Previous in Forum: Piston Pump   Next in Forum: FMVSS 105 Compliance for After Market Suppliers
28 comments
Designing a Minimalistic Remote
06/20/2014 7:23 PM
We are looking to design a remote control that attaches to the sun visor of a car. Since it will be used in the car, we want the whole face of the remote to work as a large single button. Much like Apple's magic mouse.
We are only looking at the mechanical aspect of the remote, not all the sensors that go along with it. What is the best and most simple way to design a remote like this when keeping in mind of injection molding?
Re: Designing a minimalistic remote
06/20/2014 7:54 PM
06/21/2014 5:33 AM
06/20/2014 10:25 PM
No offense, but given your obvious lack of knowledge of designing IM tooling and selecting materials, I'd suggest hiring a tooling designer.
Even a single cavity prototype can cost thousands of dollars.
Start by using rapid prototyping such as 3D printing to select the shape, then contract with a tooling designer to design the mold. Material selection is a whole other subject.
Good luck.
06/21/2014 12:06 AM
What large single function will it perform?
06/21/2014 1:25 AM
Oh please let it be a self destruct button!
06/21/2014 1:34 AM
Sort of like that hand that comes out of a box, turns off a switch, and retreats to the box. (A Claude Shannon joke, IIRC.)
06/21/2014 1:36 AM
06/22/2014 7:08 AM
Are we having an apocalyptic day or what tcm?
06/22/2014 8:00 AM
Not really. I just like having buttons that blow things up.
06/23/2014 4:15 PM
To paraphrase Mythbusters:
"TCM want Big Boom."
Cheers.
06/21/2014 1:57 AM
"...We are only looking at the mechanical aspect of the remote, not all the sensors that go along with it...."
Apple's 'magic mouse' incorporates a multi-touch surface... likening its operation to that of 'a large single button' as a reference for what you want to design is confusing at best. The quote at the beginning of this comment only makes things more turbid.
If it is to be essentially 'a large single button', then 'all the sensors that go along with it' doesn't really make much sense. On the other hand, if it is to function like Apple's 'magic mouse', considering 'all the sensors that go along with it' would probably be an necessary part of the design process.
In either case, designing something minimalistic will have a far better chance of success if consideration is given to the things that need to be contained in the minimalistic thing and how the user interacts with the the things inside through the device. To do otherwise stretches the limits of what might be legitimately called 'designing' and would probably be more accurately referred to as 'guessing'.
06/21/2014 4:24 AM
Errr, I must be missing something. If you are in the car you are not "remote" from the sun visor. Maybe there is a transatlantic difference in what we mean by "sun visor"
Raise hand from steering wheel.
Adjust visor to suit,
Replace hand on steering wheel.
In what way is the following any better?
Fumble for remote control, press big button.
Manually adjust visor to suit, because it didn't come down how you need it
To me the whole thing seems to be a problem creation exercise...
06/21/2014 7:14 AM
For what it's worth: Those 'universal remotes' don't work as well as advertised. I aimed mine at my girlfriend and tapped the 'mute' button. Didn't work.
06/21/2014 11:43 AM
I have an app for that....
06/23/2014 1:13 PM
The use of "universal" in a description bothers me, too. I doubt any of them have even been proven to be galactic in scope, let alone universal.
Re: Designing a Minimalistic Remote
06/21/2014 7:06 PM
I would say a touch pad membrane embedded in the molding.
Mr.Ron from South Ms.
06/21/2014 11:10 PM
What you need is Gorilla Glass....
http://www.corninggorillaglass.com/
06/22/2014 12:14 AM
Hmmm. First, 'Magic Mouse', now 'Gorilla Glass'.
Is 'Animal Alliteration' prevalent and I've simply failed to notice?
06/22/2014 1:06 AM
Possibly....?
06/22/2014 2:30 AM
None of those are alliteration. The only one sort of close is 'Famous Grouse', because if it is said by someone who speaks in a strange way, or perhaps if you are very British....or is that redundant.... it can be contorted to the point end rhyme is noticeable.
Alliteration happens at the other end of words. The more strict definition required initial syllable to be identical, but often is just refers to two words sharing the same initial phoneme.
Ant antennae
Bull Bullets
Cattle cat-calls
Dingo Didgeridoo
Elephant Ears....et cetera.
06/22/2014 3:38 AM
So that would be a negative....
Good Answers: 117
06/22/2014 6:51 AM
Do you think he meant "iteration"?
06/22/2014 10:20 AM
Maybe a bit dyslexic, but all-animal-iteration, interpreted as repetitive use of animal theme in advertising...a literation interpretation situation....
06/22/2014 5:39 PM
How did you make those emoticons happen?
06/22/2014 6:32 PM
press the green camera and paste in url....
http://www.freesmileys.org/smileys/smiley-basic/fart.gif
06/23/2014 4:19 PM
Animals! Animals EVERYWHERE!
Darn furries ruin everything.
Good Answers: 102
06/22/2014 1:21 AM
Normally, form follows function.
You've provided so little information that I can't even think of any clarifying questions to ask you.
What do you want to do please? In more detail, or if you fear giving away commercially sensitive information then have a go at rewording your posting with just a hint of what you want.
06/22/2014 12:25 PM
You need a sub miniture 5 or 9 way switch and a soft membrane cover Small stuff like from the ZEN or the micro joysticks. Not hard to find if you look.
Torque is not cheap
Register to Reply 28 comments
adreasler (2); LOCKDUKE (1); lyn (1); merc600sec (1); reward54 (1); ronseto (1); SolarEagle (9); tcmtech (2); Tornado (2); truth is not a compromise (4); Usbport (1); user-deleted-1105 (1); Wal (1); Yusef1 (1)
