Previous in Forum: A Little Energy Puzzle   Next in Forum: Ellipsoidal Dish Seam
10 comments
Pipe ASTM Standard For Pipe And Fitting
08/13/2014 11:52 PM
please provide me ASTM standar for pipe & fitting (technical specification )
Pathfinder Tags: pipe & fitting
Re: Pipe ASTM standar for pipe and fitting
08/14/2014 12:25 AM
Search the ASTM website which can be found with ease by searching for it.
You may not find what you are looking for there, but it will be a good exercise in independence.
08/14/2014 2:57 AM
Please provide credit or debit card number. That standard is copyrighted and available for purchase.
Good Answers: 203
Re: Pipe ASTM Standard For Pipe And Fitting
08/14/2014 10:36 PM
Google: "ASTM pipe and fittings standards"
By the magic of your payment to my PayPal account you will get the following:
ASTM A234 / A234M - 13e1 Standard Specification for ...
www.astm.org/Standards/A234.htm
ASTM InternationalLoading...A234 - 13e1 Standard Specification for Piping Fittings of Wrought Carbon Steel and Alloy Steel for Moderate and High Temperature Service , pipe ...
  • 13a Standard Specification for Cast Iron Soil Pipe and Fittingswww.astm.org/Standards/A74.htm
  • ASTM InternationalLoading...ASTM A74 - 13a. Standard Specification for Cast Iron Soil Pipe and Fittings. Active Standard ASTM A74 | Developed by Subcommittee: A04.12. Book of ...
  • ASTM D3350 - 12e1 Standard Specification for ...www.astm.org/Standards/D3350.htm
  • ASTM InternationalLoading...D3350 - 12e1 Standard Specification for Polyethylene Plastics Pipe and Fittings Materials , cell classification system, pipe and fittings material, polyethylene, ...
  • ASTM International - Standards for Steel Pipes, Tubes and ...www.engineeringtoolbox.com/astm-standards-d_367.html
  • The ASTM standards covers various types of steel pipes, tubes and fittings for high-temperature service, ordinary use and special applications such as fire ...See what the power of money can do! Any succeeding questions will receive a 10% discount. -1% 10 days, Net 30 days if your credit is suitable. Purchase Orders accepted. No wooden nickels!
    Good Luck, Old Salt
Good Answers: 34
08/15/2014 6:47 PM
This questiondoes not make much sense.
Steel Pipes
  • A53 - A53/A53M-99b - Specification for Pipe, Steel, Black and Hot-Dipped, Zinc-Coated, Welded and Seamless
  • A74 - A74-98 - Specification for Cast Iron Soil Pipe and Fittings
  • A106 - A106-99e1 - Specification for Seamless Carbon Steel Pipe for High-Temperature Service
  • A126 - A126-95e1 - Specification for Grey Iron Castings for Valves, Flanges, and Pipe Fittings
  • A134 - A134-96 - Specification for Pipe, Steel, Electric-Fusion (Arc)-Welded (Sizes NPS 16 and Over)
  • A135 - A135-97c - Specification for Electric-Resistance-Welded Steel Pipe
  • A139 - A139-96e1 - Specification for Electric-Fusion (Arc)-Welded Steel Pipe (NPS 4 and Over)
  • A182 - A182/A182M-99 - Specification for Forged or Rolled Alloy-Steel Pipe Flanges, Forged Fittings, and Valves and Parts for High-Temperature Service
  • A252 - A252-98 - Specification for Welded and Seamless Steel Pipe Piles
  • A312 - A312/A312M-00 - Specification for Seamless and Welded Austenitic Stainless Steel Pipes
  • A333 - A333/A333M-99 - Specification for Seamless and Welded Steel Pipe for Low-Temperature Service
  • A335 - A335/A335M-99 - Specification for Seamless Ferritic Alloy-Steel Pipe for High-Temperature Service
  • A338 - A338-84 (1998) - Specification for Malleable Iron Flanges, Pipe Fittings, and Valve Parts for Railroad, Marine, and Other Heavy Duty Service at Temperatures Up to 650�F (345�C)
  • A358 - A358/A358M-98 - Specification for Electric-Fusion-Welded Austenitic Chromium-Nickel Alloy Steel Pipe for High-Temperature Service
  • A369 - A369/A369M-92 - Specification for Carbon and Ferritic Alloy Steel Forged and Bored Pipe for High-Temperature Service
  • A376 - A376/A376M-98 - Specification for Seamless Austenitic Steel Pipe for High-Temperature Central-Station Service
  • A377 - A377-99 - Index of Specifications for Ductile-Iron Pressure Pipe
  • A409 - A409/A409M-95ae1 - Specification for Welded Large Diameter Austenitic Steel Pipe for Corrosive or High-Temperature Service
  • A426 - A426-92 (1997) - Specification for Centrifugally Cast Ferritic Alloy Steel Pipe for High-Temperature Service
  • A451 - A451-93 (1997) - Specification for Centrifugally Cast Austenitic Steel Pipe for High-Temperature Service
  • A523 - A523-96 - Specification for Plain End Seamless and Electric-Resistance-Welded Steel Pipe for High-Pressure Pipe-Type Cable Circuits
  • A524 - A524-96 - Specification for Seamless Carbon Steel Pipe for Atmospheric and Lower Temperatures
  • A530 - A530/A530M-99 - Specification for General Requirements for Specialized Carbon and Alloy Steel Pipe
  • A648 - A648-95e1 - Specification for Steel Wire, Hard Drawn for Pre-stressing Concrete Pipe
  • A674 - A674-95 - Practice for Polyethylene Encasement for Ductile Iron Pipe for Water or Other Liquids
  • A691 - A691-98 - Specification for Carbon and Alloy Steel Pipe, Electric-Fusion-Welded for High-Pressure Service at High Temperatures
  • A694 - A694/A694M-00 - Specification for Carbon and Alloy Steel Forgings for Pipe Flanges, Fittings, Valves, and Parts for High-Pressure Transmission Service
  • A716 - A716-99 - Specification for Ductile Iron Culvert Pipe
  • A733 - A733-99 - Specification for Welded and Seamless Carbon Steel and Austenitic Stainless Steel Pipe Nipples
  • A742 - A742/A742M-98 - Specification for Steel Sheet, Metallic Coated and Polymer Pre-coated for Corrugated Steel Pipe
  • A746 - A746-99 - Specification for Ductile Iron Gravity Sewer Pipe
  • A760 - A760/A760M-99 - Specification for Corrugated Steel Pipe, Metallic-Coated for Sewers and Drains
  • A761 - A761/A761M-98 - Specification for Corrugated Steel Structural Plate, Zinc-Coated, for Field-Bolted Pipe, Pipe-Arches, and Arches
  • A762 - A762/A762M-98 - Specification for Corrugated Steel Pipe, Polymer Pre-coated for Sewers and Drains
  • A790 - A790/A790M-99 - Specification for Seamless and Welded Ferritic/Austenitic Stainless Steel Pipe
  • A796 - A796/A796M-99 - Practice for Structural Design of Corrugated Steel Pipe, Pipe-Arches, and Arches for Storm and Sanitary Sewers and Other Buried Applications
  • A798 - A798/A798M-97a - Practice for Installing Factory-Made Corrugated Steel Pipe for Sewers and Other Applications
  • A807 - A807/A807M-97 - Practice for Installing Corrugated Steel Structural Plate Pipe for Sewers and Other Applications
  • A810 - A810-94 - Specification for Zinc-Coated (Galvanized) Steel Pipe Winding Mesh
  • A813 - A813/A813M-95e2 - Specification for Single- or Double-Welded Austenitic Stainless Steel Pipe
  • A814 - A814/A814M-96 (1998) - Specification for Cold-Worked Welded Austenitic Stainless Steel Pipe
  • A849 - A849-99 - Specification for Post-Applied Coatings, Pavings, and Linings for Corrugated Steel Sewer and Drainage Pipe
  • A861 - A861-94e1 - Specification for High-Silicon Iron Pipe and Fittings
  • A862 - A862/A862M-98 - Practice for Application of Asphalt Coatings to Corrugated Steel Sewer and Drainage Pipe
  • A865 - A865-97 - Specification for Threaded Couplings, Steel, Black or Zinc-Coated (Galvanized) Welded or Seamless, for Use in Steel Pipe Joints
  • A872 - A872-91 (1997) - Specification for Centrifugally Cast Ferritic/Austenitic Stainless Steel Pipe for Corrosive Environments
  • A885 - A885/A885M-96 - Specification for Steel Sheet, Zinc and Aramid Fiber Composite Coated for Corrugated Steel Sewer, Culvert, and Underdrain Pipe
  • A888 - A888-98e1 - Specification for Hubless Cast Iron Soil Pipe and Fittings for Sanitary and Storm Drain, Waste, and Vent Piping Applications
  • A926 - A926-97 - Test Method for Comparing the Abrasion Resistance of Coating Materials for Corrugated Metal Pipe
  • A928 - A928/A928M-98 - Specification for Ferritic/Austenitic (Duplex) Stainless Steel Pipe Electric Fusion Welded with Addition of Filler Metal
  • A929 - A929/A929M-97 - Specification for Steel Sheet, Metallic-Coated by the Hot-Dip Process for Corrugated Steel Pipe
  • A930 - A930-99 - Practice for Life-Cycle Cost Analysis of Corrugated Metal Pipe Used for Culverts, Storm Sewers, and Other Buried Conduits
  • A943 - A943/A943M-95e1 - Specification for Spray-Formed Seamless Austenitic Stainless Steel Pipes
  • A949 - A949/A949M-95e1 - Specification for Spray-Formed Seamless Ferritic/Austenitic Stainless Steel Pipe
  • A954 - A954-96 - Specification for Austenitic Chromium-Nickel-Silicon Alloy Steel Seamless and Welded Pipe
  • A972 - A972/A972M-99 - Specification for Fusion Bonded Epoxy-Coated Pipe Piles
  • A978 - A978/A978M-97 - Specification for Composite Ribbed Steel Pipe, Precoated and Polyethylene Lined for Gravity Flow Sanitary Sewers, Storm Sewers, and Other Special Applications
  • A984 - A984/A984M-00 - Specification for Steel Line Pipe, Black, Plain-End, Electric-Resistance-Welded
  • A998 - A998/A998M-98 - Practice for Structural Design of Reinforcements for Fittings in Factory-Made Corrugated Steel Pipe for Sewers and Other Applications
  • A999 - A999/A999M-98 - Specification for General Requirements for Alloy and Stainless Steel Pipe
  • A1005 - A1005/A1005M-00 - Specification for Steel Line Pipe, Black, Plain End, Longitudinal and Helical Seam, Double Submerged-Arc Welded
  • A1006 - A1006/A1006M-00 - Specification for Steel Line Pipe, Black, Plain End, Laser Beam Welded
Steel Tubes
Superheater, Boiler and Miscellaneous Tubes:
  • A178 - A178/A178M-95 - Specification for Electric-Resistance-Welded Carbon Steel and Carbon-Manganese Steel Boiler and Superheater Tubes
  • A179 - A179/A179M-90a (1996) e1 - Specification for Seamless Cold-Drawn Low-Carbon Steel Heat-Exchanger and Condenser Tubes
  • A192 - A192/A192M-91 (1996) e1 - Specification for Seamless Carbon Steel Boiler Tubes for High-Pressure Service
  • A209 - A209/A209M-98 - Specification for Seamless Carbon-Molybdenum Alloy-Steel Boiler and Superheater Tubes
  • A210 - A210/A210M-96 - Specification for Seamless Medium-Carbon Steel Boiler and Superheater Tubes
  • A213 - A213/A213M-99a - Specification for Seamless Ferritic and Austenitic Alloy-Steel Boiler, Superheater, and Heat-Exchanger Tubes
  • A249 - A249/A249M-98e1 - Specification for Welded Austenitic Steel Boiler, Superheater, Heat-Exchanger, and Condenser Tubes
  • A250 - A250/A250M-95 - Specification for Electric-Resistance-Welded Ferritic Alloy-Steel Boiler and Superheater Tubes
  • A254 - A254-97 - Specification for Copper-Brazed Steel Tubing
  • A268 - A268/A268M-96 - Specification for Seamless and Welded Ferritic and Martensitic Stainless Steel Tubing for General Service
  • A269 - A269-98 - Specification for Seamless and Welded Austenitic Stainless Steel Tubing for General Service
  • A270 - A270-98ae1 - Specification for Seamless and Welded Austenitic Stainless Steel Sanitary Tubing
  • A334 - A334/A334M-99 - Specification for Seamless and Welded Carbon and Alloy-Steel Tubes for Low-Temperature Service
  • A423 - A423/A423M-95 - Specification for Seamless and Electric-Welded Low-Alloy Steel Tubes
  • A450 - A450/A450M-96a - Specification for General Requirements for Carbon, Ferritic Alloy, and Austenitic Alloy Steel Tubes
  • A608 - A608-91a (1998) - Specification for Centrifugally Cast Iron-Chromium-Nickel High-Alloy Tubing for Pressure Application at High Temperatures
  • A618 - A618-99 - Specification for Hot-Formed Welded and Seamless High-Strength Low-Alloy Structural Tubing
  • A632 - A632-98 - Specification for Seamless and Welded Austenitic Stainless Steel Tubing (Small-Diameter) for General Service
  • A688 - A688/A688M-98 - Specification for Welded Austenitic Stainless Steel Feedwater Heater Tubes
  • A771 - A771/A771M-95 - Specification for Seamless Austenitic and Martensitic Stainless Steel Tubing for Liquid Metal-Cooled Reactor Core Components
  • A778 - A778-98 - Specification for Welded, Unanneled Austenitic Stainless Steel Tubular Products
  • A789 - A789/A789M-00 - Specification for Seamless and Welded Ferritic/Austenitic Stainless Steel Tubing for General Service
  • A803 - A803/A803M-98 - Specification for Welded Ferritic Stainless Steel Feedwater Heater Tubes
  • A822 - A822-90 (1995) e1 - Specification for Seamless Cold-Drawn Carbon Steel Tubing for Hydraulic System Service
  • A826 - A826/A826M-95 - Specification for Seamless Austenitic and Martensitic Stainless Steel Duct Tubes for Liquid Metal-Cooled Reactor Core Components
  • A847 - A847-99a - Specification for Cold-Formed Welded and Seamless High Strength, Low Alloy Structural Tubing with Improved Atmospheric Corrosion Resistance
  • A908 - A908-91 (1998) - Specification for Stainless Steel Needle Tubing
  • A953 - A953-96 - Specification for Austenitic Chromium-Nickel-Silicon Alloy Steel Seamless and Welded Tubing -
  • A214 - A214/A214M-96 - Specification for Electric-Resistance-Welded Carbon Steel Heat-Exchanger and Condenser Tubes
  • A498 - A498-98 - Specification for Seamless and Welded Carbon, Ferritic, and Austenitic Alloy Steel Heat-Exchanger Tubes with Integral Fins
  • A851 - A851-96 - Specification for High-Frequency Induction Welded, Unannealed, Austenitic Steel Condenser Tubes -
Structural Tubing
  • A500 - A500-99 - Specification for Cold-Formed Welded and Seamless Carbon Steel Structural Tubing in Rounds and Shapes
  • A501 - A501-99 - Specification for Hot-Formed Welded and Seamless Carbon Steel Structural Tubing
  • A618 - A618-99 - Specification for Hot-Formed Welded and Seamless High-Strength Low-Alloy Structural Tubing -
Mechanical Tubing
  • A511 - A511-96 - Specification for Seamless Stainless Steel Mechanical Tubing
  • A512 - A512-96 - Specification for Cold-Drawn Buttweld Carbon Steel Mechanical Tubing
  • A513 - A513-98 - Specification for Electric-Resistance-Welded Carbon and Alloy Steel Mechanical Tubing
  • A519 - A519-96 - Specification for Seamless Carbon and Alloy Steel Mechanical Tubing
  • A554 - A554-98e1 - Specification for Welded Stainless Steel Mechanical Tubing -
Welded Fittings
  • A234 - A234/A234M-99 - Specification for Piping Fittings of Wrought Carbon Steel and Alloy Steel for Moderate and High Temperature Service
  • A403 - A403/A403M-99a - Specification for Wrought Austenitic Stainless Steel Piping Fittings
  • A420 - A420/A420M-99 - Specification for Piping Fittings of Wrought Carbon Steel and Alloy Steel for Low-Temperature Service
  • A758 - A758/A758M-98 - Specification for Wrought-Carbon Steel Butt-Welding Piping Fittings with Improved Notch Toughness
  • A774 - A774/A774M-98 - Specification for As-Welded Wrought Austenitic Stainless Steel Fittings for General Corrosive Service at Low and Moderate Temperatures -
Good Answers: 203
08/15/2014 8:33 PM
I sure hope you used "copy" and "paste" on that answer!
Good Luck, Old Salt
Good Answers: 34
08/15/2014 8:52 PM
Yes, off course
01/15/2018 12:13 AM
Thanks for sharing these details.
Regards,
Siddhagiri Metals and Tubes
Address:
25 C Sonarika Apartment, Chandawadi, Nanubhai Desai Road, C.P.Tank,Mumbai
website: http://www.siddhagiri.net
Location: Shop No 12, Bhabha Chawl, Ground Floor, Near H.N. Reliance Hospital,Khetwadi 13th Lane, Mumbai - 400004, Maharashtra, .
06/16/2017 4:12 AM
please check www.bhansalioverseas.com for all ASTM & ASME grades of stainless steel pipe & Fittings
Bhansali Overseas
11/08/2018 1:09 AM
there are many astm standards. many of them are available in seamless form and many are in welded form.
check this website for all astm standards - www.sa179tubes.com
it contains all astm standards like SA 179, SA 214, SA 178, etc. and other information like its sizes available, chemical composition and other properties.
02/12/2019 6:20 AM
Hey NOCIL, Thank you for your informative question on ASTM standatds. You can find the ASTM standards for both ferrous & non-ferrous pipes and pipe fittings with their technical data and also pictures over here:
Alloy Steel & Carbon Steel
HIGH NICKEL ALLOYS
Hastelloy
Stainless Steel
Register to Reply 10 comments
deepak sheth (1); highnickelalloys (1); lyn (1); old salt (2); rakeshbhansali (1); siddhagiri (1); Tornado (1); Whitephone (2)
