Previous in Forum: Is Their Any Motor That Has Zero Back EMF?   Next in Forum: Motor Contribution Through Delta/Star Transformer
9 comments
What Caused This Damage?
10/14/2014 12:58 PM
I'm looking for the reason why these stator windings are blackened. They don't have a burn pattern related to phase loss, rather they look like they overheated. But that's only an opinion. Any ideas? Thanks!
Re: What caused this damage?
10/14/2014 1:06 PM
Where's the rotor, what does that look like..? From here it looks like it's been overheating, but it could just be an accumulation of oil and dirt...if the rotor smoked out, it could be soot...
10/14/2014 2:45 PM
Better also check the history of the motor with maintenance and staff working with the motor to see if anything had changed recently that could have caused or lead to the failure.
Good Answers: 140
10/14/2014 2:47 PM
Looks to me like it got good and wet inside.
Good Answers: 97
10/14/2014 2:55 PM
Good an wet and bindings popped from swelling and slot burn on left hand side of the picture.
CRTL-Z
Australia - Member - New Member Hobbies - Target Shooting - New Member Popular Science - Weaponology - New Member
Re: What Caused This Damage?
10/14/2014 8:47 PM
To me it looks like it either got Water into the windings or more likely the bearings have worn and the rotor & stator are brushing against each other and you have caught it before it shorts to earth... I'm guessing that you stripped it down because it wasa making noises that it shouldnt and wisely decided to investigate.
Not be wise again and get someone who knows how to rebuild motors to rebuild it for you.
Regards,
Sapper.
It's all about the Boom! - MythBusters
Good Answers: 181
10/14/2014 11:21 PM
Looking at the photograph as a whole I would say its been taken in the local scrap yard.
Good Answers: 266
10/15/2014 7:24 AM
I see what appears to be a commutator cover in the back ground. If it is a DC motor with brushes it could be carbon stain. Especial if the motor was put into service and the varnish was still tacky.
10/15/2014 5:10 PM
I want to thank everybody for all of the input! The motor is a vertical hollow shaft unit that ran a well pump. It's 3 phase 460v.
11/03/2014 9:31 AM
Well don't do it again. Replace it.
Register to Reply 9 comments
iccdan (1); jack of all trades (1); North of 60 (1); ozzb (1); PWSlack (1); Sapper (1); SolarEagle (1); TonyS (1); Unredundant (1)
