Previous in Forum: Hydrotest Pressure   Next in Forum: Chlorine & Hydrogen Psychrometric or Mollier Chart
20 comments
Is This A Normal Level Of Sound When Gently Releasing The Brake Pedal?
08/27/2014 8:40 AM
My wife just mentioned to me that she thinks her brakes make an abnormal amount of sound when you slowly release the brake pedal, either in reverse or drive.
I followed her out and took a quick video of her leaving in the garage.
It does seem to make a grinding/clicking type noise when she slowly lets off of the brakes. So when she's backing out of the garage or a parking spot or even inching forward in traffic it seems to make this noise. I know a certain amount of this kind of sound is "normal" to an extent... but does this seem excessive?
The best capture of the sound is right at the very beginning of the video below. The subsequent sounds of her stopping are NOT as bad as it usually sounds for her.
BR//
MRO Supply
Re: Is this a normal level of sound when gently releasing the brake pedal?
08/27/2014 8:57 AM
post vid to YouTube then a link to that page here
Re: Is This A Normal Level Of Sound When Gently Releasing The Brake Pedal?
08/27/2014 9:37 AM
"My wife just mentioned to me that she thinks her brakes make an abnormal amount of sound..." That pretty much says it all.
In my humble opinion, it matters not what we might think. You don't live with us.
Do yourself a big favor and take it to a shop. Don't delay, don't complain, don't rationalize, don't ask for opinions; putting forward an impression that you also think the brakes make a funny sound would be good.
Besides, there may actually be something wrong with the brakes.
Is this your old Subaru? It's scheduled to be replaced soon, is it not?
08/27/2014 9:59 AM
this might be a good idea...
08/27/2014 10:04 AM
Internet auction sites (names withheld) are great for solving problems like this. One simply lists the vehicle with a photograph or two, and in a few days' time someone shows up with some money, swaps it for the vehicle, and takes the problem away.
Good Answers: 97
08/27/2014 10:26 AM
This transaction should take place at a remote location.
CRTL-Z
08/27/2014 10:38 AM
Location wouldn't matter in the UK, as the registered keeper of the vehicle is presented on the registration document V5C, which the parties fill in and send off to register the new keeper as part of the transaction. The owner can be either a person, a group of persons or a corporate body such as a limited company; the keeper must be an individual and it is the keeper who is liable for the upkeep of the vehicle.
Good Answers: 97
08/27/2014 10:51 AM
PW,
My reply, an attempt at levity, was meant to imply possible damage to structures in the vicinity of the vehicle due to possible lack of the ability to arrest forward motion caused by insufficient friction to the rotating wheel assemblies by the new keeper which is a possibility indicated.
I shall now return to my day job..
CRTL-Z
08/27/2014 10:24 AM
Crystal ball says may be metal-to-metal grinding.
Have brakes checked.
Good Answers: 97
08/27/2014 11:09 AM
A dairy farmer from Wisconsin purchased a dairy cow for a very good price. A neighbor stopped by and remarked on the good deal the farmer got. The farmer thanked him, explaining the one negative element of the deal by asking the neighbor to 'try milking her". The neighbor did and noticed the cow passed wind with every tug.
The neighbor turned and asked "Did you get this cow from Minnesota?" The farmer replied "Why yes I did, how did you know?" The neighbor replied "My wife is from Minnesota".
Sound can be a good indicator of a possible problem.
CRTL-Z
08/27/2014 11:17 AM
My X-wife is from Minnesota.
Good Answers: 97
08/27/2014 11:26 AM
Hi Lyn,
UH, do you know what the "normal level of sound" would be for that phenomena? In case It happens to me.
CRTL-Z
08/27/2014 12:05 PM
They're silent.
Good Answers: 266
08/27/2014 4:25 PM
Have the wheel bearings checked also. Grinding may not be the brakes. But get to a shop and have them check both out.
Good Answers: 94
08/28/2014 4:27 AM
Someone mentioned that the vehicle might be a Subaru. I have a Forester & on that the brake pad wear indicator is a thin metal finger which is intended to rub on the brake disc & make a noise to tell you the pads need replacing.
08/28/2014 6:14 AM
Older Mitsubishis use the same method. My 1989 Mitsubishi "bus" had that, cheap, cheerful and effective....
The first time you hear it you RALLY think something is REALLY broken.
Mine "activated" when there was still more than 50% of brake material untouched, so I bent them back slightly to allow a quiet drive for a few thousand Kms further...till I had time to replace them.....
08/28/2014 11:05 AM
V-dub (Bosch) uses an interesting concept where they embed a small loop of wire into the pad and when the pad wears down and the wire connection is broken, the dummy light on the instrument panel lights up.
I remember my old '75 Rabbit had a 'thumper' block on each rotor that would contact the pad and cause the pedal to pulse when the pads were worn down.
Good Answers: 94
08/28/2014 11:18 AM
Had that embedded wire version on a V8 Rover but still managed to have a brake pad shoot out when I tried to stop because it had worn thin enough to slip through the gap.
08/28/2014 11:44 AM
Really. How dangerous as you basically lose hydraulic pressure when that happens. Very Dangerous....
I think all the disk brakes over the years that I have had, always had two around 6mm pins that would prevent either of the metal parts of the pads flying out......unless they broke or were removed, which never happened.....
Good Answers: 97
08/28/2014 12:01 PM
The Cushman motor scooter and I suppose other bikes with a rod linking the rear drum brake to the pedal, had a very innovative method for letting you know when the brake plate anchor bolt had sheared. This condition would allow the plate to rotate causing the full-on application of the rear brake, a just barely controlled slide through an intersection and a "High Side" or "Flying W" to use flat track vernacular.
CRTL-Z
Good Answers: 94
08/28/2014 6:16 PM
Indeed..... Luckily I was only about 1/2 mile from home at the time & got home gently just using the hand brake.
Register to Reply 20 comments
Andy Germany (2); Brave Sir Robin (1); Doorman (1); Fredski (2); lyn (3); Nigh (3); ozzb (1); PWSlack (2); Unredundant (5)
