Previous in Forum: Seizing (Binding) of Stainless Steel   Next in Forum: PLC Millivolt Input Standards
Cleaning Work Marks from Welded Aluminum Structures
08/18/2014 1:03 PM
<Update for any who know me...my time at the power plant is over : ( and now I am working as a designer / fabricator at a maintenance platform fabrication shop.>
We do a lot of work in aluminum and my welder asked me if I knew any tricks for cleaning up hand-prints and smudge marks on the assemblies we are making.
Any suggestions?
Drew K
Re: Cleaning Work Marks from Welded Aluminum Structures
08/18/2014 1:30 PM
So, your answer was no?
If isopropyl alcohol doesn't work, I'd try one of those Mr. Clean Magic Erasers.
08/18/2014 1:33 PM
08/18/2014 4:31 PM
Finger fat; IPA, hot water/soap.
Grease smudges; MEK or toluene. Spray brake cleaner in a pinch. (TCE)
Mechanical abrasions; Scotch Brite® steel wool.
Also, facial oil. Rub the side of your nose, then rub the mark. Try it before you laugh!
Good Answers: 145
08/18/2014 5:06 PM
I don't have any idea of the scale and flatness of what you are doing so this might not apply. At a previous job we would use soft scrub, scotch brite, elbow grease and hot water between fab and finish. Once you figured out how to have a consistent pattern in your scrub marks it worked very well.
08/19/2014 3:25 AM
Clean gloves while working and wipe down with WD-40 prevents corrosion in the future...
A hand print will "etch" the shiny surface quite quickly otherwise...I cannot say in what time frame exactly, probably a few days (guessing!) at least. I would guess its the salt content in sweat, but that is not a fact, you understand....Shiny/clean Aluminium is sensitive to corrosion...
The only good point that surface corrosion has on it is that it protects aluminium from further corrosion I am told...
We kept RN Fleet Air Arm choppers clean and free from corrosion in the 50s-60s-and-70s with WD-40 (maybe even today for all I know!), as they had aluminium and magnesium parts....salt water could seriously damage them if not treated correctly with WD-40....or whatever they use today....
08/19/2014 10:12 AM
We will try the WD-40, we want to avoid taking the time to actually scrubbing these things clean so SoftScrub is a last resort.
Surface is kinda shiny so it does etch with fingerprints and with the heat and humidity here salty sweat is a constant.
Will have to look into pontoon boat cleaner to see if we can get it here, like the spray on / spray off feature.
Not sure about picking the nose part...oh, wait...side of nose...aha...outside side, not inside side...will have to try that at least once ; )
Drew K
Register to Reply 6 comments
Andy Germany (1); BruceFlorida (1); Drew K (1); lyn (1); SolarEagle (1); Usbport (1)
