Previous in Forum: Micom P143 Check Synch Feature   Next in Forum: Circuit Breaker
14 comments
Alternator Voltage Regulation
09/18/2014 12:56 AM
Hi,
Voltage regulation (max) in static conditions is specified for an alternator. What does the static conditions actually mean?
Regards,
sks
Good Answers: 181
Re: alternator voltage regulation
09/18/2014 1:22 AM
What does the next page in the text book say about it?
09/18/2014 2:25 AM
sorry, could not find in book. Appears generator with no moving parts.....
sks
09/18/2014 4:36 AM
09/18/2014 2:48 AM
What does "voltage regulation" actually mean?
09/18/2014 2:52 AM
What does "regulation" actually mean?
What does "voltage" actually mean?
Good moaning!
09/18/2014 3:11 AM
voltage regulation is the ratio of change in voltage from no load to full load expressed as a percentage of full load (for max regulation)...
09/19/2014 3:59 AM
....but NOT regulating!! Static.
This is a built in design feature of some specific physical dimensions of the stator and rotor.
In my time, a 45% droop was generally used. That is from no load to full load, with no regulation, the output voltage would drop (droop) 45% from its norm.
The droop must be tailored to the requirements of the regulator. It could even be set up to stay at the same voltage, theoretically then no regulation required, but I have never ever seen one so designed....but it is possible, but feeding a short would be really dangerous under such conditions....
The droop is basically a safety feature to prevent overloading the prime mover....as a good regulator will stop adding more "excitement" once full load is reached.
Usually plus a small amount of "allowed" overload....
My infos are probably not bang up to date in some detail, but hopefully will give you an idea or two....
09/19/2014 3:05 PM
Wiki says: voltage regulation is a measure of change in the voltage magnitude between the sending and receiving end of a component, such as a transmission or distribution line.
My God Man! can't you even search?
Good Answers: 445
Re: Alternator Voltage Regulation
09/18/2014 9:16 AM
Static means steady state, unchanging, non-dynamic, etc.
09/18/2014 3:54 PM
Static conditions means you are not changing the load or the adjustment of the voltage regulator.
India - Member - New Member Engineering Fields - Electrical Engineering - New Member Technical Fields - Technical Writing - New Member
09/18/2014 11:36 PM
In case of Gensets (Engine + Alternators), static condition is the condition when Load, Voltage, Speed of the engine is not changed. if any of these changes then voltage regulation of the alternator may change.
The other condition is known as Transient Condition... where load conditions changes affecting Speed of the prime Mover and hence the Committed Voltage regulation would be out of question. In these cases of Transient Conditions, The Voltage behaviour (Voltage dip and Voltage Rise) with the recovery time needs to be studied.
Regards,
Vishram LELE
Good Answers: 137
09/19/2014 10:22 AM
But if OP's definition in #5 is correct (as far as I'm aware it is) it refers to load change from zero to maximum.
09/19/2014 11:25 AM
I find it open to misinterpretation....Post #5 that is....
Good Answers: 137
09/19/2014 1:02 PM
I'd have thought #5 should say regulation = volt drop/no-load volts, not volt drop/full-load volts, but either way the load is increased from zero to max.
Register to Reply 14 comments
Andy Germany (2); Codemaster (2); Crabtree (1); IdeaSmith (1); lyn (2); RAMConsult (1); Rixter (1); sauravbabu (2); TonyS (1); vishram lele (1)
