client CPUs in that area having too much issue with power supplies, Hard disks and mother Board.
Can you Please suggest me some PC which can sustain in tough environment also.
All the problems of the world could be settled easily if men were only willing to think. The trouble is that men very often resort to all sorts of devices in order not to think, because thinking is such hard work.
Good Answers: 109
Re: SCADA CPU Recommendation
05/05/2014 4:01 AM
You should be looking for "industrial computer".
Quote your specific environment to the Vendors (Siemens comes up in the search) and get some quotes!
Good luck!
05/06/2014 12:57 AM
I have checked the Siemens Idustrial PC, Its No doubt a better option. Thanx
Location: KCM, chingola; copperbelt; zambia; southern africa.
05/05/2014 6:52 AM
industrial PC is the only way, or go to the manufactures with your complaints
an error does'nt become a mistake if corrected!
Good Answers: 203
05/05/2014 7:36 AM
Place all but the mouse and the keyboard in a cabinet that has a gasket sealing the door on it. Pressurize it with 10-15 inches of H2O with clean fresh air with a source from outside the "sticky" area. Put a switch or valve controlling an annunciator on so that it activates an annunciator when the door is opened. When the mouse or keyboard are no longer useable toss it and replace it with another inexpensive replacement.
Monitor can also be accommodated in the cabinet if there is a glass or Plexiglas window in the door or a side of the cabinet. Another possibility would to put a very clear plastic bag over the monitor and tie is around the base or mountings of it.
This is a time proven method of enclosing instrumentation in dusty, high humidity, some XP areas and other environments detrimental to the operation of computers or other equipment.
Good Luck, Old Salt
05/05/2014 9:44 AM
First you need to clean up the environment in the control room. Otherwise you are going to continue to replace computers.
Industrial computers, and sealed cabinets will help extend the time between replacements, but that doesn't address the root cause: Poor environmental controls.
Good Answers: 19
05/05/2014 2:46 PM
I had just tossed this email away, but retrieved the URL - it's a soft sales pitch for Siemens industrial PCs.
http://www.totallyintegratedautomation.com/2014/05/industrial-pcs-true-meaning-industrial/
The others' comments on cleaning up the environment on spot on. One doesn't do commercial food preparation in the back of garbage truck.
Good Answers: 804
05/05/2014 8:37 PM
I also highly suggest using solid state drives instead of hard disk drives (rotating media).
Register to Reply 7 comments
Bud (1); DmanEng (1); IdeaSmith (1); JRaef (1); Kilowatt0 (1); old salt (1); tehseen (1)
