Previous in Forum: Why is My Bike Battery Losing Capacity? Challenge Question.   Next in Forum: Effects of Bad Buried Electrical Lines on My Home
11 comments
Multiplying Factor for Calculating Energy
10/02/2014 6:41 AM
I want to calculate meter MF.. Line CT ratio =800:1, Meter CT ratio = 1600:1, PT ratio = 132,000:110.. Previously Line CT ratio was same as Meter CT ratio and Meter MF was 1 by changing the CT ratio now what effect will it make on MF.?
Re: Multiplying factor for calculating energy
10/02/2014 9:03 AM
Once you have a drawing of what you are trying to do, the rest is arithmetic.
Good moaning!
Good Answers: 145
Re: Multiplying Factor for Calculating Energy
10/02/2014 10:05 AM
We used to have an abbreviation for undefined acronyms and abbreviations. Where is that old posting when you need it?
After reading the posting 3 times I suspect you are asking about the turns ratio in a transformer for an electrical power meter. Is that correct?
Anonymous Poster #2
10/02/2014 10:20 AM
MF = MotherF%&£@
10/03/2014 8:15 AM
See post #7 - that first word is spelled correctly there when used in this context.
10/02/2014 10:31 AM
"We used to have an abbreviation for undefined acronyms and abbreviations. Where is that old posting when you need it?"
Are you thinking of undefined TLA's?
Those are three letter acronyms... or two letter acronyms... or ten letter acronyms...
10/02/2014 11:51 AM
BA - Biletter acronym
TLA - Three letter acronym
FFLA - Fuqin Four Letter Acronym
MFFLA - Mutha Fuqin Five Letter Acronym
WNGSLA - Worthless No Good Six Letter Acronym
SOABSLA - Son of a Beach Seven Letter Acronym
10/02/2014 10:30 PM
Or 12-letter anagrams like WANGLYDIAPLT?
Anonymous Poster #2
10/03/2014 9:34 AM
WAGLYDIANPLT!
10/02/2014 10:21 AM
"by changing the CT ratio now what effect will it make on MF.?"
It becomes a BMF.
Good Answers: 145
10/02/2014 10:39 AM
This might be what I was thinking of: http://cr4.globalspec.com/thread/2446/CRIMINAL.
Good Answers: 244
10/03/2014 12:03 PM
You might get the answer in my previous response at http://cr4.globalspec.com/thread/36700/M-F-in-Electricity-bill
For your convenience, I copied and pasted it here:
M.F is for Multiplying Factor
It is the factor that is used to multiply the reading of the energy meter to get the actual energy consumption. If the M.F is 10, and the energy meter reading difference (the difference is used because energy meter reading is cumulative) is 45 for a period. The actual energy used for the period is 45x10 = 450 KWH.
M.F value is written on the front dial of the energy meter. However, there may be different cases:
Case 1: The energy meter front dial doesn't have any M.F value or CT ratio and the meter is used without CT.
The M.F is 1 in this case, so the actual energy used for a period is equal to meter reading difference for the period.
Case 2: The energy meter front dial does have M.F value but no CT ratio: and the meter is used without CT.
The actual energy used for a period is equal to meter reading difference for the period multiplied by meter M.F.
Case 3: The energy meter front dial does have M.F value and CT ratio; and the meter is used with CT of same ratio.
The actual energy used for a period is equal to meter reading difference for the period multiplied by M.F.
Case 4: The energy meter front dial does have M.F value and CT ratio (example 100/5A); and the meter is used with CT of different ratio (example 200/5A).
In this case,
Actual M.F = Meter M.F x (200/100) = Meter M.F x 2.
The actual energy used for a period is equal to meter reading difference for the period multiplied by Actual M.F.
Case 5 (rare case but may happen): The energy meter front dial doesn't have any M.F value or CT ratio but the meter is used with a CT (say 20/5A).
In this case,
Actual M.F = CT ratio
So the actual energy used for a period is equal to meter reading difference for the period multiplied by CT Ratio.
There are more similar cases for PT ratio as well (but the logic is similar to CT ratio).
- MS
Anonymous Poster (2); BruceFlorida (2); Crabtree (1); Doorman (1); lyn (1); msamad (1); Phys (1); Tornado (1); truth is not a compromise (1)
