Previous in Forum: Parallel Operation Of Transformer   Next in Forum: LS(IS) Circuit Breakers
About Droop
11/27/2014 3:14 PM
Dear sir,
how to work droop in generator running base load,load sharing,and utility
paralleling??
Re: About Droop
11/27/2014 3:45 PM
Did you look anywhere for your answer?
Droop speed control - Wikipedia, the free encyclopedia
Re: About Droop
11/27/2014 3:50 PM
What Engineer doesn't know about droop?
Good moaning!
Re: About Droop
11/27/2014 3:52 PM
Engineer? Who?
Re: About Droop
11/27/2014 4:23 PM
Put some Viagra in the fuel tank.
Re: About Droop
11/27/2014 6:08 PM
The governor controls the speed of the engine and frequency of the generator. If the generator is used alone, you want the control of frequency to be very tight, sometimes called isochronous. If you parallel the generator with an existing generator or utility supply, you want a looser control, or droop so that the throttle can be set to share the load.
http://www.svri.nl/en/isochronous-vs-droop-control-for-generators/
ISOCHRONOUS
DROOP
Re: About Droop
11/28/2014 1:31 PM
To properly understand droop with regard to AC Power generators, you need a good instructor and a class room, not here on CR4......
You might not fully understand it here and make some serious and very costly mistakes....and it will be your fault, not ours.....
Register to Reply 6 comments
Andy Germany (1); Anonymous Poster (1); Crabtree (1); lyn (2); Rixter (1)
