Previous in Forum: Risk Assessment for Design of Lightning Protection System   Next in Forum: Crossing of Plumbing and Electric Services
9 comments
Fault Current Level
07/13/2014 6:14 AM
Hi Guys,I am not a designer.I came to know that prior to design the power system of any building of big power consumption and define the setting values of the earth leakage relays , a specific calculation is required to estimate the Fault Current Level.Is it correct ?If yes , may I get please a simplified methodology for the same ?
Best Regards
Re: Fault Current Level
07/13/2014 10:21 AM
Good Answers: 32
07/14/2014 4:13 AM
Hi lyn:
First Link did not open but the last link looks pretty good. You are very helpful Santa.
07/14/2014 1:11 PM
OOPS,
It's a PDF that must be downloaded.
It just worked fine for me.
Good luck.
Good Answers: 32
07/15/2014 12:35 AM
Hi lyn:
Yes, this time it worked well. In previous attempt, it said server problem. Never mind. We know that computers reboot at time and go in hibernation as well. Information is pretty good.
Good Answers: 42
07/15/2014 6:37 AM
Hi Iyn,
All the links are good and informative .Thanks
07/14/2014 6:30 AM
Do you use a national electrical code where you are?
Do you have an Electrical Designer who knows how to apply it?
Good moaning!
07/14/2014 7:55 AM
Yes for both questionBest Regards
07/14/2014 8:17 AM
As an Electrical Designer is attached to the project, that individual would be the best one to ask.
10/09/2014 3:12 PM
Hi!
I think that it is not always straightforward to calculate the fault currents. You can simplify the calculation in case the power system studying is small and its voltage level under 110kV. On the other hand, when study a HV power system, you should take the advantage of power system software to carry out the calculation. It not only help you save time, but also make you convenient when using it.
In your situation, you want to determine the values of earth leakage currents. Thus, you have to calculate single-line to ground fault currents that are utilized to set protective relays.
To see an example of asymmetrical short-circuit calculation, refer to this link http://www.psa-outline.com/asymmetrical-short-circuit-calculation-simulation/
Notes that: I don't mention the case of low voltage systems.
Register to Reply 9 comments
Anonymous Poster (1); Crabtree (1); lyn (2); mansuralaa47 (1); PWSlack (1); Shyam (2); V.I.Abraham (1)
