Previous in Forum: Ballast Used in Locomotives   Next in Forum: Voltage Drop Using Cables in Parallel
25 comments
How to Reduce Ground to Neutral Voltage
09/07/2014 7:51 AM
I want to know how can we reduce ground to neutral voltage. Suggest all possible ways, please
Re: how to reduce ground to neutral voltage
09/07/2014 8:35 AM
A small wire, a medium wire, or a big wire.
09/07/2014 8:42 AM
By knowing all [intended and unintended] conductors and insulators, then apply approved electrical engineering protocols.
Next on "How To Do It", we show how to play the flute.
Anonymous Poster #3
09/08/2014 12:56 AM
09/07/2014 10:01 AM
De-energize all the devices! No current, no leakage.
Now, go get your flute and be ready for the next lesson.
Good Answers: 11
09/07/2014 10:49 AM
Ground all lines with the use of these
Good Answers: 44
09/07/2014 1:14 PM
Is this polyphase?
Simple checks/fixes for common-mode voltage:
Bonding
Reduce harmonics
Balance your loads
Check your X0's
Reduce branch lengths
Eliminate induced voltage
Edit: Shielding
09/07/2014 4:21 PM
Get the OP to mail his homework direct to you.
Read the CR4 rules.
Good Answers: 44
09/08/2014 1:08 AM
Yah, prolly so. I just want to see good discussions...
It's one of my favorite topics.
Good Answers: 67
09/07/2014 4:46 PM
"Suggest all possible ways, please"
Way #137: Bond Neutral to Ground at point of measurement, then take reading.
Anonymous Poster #2
09/07/2014 4:53 PM
What is Bond?
Good Answers: 67
09/07/2014 5:05 PM
Who is Anonymous Poster #1?
Anonymous Poster #2
09/07/2014 5:25 PM
I don't know.
Oh, DRAT! Now I've done it.
09/07/2014 10:01 PM
So who are you then?
What is Bond?
Bond, James Bond!
Don't you know?
Good Answers: 25
09/07/2014 11:02 PM
Also a musical group comprised of "hot" ladies.
Good Answers: 122
09/08/2014 9:49 AM
jaMES bOND AGENT 007?
Good Answers: 12
09/15/2014 10:02 PM
Bond!!! James Bond!!! 007
Good Answers: 25
09/07/2014 11:05 PM
That's what I would try to get away with...
...uhh...
...I mean, "That's what I would do!"
Re: How to Reduce Ground to Neutral Voltage
09/08/2014 3:04 AM
Effective method No 1: is to open the incoming breaker, lock it out and go home and put your feet up.
Effective Method No 2: disconnect all neutrals.
Effective Method No 3: See No 1 above.
These are all suggested possible ways and work on all systems.
09/08/2014 4:57 AM
What is your elevation above ground?
Are you in a balloon,a cell phone tower,a boat, a plane, a space station, a lunar lander,or a Mars explorer?
Will the measurement be taken during a solar eclipse,a lunar eclipse, or during a waning or waxing Gibbus?
During a Coronal Mass Ejection?
If so, of what magnitude is the ejection?( 100 to 800 picometre X-rays near Earth, as measured on the GOES spacecraft)?
At what frequency?
A good ground for 60 hz is not a good ground for RF, likewise for DC.
Are you speaking of an Earth Ground, or a circuit ground, possibly isolated from Earth Ground?
Or ground beef?
Or did you means grounds,as in coffee grounds?
If so, there are more possibilities.
To give all possible methods, I need all possible conditions.
I have listed only a few here, so get back with me when you have all the relevant information.
09/08/2014 5:36 AM
Our sarcasm knows no bounds.
Good Answers: 11
09/25/2014 6:00 AM
hilarious stuff right here.lol
Your sarcasm knows no "ground"
09/08/2014 5:44 AM
  1. Reduce the current in the neutral.
  2. Reduce the earth loop impedance.
  3. Disconnect supply power.
  4. Disconnect the neutral.
  5. Disconnect the ground.
  6. Some combination of any of the above.
09/12/2014 5:37 AM
The neutral and ground should be connected.
You can do this at the in coming terminal. If the utility company gives a 4 wire supply
one wire would be the neutral. You should make a good "ground" terminal and inter connect the neutral and ground.
This should be done at both ends, i.e. at the meter end and also at the machine terminals.
This also protects the equipment in case of a neutral wire break.
MAJMUDAR
Good Answers: 44
09/12/2014 2:31 PM
Bond the neutral and ground at the service and at the equipment?
Where do you think that will lead?
If that's not what you meant, you need to separate you sentences in your advice...a little disambiguation, though that looks like what you meant. Not safe.
09/16/2014 6:04 AM
I stand by what I wrote.
The neutral wire in case of a 4- wire supply system should be grounded.
This is best done with a "ground" at the input end of the supply.
At 'point of use' grounding the neutral would be a good precaution as this reduces the neutral to ground voltage.
Many electronic circuits have a capacitor between =ve. and neutral to reduce "noise"
a grounded neutral helps.
MAJMUDAR
Register to Reply 25 comments
Anonymous Poster (4); cuba_pete (3); Ed Watts (2); europium mkII (2); HiTekRedNek (1); IdeaSmith (1); IQ (2); lyn (1); majmudar (2); Noudge79 (2); PWSlack (1); redfred (1); Sciesis2 (1); SHOCKHISCAN (1); Tornado (1)
