Previous in Forum: HT Cable and HVAC Ducts   Next in Forum: Imprignation
27 comments
Motor Connection for Submersible Pump
11/24/2014 6:02 AM
Submersible pump motor can be connected star or delta. Which connection is chosen and why, any idea from learned friends? Is it constructional issue?
BNDas
Re: Motor connection for Submersible pump
11/24/2014 7:44 AM
It can be operated at either of two voltage ranges. Ordinarily there is a diagram to show which way to wire it for which voltage you have.
Good Answers: 11
Re: Motor Connection for Submersible Pump
11/24/2014 9:38 AM
Read the manuals and diagram.
Good Answers: 122
11/24/2014 9:39 AM
The Star connection is for operating the motor at the higher nameplate rated voltage.
The Delta connection is for operating the motor at the lower nameplate rated voltage.
Be sure the motor leads are configured to match the application's system voltage.
Good Answers: 804
11/24/2014 12:39 PM
There is also a rather disturbing trend, especially common in India, to connect the motor for the higher voltage connection when using the lower voltage supply as a means to"save energy". For example the motor is 230/400V, you supply 230V but connect in Star as if it is 400V, or the motor is 400/690V and you connect in Star (690V connection) but supply it with 400V. This is a false economy because when this is done, it puts the motor at extreme risk of failure should the load change. When connected in Star and supplied with the lower voltage, the motor develops only 58% of it's power capability. The concept of "saving energy" stems from the lower excitation current consumption IF the load is less than 58% of rated for long periods of time. But when is that the case on something like a submersible pump? Basically never and worse yet, the starting torque is reduced to 33%, which means the pump may not get enough flow fast enough to self-lubricate, causing damage.
So back to what the others said, don't mess with it. Look at the motor nameplate and/or connection data sheet, use the connection pattern that matches your available voltage supply and be done with it.
11/25/2014 8:53 AM
Is there any constructional advantage for delta connection?
BNDas
11/25/2014 9:18 AM
Yes. You won't have to replace it very often.
Good moaning!
Good Answers: 117
11/26/2014 12:45 AM
none whatsoever. and it is NEVER done for the reasons I listed previously
Good Answers: 27
11/25/2014 9:15 AM
JRaef-
Your observations may be on the spot! But I believe those consumer's practices were triggered by a poorly designed infrastructure power distributions. Resulting to the possibility of having a poorly designed power regulation of distributed power in India?
Countries in hot climates, due to their poor economic conditions, the normal tendency for the consumers is to use the higher supply voltages instead of the typical 230 V supply lines. A common practice due to experienced voltage drops along the supply lines.
The normally distributed 230V supply lines can be observed to regularly drop down to as low as 170 Volts, specially during peak usages! A very low level that causes burnt motor windings, and beyond the normally allowable +/- 10% voltage variations acceptable designed equipment operation!
The use of marginally, smaller (AWG) wire sizes with limited # of step down distribution transformers along the distribution lines are the main causes which was done or triggered by poor economic conditions!
vsar
11/26/2014 9:21 AM
Hi Mr Vsar
Do you have any data of cost difference for using 415 V instead of 230 and a comparative statement? will be highly appreciated
" Countries in hot climates, due to their poor economic conditions, the normal tendency for the consumers is to use the higher supply voltages instead of the typical 230 V supply lines."
BNDas
Good Answers: 27
11/26/2014 9:49 AM
biswanath.das -
Not for an up to date info...
The comments made were all based from experience encountered while engaged in solving power problems. Both related to power distributions and regulation problems as well as other observed conditions existing at that time in other countries in Asia... which by is now almost 50 years ago!
vsar
11/25/2014 1:30 PM
I liked your post and explanation when running the motor at a low voltage, but set for high.
I do believe that running at the low voltage, but set for high, can cause extra heat/less cooling and possible damage to some motors as well.
Is that your opinion as well? Thanks.
11/25/2014 12:28 AM
Normally when you place an order mentioning operating voltage and frequency they will supply with tail cable,don't worry about internal connection.
pnaban
Good Answers: 117
11/25/2014 6:05 AM
ALL submersible pump motors that I've used, made by numerous manufacturers, ALL have their motors in STAR configuration.
first as the pump usually is loaded even before starting, therefore the maximum amount of starting torque is required, or you get a stall situation, which is not good for the motor
Second and in my field, that is the oil patch, all submersible pumps are required to have a downhole monitoring tool fitted to the bottom of the motor.
A downhole monitoring tool is a 5 channel measuring instrument that will send to the surface, downhole temp, motor running temp, intake and discharge pressure and vibration.
It sends the information to the surface via the motor STAR point and through the power cable to where the data signal is taken off the power cable and displayed as a set of readable values at surface.
11/25/2014 6:32 AM
Give names of reputed manufacturers of downhole monitoring tool for submersible motor in deep well for water.
pnaban
11/25/2014 9:20 AM
www.pumpperiscope.com
11/25/2014 10:23 AM
It doesn't give any information on motor/water parameters(temperature, vibration, pressure) monitoring
pnaban
11/25/2014 10:05 PM
I found it in www.slb.com/schlumberger deep well pumps,but I couldn't find description.
pnaban
Good Answers: 117
11/26/2014 12:45 AM
it that a demand or don't you EVER say please?
11/25/2014 12:00 PM
Dear.Mr.biswanath.das,
The Submersible Motor should run on DELTA MODE. The reason - the Phase Current will be less than the Line current.
No constuctional constraints.
DHAYANANDHAN.S
Good Answers: 117
11/26/2014 12:50 AM
Sir
you know not what you talk about....
I'll be blunt, and if it offends, then it offends. Your comment is total rubbish and to me it tells me you have NEVER installed submersible pumps. If you had designed, installed and managed submersible pumps, you would understand.
11/26/2014 11:50 AM
Thank you Mr.brich for your comments.
I do not intend to contradict your statement, on the other hand, may I request you to post proper information so that at least I can (though not others who are not interested to) learn.
It is better to light a candle than curse the dark.
DHAYANANDHAN.S
Good Answers: 117
11/27/2014 12:49 AM
If you take the time to read ALL the posts, you will see my previous post No6 has ALL the relevant and correct information to explain exactly why submersible pump motors have a STAR connection.
And while I mention my post No6, which MUPPET marked it as "off topic"... to that I will say I now know there are more than one person who doesn't understand submersible pump and motors.
You said and I quote "It is better to light a candle than curse the dark."
I say "open your mouth and prove you are stupid or keep it shut and let everyone think you are"
11/27/2014 10:58 AM
Dear Mr.brich
you referred,
WHY YOU GET SO OFFENDED.? According to you I HAVE FAILED. OK. Yes, I can pass in the 2nd attempt.
Henceforth I do not intend to drag/reply in this matter. God Bless you.
DHAYANANDHAN.S
Good Answers: 117
11/27/2014 1:57 PM
Simple really, have you ever seen an ESP, run an ESP in a well, operated or designed an ESP? If you answer no to any or all of my questions then you don't know what you are talking about. As for me being offended... No I'm not. What I am is slightly peeved at people spouting about a subject they know nothing about....
11/26/2014 9:15 AM
That's the easy ans most of the people know. I am talking about the constructional advantage, taking out 3 nos terminal instead of 6 and its cost advantage. Any one working with manufacturer can be in a better position to think over.
However, thanks for writing.
BNDas
Good Answers: 117
11/27/2014 6:20 AM
My Friend...
Using 6 core cable at a length of 6000ft or even more is counter-productive. You have never run a submersible pump have you? the OD of many of ESP's is about 5.5 inches, and you want to connect six cores to the motor.
Have you EVER seen a ESP?
Hobbies - CNC - New Member
11/26/2014 12:30 PM
Connect it as per the manufacturer specified voltage connections. Simple as that!
Register to Reply 27 comments
Andy Germany (1); Anonymous Poster (1); biswanath.das (3); brich (7); Crabtree (1); dhayanandhan (3); JRaef (1); Noudge79 (1); Original_Macgyver (1); pnaban (4); SHOCKHISCAN (1); Tornado (1); vsar (2)
