Previous in Forum: Lets Say i wanna indent for Bolts / nuts sets   Next in Forum: need compress pressure software
How to repair a submerged pipeline
06/30/2007 7:42 AM
i every one
Please can someone suggest a cheap method to repair / weld a leaking 6 inch diameter crude oil pipeline submerged about 1 meter below the surface of a water stream / river. About 5 Meters and 100 Meters distance away from and on both sides of the leaking point, the pipeline leaves the water stream / river and enters the ground and is buried about 1 meter below the ground surface.
Thanx in advance for your sugestions.
Good Answers: 61
Re: How to repair a submerged pipeline
06/30/2007 8:15 AM
I think that you might be able to use a "Pipe Repair Clamp" as shown on this web site.
Scroll down and you will see it about 3/4 of the way to the bottom.
http://www.engnetglobal.com/c/c.aspx/PIP001/brands
  • Pipe Repair Clamps
    Pipe Specials has developed a new repair clamp that provides a fast, economical means of repairing breaks, holes, cracks or other types of damage to steel, PVC, AC Pipes and other types of rigid pipe.
Contact info:
Unit 8, Northlands Business Park
29 Newmarket Str
Northriding
Johannesburg
Gauteng
2162
South Africa 486
Northriding
2162
South Africa
Do it once and do it right
Good Answers: 97
06/30/2007 10:02 AM
Please look at the replies to the previous similar (same) question.
A clamp as shown by #1 is A good idea.
A SA co would gladly exchange a clamp for a few barrels of oil.
07/01/2007 1:55 AM
Use Belzona, a resin compound. I have used in similar situations and it works. There is no welding or no hot work. try www.belzona.com
sisira
Hendrik (1); PennPiper (1); Sisira (1)
