Previous in Forum: Required NEC   Next in Forum: DC Circuit Breaker on a Boat
32 comments
Conductor Length Problem
06/30/2014 10:42 AM
Hi,
In a electrical switchboard if the height of the panel is reduced and consequently the conductors (VERTICAL BUSBARS) height is also reduced, on energizing the system with the same amount of current, what would be the expected change in the temperature rise? (Assume the volume reduction in the enclosure is 14% and in the vertical busbar to be 18%.
Thank You in advance
Leonardo
Good Answers: 181
Re: Conductor length problem
06/30/2014 10:48 AM
Is this homework?
We don't do homework.
06/30/2014 11:09 AM
I think we should consider ceasing to inform those who ask for answers to obvious homework questions that we do not offer answers, and instead we might simply offer obfuscation.
06/30/2014 11:16 AM
Don't just offer a plan of action, execute and demonstrate your plan!
06/30/2014 11:17 AM
Oh, look. Another undefined <...we...>.
06/30/2014 11:19 AM
We are not amused.
06/30/2014 11:55 AM
There is no critical lack of definition. We who need know, do.
06/30/2014 11:59 PM
No sir, This aint homework
07/01/2014 12:08 AM
It should be.
You are not ready for a real job!
<unsubscribe, with prejudice>
07/01/2014 12:12 AM
No I am not. So please help me. And if you cant, keep your mouth shut.
Good Answers: 137
07/01/2014 5:33 AM
If it is homework, my guess it's a trick question and the change is negligible. There are much bigger heat sources in a panel, which don't change.
If it's a gen question, ditto!
06/30/2014 11:13 AM
Temperature is often related to watts produced. Then again without knowing anything about your cooling design, nothing can be determined about an equilibrium temperature.
Do your own homework! I did.
07/01/2014 12:01 AM
The cooling is natural. No forced cooling. The heat is dissipated at a ambient temperature of 35oC
06/30/2014 12:07 PM
How much liquid nitrogen do you normally use?
06/30/2014 12:12 PM
06/30/2014 12:41 PM
That the busbars are vertical is a salient feature. Since heat convection will be the dominant mode of heat transfer and also the most affected by the decrease in height, this will have the greatest affect on the panels vertical heat gradient. This is the reason it will dominate the change in the heat transfer from the panel to the environment and the change in temperature of the panel as well as the bus bar.
Precise solutions would require some powerful number crunching for extended periods, but using the usual standard approximations of Rayleigh numbers and Prandtl numbers, dimensionless temperatures and one dimensional quasi-viscosity you can work out the transition from laminar to turbulent flow on the back of a stained napkin.
After that the change in temperature rise shouldn't take any engineer worth his weight in salt more than an hour to burn through the numbers.
The first question I had for the alien who emerged from the spacecraft was "do you have palindromes in your language?" The alien responded, "Dedno pser nei, laeht. Ega ugnal nis emordni lapev ah, uo yod. Sa Wtfa rceca. Psehtmo rfdegreoh, wneilaehtr ofda hinoits euqtsr ifeht."
06/30/2014 2:06 PM
Should the OP do at least one Turbulent Prandtl number calculation to identify any possible hot spot complications?
Depending on the frequency of the power distribution there could also be magnetic induction eddy current heating effects in any ferrous hardware and shielding.
06/30/2014 4:44 PM
Given what has be described thus far, I can't think of a situation for which not executing at least one turbulent Prandtl number calculation wouldn't be a sign of negligence or incompetence, even at very basic levels. In case anyone needs a refresher, this is a decent refresher that should bring it all back.
07/01/2014 12:04 AM
Hello Sir,
Thank You for your reply. Could you please tell me in detail of how I can do this calculation??? Your help will be much appreciated.
07/01/2014 12:44 AM
The link in comment #15 provides all the necessary detail and example for such calculations.
07/01/2014 12:29 PM
Thank You Sir
06/30/2014 1:33 PM
Don't do that.
Next question.
Good Answers: 266
06/30/2014 3:19 PM
Since we are to assume then I will assume the same current to be zero. So the will be no temperature rise.
07/01/2014 12:08 AM
Current is not zero. It is close to 3000A.
Good Answers: 266
07/01/2014 7:18 AM
Like pulling teeth.
Don't you think that information would be necessary to give you an answer? It is the load that's causing the heat. Not the size of the panel.
Maybe you should just copy the question verbatim from the text. That way we don't get the information in dribs and drabs.
06/30/2014 4:26 PM
This has to be homework. And my answer seems a reasonable one.
Don't do it!
IF you have to ask, DON'T DO IT!
Nobody alters the design of a power distribution component without knowing what they are doing and the implications of their actions.
<Unsubscribe>
07/01/2014 12:09 AM
What is your problem? If you cant give a decent answer please don't go on a vilification drive.
07/01/2014 12:13 AM
''Could you please tell me in detail of how I can do this calculation??? "
If you don't know how to do the job, why would you ask strangers to do the work for you?
YOU are the problem!
Have a good life.
<un-unsubscribe>
07/01/2014 12:15 AM
Please sir. Enough with this. Please help me. I heard this is a great community to get help regarding ELECTRICAL engineering. Please guide me.
Good Answers: 42
Re: Conductor Length Problem
07/01/2014 2:06 AM
Attached here are ABB recommendations how to calculate temperature rise in a busbar enclosure:
Julius
07/01/2014 1:12 PM
Could you please give me more info on this???
Good Answers: 42
07/01/2014 2:21 PM
See:
http://www.abb-shb.de/index_abb_en_start.html
or:
http://www.scribd.com/doc/23692182/ABB-Switchgear-Manual-11th-Ed-2006
Julius
India - Member - New Member
Good Answers: 164
07/01/2014 5:00 AM
Given that there are so many variations, it is best to make a prototype and test.
Register to Reply 32 comments
7anoter4 (2); Anonymous Poster (3); Codemaster (1); grimranger (9); kvsridhar (1); lyn (4); ozzb (2); PWSlack (1); redfred (5); TonyS (1); truth is not a compromise (3)
