Previous in Forum: Cantilever Base Plate Design   Next in Forum: Revision of IFC drawing
16 comments
Adapting Electromechanical Equipment
06/02/2014 10:46 AM
Hello everybody:
For a small hydroelectric powerplant it is analyzed the possibility of installing a turbine and a generator that have been removed from another small hydro plant.
The new site will have the same amount of water (design flow for the turbine) and the net head is increased by approx. 25 meters.
Hereby I would like to have your comments or references to a web site where I can find information describing the possible setbacks and problems that can lead to this new facility.
Thanks in advance.
Good Answers: 145
Re: Adapting electromechanical equipment
06/02/2014 11:48 AM
I don't know if you would be viewed as customer, competition, friend or foe but Bill from http://www.frenchriverland.com/ sometimes posts here. This sounds like the kind of thing that he is an expert at. Be sure to have some spare time when you start browsing his web site because he has hundreds of photographs of his work and you end up going through all of them.
India - Member - New Member Engineering Fields - Mechanical Engineering - New Member Engineering Fields - Piping Design Engineering - New Member
06/04/2014 1:27 AM
Hi bruce
I know it's offtopic to ask this,
the link you mentioned is really a good one. Is there any website, similar to this dealing with steam turbine. please let me know.
(engineering)...is the art of doing that well with one dollar that any bungler can do with two..
Good Answers: 70
06/04/2014 2:27 AM
Nice link Bruce, thanks!
Dan
06/02/2014 4:53 PM
Not enough information.
"net head is increased by approx. 25 meters."
25 meters from what? Is it from 50 to 75? 25 to 50?
That's about 60 PSI increase over whatever you had before.
You'll need information of the turbine design to get anywhere.
Throttling the inflow will likely be needed to keep from over-speeding the generator.
Converting Pump Head to Pressure may be of help.
CR4 ADMIN: Modified Post
Abuse/Attack: This post was modified because it was an attack on another user. Please review the CR4 Site FAQ and the CR4 Rules of Conduct.
06/02/2014 10:31 PM
About 35.5 psi increase, rather than 60.
06/02/2014 10:52 PM
Dyslexia and oldtimers disease have set in.
Not only did I go the wrong way, but I multiplied by the wrong units.
And I'm typing on a phart smone.
Technical Fields - Technical Writing - New Member Engineering Fields - Environmental Engineering - New Member
Location: The 'Hub of the South Pacific'; 18.15°S, 178.45°E
06/02/2014 10:56 PM
244.5 kPa ~ 35.5 psi - check!
VT
Popular Science - Weaponology - New Member Canada - Member -
Location: In the sticks of the Central Kootenays, BC, Canada
Re: Adapting Electromechanical Equipment
06/02/2014 11:13 PM
You'll need to tell us the type of turbine you have, the original design flow and head; and the new flow and head.
From there you can see if the type of turbine can handle the increased head. Probably the answer is yes, even if the flow regime moves into a lower efficiency range.
J.
Good Answers: 34
06/03/2014 1:48 AM
Easiest way is to have two power plants in cascade. Existing TG can be installed at designed head or close to designed head at a suitable location.
At tail race of first TG and 25 meter below a Francis Turbine type TG can be installed.
06/03/2014 3:22 AM
Website? Why not just telephone the turbine manufacturer instead and ask technical questions over the phone? Much quicker, interactive, and one speaks with a real human being - highly recommended.
Make sure that all the available data about the existing turbine is to hand before starting the call, for very little of it has been revealed to CR4 readers.
06/03/2014 10:13 AM
Hello everybody:
First of all, I want to give thanks to the entire posters in this thread for your comments and inputs.
Taking into account the seriousness and professionalism with that the technical questions are dealt in CR4 Forum, I have posted this enquiry with the only aspiration to spread the horizon of alternatives for a particular issue, and not to save a few dollars (or whatever it costs) for consulting services.
sawmilleng, the turbine is a Francis horizontal shaft, with design flow of 6,8 m3/s and a Net Head of 122 m. The new flow is about the same 6,3 m3/s and the Gross Head is 25 m. The latter could be, at the end, a Net Head of around 20 m.
PWSlack, so far, we know the position of the turbine manufacturer related with the technical matters and a possible way to go with this subject. The idea is to get to know by alternate roads what could be the better solution to this situation. Do not forget that for the turbine manufacturer this is another business for them.
By the way, thanks to CR4 ADMIN for acting in my benefit.
06/03/2014 10:32 AM
Eleman,
Original design is a head of 122m and the new head is about 25m? I'm missing something here, as you originally said the head was increased by about 25m
Jon.
06/03/2014 11:47 AM
small? which size in KW output
06/03/2014 3:22 PM
Eleman,
You are talking some pretty big power: Unless I am losing decimal places, the design hp is 11,000hp and your proposed flow and head move that to 12,000hp or a little under 9 MW.
This kind of power production means some significant money will be made when producing it, so I would find a consultant who makes his living at dealing with water turbines who can work with you.
The best place would be the OEM but, as you suggest, they may not be very helpful unless you wanted to have them refit the turbine at their shop--although they may, with the application of money, be willing to go over the engineering figures to tell you what the original turbine might produce at the new flow and head regime. And whether the existing shafts/bearings/gates can handle the increased forces.
Another way of looking at the issue, depending on your constraints, of course, is to arrange the penstock so that the head is actually only 122m to start with and gradually move that higher as the system comes on line.
Sounds like an interesting project. Please keep us posted!
Jon.
06/03/2014 5:37 PM
Hello everybody:
I am very sorry for giving incorrect data. I beg your pardon.
sawmilleng, the correct is: "The new flow is about the same 6,3 m3/s and the Gross Head is increased in 25 m. The latter could be, at the end, a Net Head of around 142m.
You are right, we are in touch with the OEM but, they have been saying: you need this new, that part new, etc. and never has made (so far) a proposal like the one you have suggested at the end of your last post.
I will be in contact with the forum in order that all of you be aware of the development of this subject.
06/03/2014 8:14 PM
Eleman,
You are the driver in this project. ASK the OEM for a cost to do the engineering work you want. If they say "no" then you have your answer and need to find an independent engineering consultant.
The people at French Riverland, mentioned above, are very likely a good group to talk to. I believe it is the Dad, an engineer, and his two kids, both of whom I believe are engineers, too. They have specialized in taking old water power equipment and getting it running again--on the cheap. Therefore, they can probably give you some good information.
Jon.
Register to Reply 16 comments
BruceFlorida (1); dj95401 (1); ELEMAN (2); javo (1); lyn (2); ntr (1); powersolutionsFBD (1); PWSlack (1); sawmilleng (4); Tornado (1); VT (1)
