Previous in Forum: Restriction Orifice Plate   Next in Forum: Control Valve Power Up
12 comments
Joint for LHS (Linear Heat Sensor) Cable
09/03/2014 1:32 AM
Good morning everybody ...I want to ask you about LHS Cable (Linear Heat Sensor) .. We are using it to detect any possible fire at the floating roof of our CRUDE OIL TANK. Now I have a problem that the (Cooper cable) thats connect LHS to junction box was damaged and I want to make a joint for it. my question is:Is it possible to make a traditional joint using my hands only or I need a certified connector to do this joint ?
Pathfinder Tags: LHS
Re: Joint for LHS (Linear Heat Sensor) Cable
09/03/2014 1:55 AM
I would twist-splice and solder each conductor and sleeve it with heat-shrink tubing; then sleeve the whole assembly with larger heat-shrink tubing. At an opportune time, it would be good to replace the whole cable.
09/03/2014 2:47 AM
Many thanks for your great suggestion but in the data sheet it is forbidden to use heat shrink one ! is it possible to do it normally just connect to wires together and cover it with normal tape ! or it is not possible due to hazardous area ?
09/03/2014 1:56 AM
Tell me about the hazardous area classification, Murphy. Which zone is it in, and what are the explosion protection arrangements for the circuit?
Good moaning!
09/03/2014 2:39 AM
It is zone 0, very hazardous area due to H2S high concentration availability !
09/03/2014 2:42 AM
Well that makes it an Ex ia circuit. Yes?
Good moaning!
09/03/2014 2:48 AM
Yes exactly !
09/03/2014 2:59 AM
No problem joining the cable with a temporary splice, then, though as Tornado pointed out above, it would be good to replace the cable at an early opportunity. It's wonderful what barriers can do for you.
Hurrah for Ex i!
Good moaning!
09/03/2014 3:09 AM
* You are right ! it is great to change the cable but unfortunately we dont have spare one !
* I am using I.S Barrier right now and I am afraid if I do normal splice and the weather in my area is very hot and temperature is about 50C, the normal splice may get hot and I have high H2S gas concentration !!!
Are you sure I can do the normal splice ?!
MANY THANKS for your support.
09/03/2014 4:35 AM
The splice cannot get significantly hotter from the current flowing in the circuit, Murphy, as it is limited by the barrier.
Good moaning!
09/03/2014 8:05 AM
Because of this improperly delayed information, I am marking my first post off-topic.
Good Answers: 125
09/03/2014 8:32 AM
LHS is a trade name, but is used often in a generic sense.
Is your line heat sensor cable of the integrating type or the shorting type?
This question cannot be answered without this information.
09/03/2014 11:06 AM
Do grab yourself some training in hazardous area electrical practice, Matey.
Good moaning!
Register to Reply 12 comments
Crabtree (5); M.ABBAS (4); Tornado (2); WJMFIRE (1)
