Previous in Forum: Shores Model D Standard Recording Scleroscope   Next in Forum: Air Flow Measurement by Double Venturi Tube As Primary Element
8 comments
Relay Contact
05/31/2014 2:56 AM
relay contact
i can used relay for the NO Normal open in replace NC because i dont have spare
Pathfinder Tags: relay contact
Re: relay contact
05/31/2014 6:57 AM
Usually no.
Re: relay contact
05/31/2014 7:44 AM
If you have to ask, then the answer is no.
If you're asking for our permission to experiment, then I say go for it. You should find out a critical bit of information about relay logic. Just be careful and respect the energies you are using with this relay.
If you already understand relay logic and are asking if the compliment of a bit of information can be used in place of the original bit of information with the necessary inversion or a clever circuit design then the answer is yes, absolutely this can be done. You have to remember that relay logic is relatively slow and that these two bits are not really compliments of each other.
Re: Relay Contact
06/01/2014 2:09 AM
To the NO contact connect a relay with NC contact
pnaban
Re: Relay Contact
06/01/2014 5:13 AM
Logically, no its no permitted ,but
Yeah, you can for another relay and use the NC of that, but you have to use again a third relay to confirm the on/off condition of relay no 1..
love4everyone
Re: Relay Contact
06/01/2014 5:33 AM
If the relay is handling DC, yes you could use a transistor to invert the logic providing the transistor can handle the current and voltage. The collector is connected to +ve side of relay contacts, and emitter to -ve side. Apply the voltage at the collector to the base of the transistor thru a resistor. When the relay is closed, the transistor is off. When the relay is open, the transistor switches on.
If the relay is handling AC, use a diode bridge circuit including the transistor, so the transistor operates on both +ve and -ve cycles. Again the base is connected to the collector as above.
There will be voltage drops associated with these circuits. If the voltage available across the relay contacts is small, you're up the proverbial.
Good Answers: 70
Re: Relay Contact
06/01/2014 11:24 AM
(KISS)Keep it simple , cheap and safe, buy the proper relay. If you can't find the exact part number replacement, then get one with the same coil voltage and a little higher contact amp rating.
Re: Relay Contact
06/02/2014 3:52 PM
Well Normally Open contacts are the OPPOSITE of Normally Closed so you would need to change the way the circuit works to get the same contact functionality. Potentially possible.
It would be far cheaper, easier and likely safer to just buy a replacement relay.
Re: Relay Contact
06/09/2014 12:10 PM
Most relays are both normally open and normally closed. It just depends on where you attach the wires. NO and NC would refer to how that relay is used in the circuit.
common knowledge...less common than common sense
Register to Reply 8 comments
dj95401 (1); jack of all trades (1); Phaddy (1); pnaban (1); redfred (1); sohail0110 (1); The.Tinkerer (1); Tornado (1)
