Previous in Forum: Oil Seal Question   Next in Forum: Adapting Electromechanical Equipment
29 comments
Cantilever Base Plate Design
05/30/2014 3:59 PM
I have to design a base plate for a cantilever beam which i have to connect with a chain attachment and my SECTION IS MCP75 which has to with stand a load of 250kg or 2500N only and my cantilever length is 500mm please suggest me
From the CR4 Rules: Do not post phone numbers or email addresses. The CR4 Admin will delete all phone numbers and email addresses posted in threads or comments. You can share this information via the CR4 internal messaging system.
Re: Cantilever base plate design
05/30/2014 4:06 PM
Suggest you get busy looking for a cantilever beam design guide.
05/30/2014 4:17 PM
Dear sir,
If u don't mine can you please send me a link where i can download the cantilever design guide
Thanks & Regards
Prashant Kumar Ravella
05/30/2014 4:39 PM
Good Answers: 183
05/30/2014 5:03 PM
I wanted to have a look at the optimization but I could not reach it. may be the link has an error cold you check ?
05/30/2014 5:32 PM
This work was done by Timothy Demers at
Rensselaer Polytechnic Institute (RPI) - Hartford Campus
This link seems to work: View as HTML
Fans of Old Computers - PDP 11 - New Member
Location: In a mushroom field somewhere in Canada. Kept in the dark and fed sh--, well you know.
06/02/2014 7:37 AM
CR4 ADMIN: Deleted Post
Abuse/Attack: This post was deleted because it was an attack on another user. Please review the CR4 Site FAQ and the CR4 Rules of Conduct.
Dirt is for vegetables. Pavement is for racing.
06/02/2014 3:16 PM
06/02/2014 7:33 AM
05/30/2014 4:13 PM
05/30/2014 4:37 PM
Respected Sir,
The above example u posted is for column under axial loading in my case it is cantilever beam please suggest me for cantilever beam
Thanks
05/30/2014 7:28 PM
05/30/2014 8:32 PM
Get it right. People's live are at stake here.
Never mind that OP doesn't have the slightest clue what he's doing.
05/30/2014 9:38 PM
If I have to pay attention, I want a raise....
Bitcoins will be fine...
06/02/2014 3:26 PM
06/02/2014 7:35 AM
05/30/2014 11:10 PM
Please explain this chain attachment. I would expect bolts or welding.
Lehman57
05/31/2014 1:55 AM
Cantilever base plate is attached with the chain attachment by means of bolt only
05/31/2014 11:16 AM
Those words make no sense!
Out in a Bowt
05/31/2014 7:18 PM
Like this?
Good Answers: 183
06/01/2014 5:17 AM
The direction of the reaction vector is wrong!
06/01/2014 6:10 PM
Depends on whether it is the force of the beam on the wall, or the wall on the beam.
Lehman57
Good Answers: 183
06/02/2014 2:59 AM
Am I wrong or we discuss the base plate ? Do you find in the sketch any force pulling the plate ? May be a new way of interpretation.
06/01/2014 3:26 AM
Prashant:
Since your written description is ambiguous at best, please provide a drawing thoroughly describing the configuration.
05/31/2014 12:08 AM
05/31/2014 7:09 AM
A sketch might help; your descriptions are unclear.
Good Answers: 38
05/31/2014 1:52 PM
This is the guideline that you want:
http://www.aisc.org/store/p-1529-design-guide-1-base-plate-and-anchor-rod-design-second.aspx
Your baseplate design is a little different from a column baseplate design, insofar as you have no axial loads into the plate, only modest bending loads.
I believe that your desired plate is a common pipe support baseplate design
I suggest that you consider a four bolt baseplate, ~0.75 inches thick about 100 mm x 100mm
The anchor bolts must be carefully evaluated for both tension and shear. Be aware that different anchor bolts designs exist with different capacities.
The anchor bolts cannot be located too close to the edge of concrete. A special calculation must be done to evaluate this distance.
Suggest google searches "baseplate design" and "anchor bolt base plate"
Is this your first cantilever design with baseplate ?
Respect us....... complete this thread and tell us of your final decision.
http://www.asdipsoft.com/products/steel/base-plate-design/
Good Answers: 38
06/02/2014 10:09 AM
Oooops..
I meant a baseplate about 200 mm x 200 mm and 0.75 inches thick
Weld the MC all around with a 0.25 inch minimum fillet weld....
Sorry
06/02/2014 4:58 PM
What? Units are determined by standards: please adopt one or another; they are not to be interchanged.
Re: Cantilever Base Plate Design
11/19/2017 11:56 AM
Try PCEESoft's ColumnBase software. Model your base plate geometries, assign loads and view precise analysis results. Also, use automatic check/design according to AISC360-10 and ACI318-14 standards.
I invite you to view ColumnBase software. ColumnBase is integrated software for analysis and design of column base plate connections using three-dimensional finite element modeling.
Visual and user-friendly interface, easy to use and precise results.
In this software, all components of the connection are modeled such as the column, plate, stiffeners, anchor bolts, concrete footing, and grout.
Analysis results verified by several valid experimental tests and realistic simulation of base plate behavior is performed by using it.
Analysis results are used for the automatic design of connection components according to standards/codes.
Introduction: http://pceesoft.com/product
View its introduction in LinkedIn http://www.linkedin.com/pulse/introduction-columnbase-software-amir-hasanpour
It is now available for free download at http://pceesoft.com/download
Register to Reply 29 comments
ircivil (1); Lehman57 (2); lyn (6); MalteseXXX (2); MJCronin (2); nick name (3); Prashant Ravella (3); sanweld (1); snowboy (1); SolarEagle (4); Tornado (1); unclefastguy (3)
