Previous in Forum: Clarification on Tariff Meters   Next in Forum: Gen Set Additional Load
Engineering Fields - Electrical Engineering - Ron Nombri Engineering Fields - Energy Engineering - Ron Nombri Engineering Fields - Power Engineering - Eternal Power Papua New Guinea - Member - Ron Nombri
Cable to Connect UPS Relay Card to DCS I/O.
06/17/2014 3:14 AM
What's the recommend control cable to connect a Eaton UPS Relay card (XSLOTRELAY) to DCS I/O? The card users DB-15 connectors.
Kind regards, Ron
Re: Cable to Connect UPS Relay Card to DCS I/O.
06/17/2014 4:01 AM
I think this is the sort of issue where you must go to the respective manufacturers, among other things to determine if the devices are compatible.
06/17/2014 5:08 AM
Most likely any cable that has a DB-15 connector then.
Also called D-sub connectors and plenty of information in the net.
Also looks like eaton has a nice web side to show the connectors on their cards.
http://powerquality.eaton.com/EMEA/Products-services/power-management/connectivity.asp
06/17/2014 5:43 AM
The solution lies in a phone call to Eaton.
06/17/2014 6:43 PM
Thought I see what others have used.
Anyway, had spoken to Eaton earlier, they said the card can be connected via DB15 connectors or any control cable with 15+ wires/threads to connect to the contactor on the PCB is good.
Cheers!
Ron
Kind regards, Ron
Register to Reply 4 comments
IdeaSmith (1); PWSlack (1); Ron Nombri (1); Tornado (1)
