Previous in Forum: How to Measure the Total Static Pressure of AHU   Next in Forum: Can Anyone Help On Electric Over-Head Crane Pendant Cable Wiring Diagram
Small Shrouded Wind Turbine
09/12/2014 8:18 AM
I am searching a wind turbine with shroud(nozzle-diffuser combination) of about 1KW capacity. I have completed my search on shroud and now I am searching for blades. I want 5 or 10 number of blades. Discuss with me the effect of number of blades on wind turbine. I have selected 2 meter length of blades(it can be changed from 2m ). I have also designed the generator of 24 poles. When it rotates at 120 RPM the capacity of this generator will be near about 1KW. The air speed is 4m/s in my area.
Re: Small shrouded wind turbine
09/12/2014 8:21 AM
Internet search engines are an ideal tool to use to find these things.
09/12/2014 10:23 AM
Sir I have visited the practical field of shrouded wind turbine like windlens and ogin companies. These turbines are working well.
09/12/2014 10:26 AM
From the CR4 Rules: Do not post phone numbers or email addresses. The CR4 Admin will delete all phone numbers and email addresses posted in threads or comments. You can share this information via the CR4 internal messaging system.
Good Answers: 97
Re: Small Shrouded Wind Turbine
09/12/2014 5:30 PM
This guy has a turban, maybe you could ask him?
No, Really, Google "Marine Wind Turbines", they have been using them for years.
CRTL-Z
09/12/2014 9:15 PM
I'd try this research:
https://www.google.com/#q=wind+turbine+shroud+design+blade+numbers
There is a number of theoretical papers coming up which might be of interest.
Good luck!
09/12/2014 9:28 PM
To design from scratch is extremely complicated....best to find a design that meets your specifications and copy or buy it....and make sure to oversize it...
http://en.wikipedia.org/wiki/Wind_turbine_design
....as an example....
http://www.amazon.com/PowerMax-Wind-Generators-Discontinued-Manufacturer/dp/B001DY41A2
Register to Reply 6 comments
IdeaSmith (1); Muhammad Fayaz (2); PWSlack (1); SolarEagle (1); Unredundant (1)
