Previous in Forum: Transfer of Electrical Energy?   Next in Forum: Shunt Release or Under Voltage Release for Electrical Interlocking
22 comments
T/N/C Switch
07/30/2014 7:20 AM
What is TNC Switch & its function in ACB Panel?
If possible then please explain with the help of SLD.....
Pathfinder Tags: ACB TNC SWITCH
Re: T/N/C Switch
07/30/2014 7:44 AM
OMG WTF
Re: T/N/C Switch
07/30/2014 8:05 AM
Re: T/N/C Switch
07/30/2014 2:32 PM
He said WTF. Look it up.
Good moaning!
Good Answers: 69
Re: T/N/C Switch
07/30/2014 8:30 AM
Read this
Re: T/N/C Switch
07/31/2014 1:45 AM
Already gone through it...
none of them are satisfactory......
Re: T/N/C Switch
07/30/2014 9:15 AM
Do stop using TLAs, Murphy.
Good moaning!
Good Answers: 181
Re: T/N/C Switch
07/30/2014 9:52 AM
I've got to go in to town later, I'll call in at The Nottingham Company and ask.
I get the feeling I'll get blank looks.
Re: T/N/C Switch
07/30/2014 10:44 AM
Thought it was Hand/Off/Auto in another language, but I can't find one that translate to those letters. Still could be as the term Auto and Off may not be what it is considered in, say, French, as technical terms aren't always the direct translation that you would expect.(i.e. - they use a different term than Off for not activated) I've spent many wasted hours trying to comprehend French drawings trying to translate using a standard translation guide. For technical terms, you need a technical translator, and that usually means - call an engineer over there.
Good Answers: 181
Re: T/N/C Switch
07/30/2014 11:33 AM
I worked for a French company. Never seen TNS as a switching option.
Re: T/N/C Switch
07/30/2014 11:41 AM
Okay - so now we need to hear from the Germans, the Spanish, the Italians, the Japanese, the Scandinavian countries,.....
Thank you - we can eliminate that one - I never said it was French - just another language than English.
Re: T/N/C Switch
07/30/2014 2:31 PM
TN-C is a method of providing an Earth connection. Is that what you are talking about?
Good moaning!
Good Answers: 181
Re: T/N/C Switch
07/30/2014 10:20 PM
TN-C Terra Neutral - Combined. AKA CNE/PME
Which you can switch so long as the combined neutral/earth is early make, late break.
It would help if the OP told us the full details.
Can someone tell me what SLD is please?
Good Answers: 11
Re: T/N/C Switch
07/31/2014 2:56 AM
SLD = Single Line Diagram or what I used to call a "schematic".
rogerggbr
Good Answers: 181
Re: T/N/C Switch
07/31/2014 9:04 AM
Ooopps
Re: T/N/C Switch
07/31/2014 2:09 AM
TNC a trip-nutral-close switch. Normally it stays at nutral position and indication of breakers' status is with indication lamps else the switch has to stay in trip/nutral / close positions to indicate. Trip -- switching off the breaker and close - switching ON. In another nomanclature TNC is test nutral and close switch where in T est is a position load is not connected i.e breaker output id open and the functions of the breakers will be avaiable for testing purposes. In close position the breaker will get connected to load sooner it is switched on ( closed). Nutral position the breaker is drawn out and no way connected to power and available for repairs and can coolly be taken out of the cubicle. But mostly these switches are mechanical
THE FIRST COMBINATION IS MOST COMMON.
Let us discuss the practical issues not the classroom.
Re: T/N/C Switch
07/31/2014 3:09 AM
Thx for the clarification.... it helps a lot, can you please post one sample SLD if possible...
Re: T/N/C Switch
07/31/2014 7:10 AM
NOT able to load file. I want to know from someone... which format is allowed here for posting a drawing/ circuit etc.
Re: T/N/C Switch
07/31/2014 7:58 AM
http://www.larsentoubro.com/lntcorporate/uploads/product/C-Power%20Manual.pdf
See page 8-19 for TNS and Sample circuit SLD.
http://www.allinterview.com/showanswers/60633.html
See this for detals of TNC types ( Some one has already refered to this)
http://www.gepowercontrols.com/ex/resources/literature_library/catalogs/industrial_components/downloads/Record_Plus_Catalogue_EN_Export_ed09-11_680860.pdf --- Another manual mentioning TNC and control ckt. Pls go thru for detailing.
Re: T/N/C Switch
07/31/2014 3:41 AM
Isn't there a manual for this panel, Boss?
Good moaning!
Re: T/N/C Switch
07/31/2014 3:55 AM
Not available in manual because we need to integrate it in existing ACB Panel
Re: T/N/C Switch
04/28/2025 4:27 AM
It sounds as though the <...we...> needs the help of a local specialist.
Re: T/N/C Switch
07/31/2014 4:24 AM
It is a 3 position switch. In Trip Position, CB Trips (Energized thru Shunt Coil of CB). In Close Position, CB Closes or can be made ON (Energized thru Closing Coil of CB). In Neutral Position all the operations on AUTO mode or from REMOTE can be done, as per user scheme.
You have normal TNC and TNC with Spring Return. In Spring Return TNC, the switch returns to Neutral Position and hence cannot be locked either on TRIP or CLOSE position (Required to isolate the closing/trip coil which may be short-time rated). Normal TNC can be locked on either TRIP or CLOSE Position.
These switches are also called as Breaker Control Switches.
Register to Reply 22 comments
arpittare (4); Crabtree (4); Jignesh Shah (1); M.R.Iyengar (3); Phys (2); PWSlack (1); rogerggbr (1); SolarEagle (1); TonyS (4); Yahlasit (1)
