Previous in Forum: Electrical Maintenance Help   Next in Forum: Motor Connection for Submersible Pump
14 comments
HT Cable and HVAC Ducts
11/24/2014 5:26 AM
Hello All,
I want to know whether any IS standard prohibits laying HT cable trays below HVAC ducts. Or is it convention that all HT cables should be above among, ducts, LT cables, Pipes etc.
regards'
Jithin James
Re: HT Cable and HVAC Ducts
11/24/2014 8:36 AM
below or attached to the underside?
11/25/2014 12:28 AM
It's in a cable tray underneath the HVAC duct, and it doesnt touch, but the clearance is shown very minimum, around 100 mm.
Good Answers: 122
11/24/2014 9:40 AM
It depends on the application and local codes.
11/25/2014 12:25 AM
Ask the Consultant to give a sketch.
pnaban
11/25/2014 12:32 AM
The consultant has already given a sketch, we are bit skeptical on that , hence the doubt!
11/25/2014 1:46 AM
Could you post here?.
pnaban
11/25/2014 10:19 AM
Suppose the skin of the HVAC duct is non-insulated and below dew point with the HT tray below it. Do you really want conductive water dripping on that? Do you want the tray supporting the HT to corrode? Are you serious? This is a complete no brainer.
Good Answers: 21
11/26/2014 1:51 AM
I think you have loosely used the descriptor "IS".
The question posed has nothing to do with IS as understood in Electrical Theory.
IS has to do with apparatus capable of generating sufficient energy under fault conditions to ignite a surrounding flammable/ explosive atmospere.
Perhaps there is another meaning for IS (other than Intrinsic Safety) that I am too dim to latch onto , on this otherwise fine day ?
11/26/2014 10:52 AM
Maybe meant short hand for "International Standard". Usually referred to as ISO?
Good Answers: 21
11/27/2014 1:26 AM
Aaah..there you go... I stand corrected, thank you!
The years are starting to haul me in.
Good Answers: 42
11/26/2014 2:00 PM
IEEE Std 525-1992, IEEE Guide for the Design and Installation of Cable Systems in Substations.
ch.12.3.2 Tray system design
  1. In general, vertical spacing for cable trays should be 12 in (30.5 cm), measured from the bottom of the upper tray to the top of the lower tray. A minimum clearance of 9 in (22.9 cm) should be maintained between the top of a tray and beams, piping, etc., to facilitate installation of cables in the tray.
  2. Cables installed in stacked cable trays should be arranged by descending voltage levels, with the higher voltage at the top.
That means-if "etc." =ventilation duct also-it is permissible to install a cable tray for medium voltage cables below the duct if the clearance of 9 inches is provided.
Julius
11/26/2014 9:51 PM
when buried in earth does the same rule apply?.
pnaban
Good Answers: 42
11/29/2014 4:52 AM
For underground installation: in NESC Rule 353 and 354 minimum radial separation required it is 300 mm [12 inches].However, adequate vertical separation shall be maintained to permit access to and maintenance of either facility without damage to the other cables.
Julius
11/29/2014 5:04 AM
Thank you Sir!
Register to Reply 14 comments
7anoter4 (2); Fredski (1); Hilton (2); James Stewart (2); jamesjithin (3); pnaban (3); SHOCKHISCAN (1)
