Previous in Forum: How to Make Light Sensor Switch on Human Presence   Next in Forum: Single Phase to Three Phase Conversion Of Current
12 comments
Energy Efficient Light Bulbs
05/27/2014 4:42 PM
I have a question about the incandescent light bulbs that are labeled 60W, but said to consume only 48W. Do they accomplish this by using a thicker filament (less resistance), or are they 130V long life construction?
Mr.Ron from South Ms.
Good Answers: 445
Re: Energy efficient light bulbs
05/27/2014 5:06 PM
130 volt, also known as severe duty or extended life since they run at a lower temperature.
05/27/2014 5:10 PM
Without more details about which bulbs you are referring to I would have to guess that you comparing a quartz tungsten halogen vs. a basic tungsten lamp. Since the tungsten atoms that vaporize off of the filament get redeposited in a quartz halogen bulb the filament can run hotter. This alone allows for more efficiency but the filament shape can now be more convoluted, too. This coiled filament will look at a glance to be thicker but the wire itself is actually a thinner wire in the shape of a coil (spring). By using a thinner filament wire the filament cools quickly when power is turned OFF an thus the tungsten redeposits on the filament.
05/28/2014 2:54 PM
Good answer.
Ordinary light bulbs contain a small amount of Nitrogen and an even smaller amount of Argon. Halogens contain a higher ratio of Argon to Nitrogen, and also contain some Krypton. This combination of gases acts a heat sink to the filament, allowing the filament to run hotter, thus producing more light without degrading the filament life. It also allows the tungsten re-deposition you mentioned.
Good Answers: 804
05/27/2014 5:59 PM
Huh, interesting. I've wondered that myself. When I worked for Siemens a few years ago, we shared booth space with Sylvania (a sister company) and I asked something similar to one the lamp guys. He told me that on most of the incandescents that you see in the store, the label saying "60W, uses 48W" is a mostly a marketing gimmick in that it is a 48W lamp, but has a reformulated phosphor coating that luminesces at the same rate as an old 60W frosted lamp used to. So the "60W" is relative only to the lumen output. The thing is, how can we compare now? The old ones are no longer available...
Re: Energy Efficient Light Bulbs
05/27/2014 8:48 PM
From: http://en.wikipedia.org/wiki/Incandescent_light_bulb
For a supply voltage V near the rated voltage of the lamp:
  1. Light output is approximately proportional to V 3.4
  2. Power consumption is approximately proportional to V 1.6
  3. Lifetime is approximately proportional to V −16
Operating a bulb at a lower voltage has several effects. From (3) the lifetime is vastly extended. From (1) and (2), the power consumption is reduced, but the light output is reduced even more, so it is less efficient.
Good Answers: 39
05/27/2014 10:51 PM
They basically run a 95 volt lamp at 117 volts and you get more light per watt, but a lot less life. See the formulas above. It's a desperate ploy to stave off the Cree LED lamps.
Align culture with nature...
05/28/2014 5:35 PM
I've been converting all of my lighting to LED bulbs. I am pleased with the results but the upfront costs are pretty high.
Yesterday I bought another LED light bulb from WALMART. This tells me they will be going mainstream quite soon.
There is still a lot of thermal loss due to voltage conversion; perhaps one day lighting circuits will be on separate low voltage circuits.
I light my carport with homemade LED light sets on a 12 volt circuit. It draws 30 milliamp. That's about .36 watt. The light set cost me about 3 dollars to make. Not blindingly bright but quite adequate.
05/28/2014 12:48 AM
If the marked power consumption differs significantly from the measured power consumption then someone is being mislead or it's running on the wrong voltage.
Given that most of the power consumed by an incandescent lamp is converted to heat rather than light, then a measure of the lumen output is useful to understand how bright it will look.
With the range of new lamp technologies now on the market, the relationship between power consumed and lumens produced is highly variable.
05/28/2014 7:16 AM
All of the input energy is converted to heat, it is so hot (2700 K or more) the filament becomes incandescent.
05/28/2014 1:15 AM
Twenty years ago I got some surplus traffic light bulbs. They are rated at 60 watts but give off the light of a 25 watt bulb. We like the soft warm glow they emit. They're designed to turn on and off continuously and are rated at 8000 hours. It's been ages since one burned out on me. One time the electrician sent them 220 volts. They got eral bright but they didn't burn out.
I visited the State Capitol building recently and high in the middle of the dome is a thousand light chandelier. From my vantage I could see that it was stocked with the all too familiar traffic light bulbs.
05/28/2014 6:25 PM
I worked at a hotel at one time in the maintenance department. They had hundreds of light bulbs that were rated at 130 volts. For some reason (I don't recall), they wanted to get rid of them and switch to different lamps. I was able to latch on to a few cases of these bulbs. That was over 25 years ago and I don't recall what happened to those lamps. I remember giving some away and using some myself. If I had them today, I would never have to worry about ever being in the dark.
United States - Member - VT
06/01/2014 10:08 AM
Halogen lamps are available with a infrared reflective coating to recycle some of the heat. Less heat emitted = less electricity needed to keep temperatures up to emit light. When I learned of these from a major manufacturer (had to ask, even though they were trying to sell efficiency!) they said about 30% savings. Direct replacement, dimmable, it is a halogen lamp. I have fixtures in my kitchen with an exposed MR16 lamp. I cannot tell the difference between the 50W and 37W lamps. I don't rememeber specs for longevity, I think it is better.
Maybe similar technology is used for incandescent lamps?
Remember to look at lumens per watts consumed @ voltage when comparing lamps. The selection of LEDs is getting better...
Light is a nutrient.
Teach your cat to write
Register to Reply 12 comments
Charlie Greenwood (1); Gavilan (1); jonaparker (1); JRaef (1); JWthetech (1); NeilA (1); ormondotvos (1); RAMConsult (1); redfred (1); Rixter (1); ronseto (1); Usbport (1)
