Previous in Forum: File Sharing   Next in Forum: Flange Face Finish and Gasket Type
Maximum / Minimum Hardness For Ring Gaskets
09/09/2014 5:38 AM
As per ASME 16.20 Metallic Gasket for Pipe Flanges Maximum Brinell Hardness for SS316 is 160. ( Refer Table 1). Is there any minimum requirement also? Can we use gasket having Maximum Brinell Hardness 135. Please suggest.
Good Answers: 34
Re: MAXIMUM/MINIMUM HARDNESS FOR RING GASKKETS
09/09/2014 6:24 AM
I do not think 316 ss material may come to have 135 Brinell hardness. the lowest I've seen have been 153 Brinell.
And yes, if you found 316 ss metallic gasket with a hardness of 135 Brinell you can use it according to ASME 16.20 . However, I think there is a mistake somewhere. Error in the certificate, or the calibration of your hardness machine, or to the measuring method. (Are you using EQUOTIP?).
It is recommended that ring-joint gaskets be of a lesser
hardness than that of the mating flanges.
2.3.2 Hardness. Ring-joint gaskets of materials
listed in Table I shall have a hardness equal to or
less than that shown in Table I .
WP
09/09/2014 6:26 AM
It depends upon the relationship between the flange hardness and the gasket hardness:
  • If the gasket were harder than the flange, the flange would distort into the gasket when the bolts are flogged-up and not the other way round.
  • If that is unacceptable then use a softer gasket instead.
Only the <...we...> can determine the correct approach from the standards and guidelines to hand.
Register to Reply 2 comments
