Previous in Forum: Unbalance Power Factor at No Load on 3-Phase Motor   Next in Forum: Lightning Protection System Design
74 comments
Remember Me? The "Iceberg In Fukushima" Guy?
12/07/2014 11:27 PM
I have another question, it has been so long since I got on here and asked for more verbal abuse, I thought it was time to get picked on again. But, thanks in advance for any civilized responses, some of you were quite patient with this layman in the past.
The others can suck eggs.
CAN A MAGNETIC FIELD BE ROTATED OR RAMMED?
ANY ELECTRICAL ENGINEERS READING THIS WHO CAN ANSWER THIS LAYMAN'S QUESTION?
Is it possible to move a magnetic field either in a rotation or in a ram? If so, couldn't we use computers to circulate or motivate a magnetic field around a coil, rather than turning the coil, or the magnets, with mechanical devices?
If we can generate a magnetic plasma field that tugs or pushes a MAGLEV train along a track, couldn't we move that same magnetic field through a stationary coil and induce a current that is picked up by that coil.
Thus, by using a computer "distributor" system that alternately charges magnets in a circle or along a line, and thereby pulling or spinning those electrons into motion, we eliminate the need for mechanical drive, which is the reason we need coal, or steam (nuclear) or falling water, or even wind, to rotate the coil or the magnet?
By alternately charging magnets in close proximity to either attract or repel in sequence, would it move the magnetic field so it could be harvested by a stationary coil? Either in a circular rotation, with a wheel type coil in the middle of the magnetic field (rotated), or along a track, with a straight-line coil in the middle of the field (rammed).
If this is possible, wouldn't it represent a non-mechanical method of electricity production? And wouldn't that represent a way to produce an electric current that did not require some sort of fuel to generate that electron flow?
Re: Remember me? The "iceberg in Fukushima" guy?
12/07/2014 11:38 PM
No to all of that.
12/07/2014 11:45 PM
OK, then, if one placed a coil in the magnetic field that moves a maglev train, would it induce an electrical current?
12/08/2014 12:03 AM
If you move a coil in a magnetic field you induce a current.
Physics basics.
Putting the coil there will do nothing or everything. It depends if there is movement.
I think you can move the magnet or the coil same result. Your choice.
Good Answers: 11
12/08/2014 7:40 AM
seems like the cool blues dude want to have a perpetual Maglev. How would he drop off or ride on such condition? No to that.
100% support on the music.
Good Answers: 804
12/08/2014 12:29 AM
No? I disagree. Rotating magnetic fields? What he is describing is the basic theory behind an AC induction motor. I'm not sure why he thinks this is anything new, it's the basis of out modern society. But it's not that odd by any means. It was maybe when Steinmetz thought it up and then Tesla made it work.
12/08/2014 12:33 AM
The "no" occurs when proposing to get energy out without putting any in.
Good Answers: 804
12/08/2014 3:05 AM
Oh yeah, well there's that...
I failed to read the last line. That's where he falls apart.
12/08/2014 12:14 PM
"get energy out without putting any in"
I never said that, I just asked if it had to nbe mechanical, I know it takes electricity to charge the magnets, and to run the computer that switches those electrical impulses to the magnets on and of in perfect sequence.
Isn't energy is ambient, and all we are doing is tapping it, not creating it?
12/09/2014 7:42 PM
Yes you can, but the electricity required to do so is more than the electricity you get back.
Jim
Good Answers: 42
12/09/2014 12:20 AM
GA!
(You stole my thunder - grumble mutter)
Good Answers: 82
12/09/2014 4:30 AM
"Steinmetz thought it up and then Tesla made it work"
Let's keep in mind there was a whole lot of AC power, with transformers, and motors, etc., going on before Tesla came along, including at Westinghouse. What Tesla brought to the table was polyphase, along with transformer and motor-winding techniques that made polyphase work. He brought his patents for these things to the table, and sold them to Westinghouse, reportedly for $1M. Plain old single phase was OK at low power levels, but to get serious, one needed polyphase.
Thanks, Win
Good Answers: 82
12/09/2014 11:08 AM
I will have to say though, after spending a few hours going through Tesla's huge collection of patents, it appears that someone else invented the 3-phase generators and motors, etc., that we rely on. The drawing on my last post was from US487796, an 1888-1892 patent. The drawing at right is from a slightly earlier patent, US390414, applied for and granted in 1988.
As you can see in the bottom half of the page, the drawing, Figure 3 in the patent, shows a 3-phase machine. But he barely makes mention in the text, except to say,
"There is another well-known type of machine in which three or more coils, A' B' C', on the armature have a common joint, the free ends being connected to the segments of a commutator. This form of generator is illustrated in Fig. 3. In this case each terminal of the generator is connected directly or in derivation to a continuous ring, a b c, and colIecting-brushes a'b'c', bearing thereon, take off the alternating currents that operate the motor. It is preferable in this case to employ a motor or transformer with three energizing coils, A" B" C", placed symmetrically with those of the generator, and the circuits from the latter are connected to the terminals of such coils either directly - as when they are stationary - or by means of brushes e' and contact-rings e."
Note the phrases, "well-known type of machine" "three or more coils" and "placed symmetrically". It would seem this technique was already in use elsewhere. I found no sign of it in his other patents, earlier or later. I may have missed one, but he generally self-referred to his earlier patents in the text of his later patents. Given the clear efficiency importance of 3-phase, if it was his invention, surely he'd have made a bigger deal about it in this patent.
Thanks, Win
Good Answers: 44
12/10/2014 1:49 PM
Many of Tesla's ideas, and later patents, were based on his insistence to not use brushes in his motors. This is dialoged as his "ah-ha" moment of drawing in the dirt one day in Central Park (or some such story).
And Niagara Falls (Cataracts) was not the first polyphase generating station. It was just one of a handful worldwide. It was the one where many of Tesla's engineering practices were put into place in one facility...his "system" of producing and distributing alternating current.
With all of the hype out there it's difficult to see the clearing in the forest.
My child's 9th grade text book still states that Edison "invented" the light bulb. Go figure.
12/11/2014 9:58 AM
totally off topic, but wouldn't we all just love to be a fly on Tesla's wall when he was doing this work?
Good Answers: 42
In reply to #63
12/11/2014 12:53 PM
I think there is just as amazing work going on by many people, but some people are much better at patents and commercializing their products. We often confuse the commercial success with being brilliance - it just is not so.
Good Answers: 122
Re: Remember Me? The "Iceberg In Fukushima" Guy?
12/08/2014 8:59 AM
JEP;
Creation of magnetic fields require energy from either a mechanical or electrical powered source.
In all energy producing reactions:
(Power In) minus (System Dynamics Power Losses) = Power Out
Or: Energy In = Energy Out
The most efficient power generating systems we have access to is Solar and Wind Generation because the initial energy source is basically free.
In order for a computer to induce and control any sort of rotating magnetic field the computer would first have to produce or control enough external electrical power to create/induce the amount of magnetic flux in the coil(s) of wire required to satisfy the electro-mechanical load.
More load => More magnetic flux required => More consumed power
The train you are referencing to is controlled by embedded magnetic coils in the monorail under the center of the train which consume a significant amount of electric power in order to keep the train cars in suspension and to propel and/or stop it.
The train propulsion system is not 100% efficient nor is any other system we use to create or control mechanical movement of any load.
All we are allowed to do is convert energy from one form into another while suffering efficiency losses in the process.
Everything we as humans have access to, has a finite, pre-determined life expectancy governed by the laws of physics.
All this being said, we are capable of and we are making progress in improving energy conversion efficiency so we need to keep questioning our methods.
Hope this helps.
12/08/2014 10:53 AM
Thanks for everyone's input. Again, I'm no engineer or physicist, just a curious old fellow with magnetodes on the brain.
Let me offer a scenario here, to illustrate what my head sees... imagine, if you will, a few solar panels connected to a series of wire-wound steel posts, which protrude partially into an open space, those posts being staggered in such a way that they draw a magnetic current from each other whenever they are charged.
My pea brain sees a flow of electrons from one of those posts to the other, if the charge sent through them could be "managed" sequentially with a computer, wouldn't that represent "movement" without mechanical effort? If those posts protruded into a space where a coil could be stationed, then wouldn't that coil pick up that electron flow and send it down its output wire?
If that sequence could be refined, as only computers can do (think of the electronic ignition in an auto engine) so that it was extremely fast, wouldn't that create non-mechanical motion? By tugging electrons from one magnet to another, as long as it was perfectly sequential, seems to this layman that would create an electron flow that could be harvested by a stationary coil.
And while I do understand it takes energy to make energy, the solar panels (or wind turbines or batteries) that charge the magnets would not have to use up that much initial energy just to charge the magnets, if that were the case, the giant electromagnets we now use for generation would suck up all the power they could produce, which we know is not the case, as long as the magnets are charged they draw in more electrons than they consume as magnets.
So, by using a small amount of electricity to create powerful magnets, and using a computer to charge those magnets in sequence, seems to me it is something like a hadron collider, or maglev flow, that would create more energy than it uses. Tesla describes the energy that is perpetually available around us, seems to me Einstien does, too, and by "organizing" that available energy we can tap it, we already do it with rotation generators
And in the same way we could never have discovered fractal formulas without computers, we could never create that sequence of power input I imagine, without them, a mechanical distributor might work up to a point, but to get the kind of super-fast sequencing I THINK it would take to create a magentic flow worth harvesting, it would require computer switching.
Bear with me, folks, I appreciate your answers, I am just offering questions that my limited knowledge leaves hanging in my head. Seems to me, the cost of energy production, both in making it happen and in what we are doing to the planet because of it (coal and nuclear power in particular) is more than it is worth. So, if there are any options, we should use them. It also seems to me we already have some of those options available, but pernicious profiteers have suppressed those options so they can monopolize energy production.
Call me crazy (you won't be the first) but when I looked at maglev trains, the idea stuck in my head that here was a magnetic flow that might be tapped. And putting it into a circle rather than a straight line was just the next thought.
One thing I am certain of, it takes very little energy to charge magnets, relative to the amount of energy those magnets can produce, those magnets can tap a lot more of energy from the ambient availability than they consume. It is just a matter of organizing a series of those magnets to tap that available energy and placing a coil in the midst of that electron motion.
If this is not possible, where am I off here? At which point in my construct does the physics collapse?
Good Answers: 42
12/09/2014 12:42 AM
Magnets don't create energy. It takes a huge amount of energy to initially form a strong magnet.
You are confusing magnetic fields like a permanent magnet, with changing magnetic / electric fields like radio waves, and electric fields. They all get tangled up together, but they have distinct differences.
In my graduating thesis I was transmitting power from a large coil (the size of a bed) to a small coil implanted in a patient. The best we could get is a few milliwatts of power in the receiving coil, and the main coil transmitted over 1 kilowatt. This is like a radio station that broadcasts possibly thousands of watts, but for your radio to pick it up it needs powerful amplifiers to magnify the microwatts of power it received.
To use the energy in the ether requires an energy gradient. Hot flowing to cold, water flowing down hill, light to dark, positive to negative. If you tap into one of those energy flows you steal part of its energy, and you never get away from it. To use Niagara falls you diminish the water flow over the falls, If you use a sun beam, you create shade, if you burn coal the energy previously stored by plants from the sun is stolen and gone, if you use geothermal hot water energy, something now gets cold water. There is just no free energy, you always pay the piper.
12/09/2014 9:14 AM
"To use the energy in the ether..."
Hey, dude, the ether went out with Michaelson and Morley, not to mention Einstein.
12/09/2014 9:36 AM
It also went *IN* with Shakespeare, the dude was using a poetic analogy. It's pretty, completely wrong, and yet puts the right idea in the recipients head.
Good Answers: 44
12/10/2014 1:52 PM
Let's go all out and call it the æther!
Good Answers: 42
12/10/2014 9:50 PM
wikipedia gives both spellings, but I like yours better - gives essence to the Greek origins.
12/09/2014 1:20 AM
I think the answer you are looking for is inductive charging.
http://en.wikipedia.org/wiki/Inductive_charging
Have fun!
Good Answers: 27
12/09/2014 8:49 AM
I think an important component in your thought processes is missing! That component I believe is "Heat"! In order to realize your ideas functionality, You need to incorporate some "heat" in the thought processes! I believe once you incorporated some "Heat" into your ideas, the reality will set in?
Will they function properly without the element of "Heat" present?
vsar
12/09/2014 10:04 AM
but a magentic energy flow is frictionless, isn't is? I know you are making a crude attempt at ridicule, but humiliation isn't one of my qualities.
Good Answers: 27
12/09/2014 1:11 PM
And JEP, where do you think / plan for those "frictionless energy" supposed to flow / how to be of any real use in this world?
You may already have spent those energies just thinking about them!
vsar
Good Answers: 42
12/09/2014 6:32 PM
Its in the ether!
12/10/2014 10:51 PM
so, was Tesla wrong about wireless electricity?
Good Answers: 42
12/11/2014 1:05 AM
For commercial purposes, yes.
A great man is not always correct.
12/11/2014 10:26 AM
that is an unlimited supply...
Good Answers: 27
In reply to #65
12/11/2014 12:45 PM
JEP -
"that is an unlimited supply.." ----
If the above claim of yours is true, then why not you utilize it, to justify your statements! As in your last paragraph, replacing the "If", making your original post a real possibility!
"If this is possible, wouldn't it represent a non-mechanical method of electricity production? And wouldn't that represent a way to produce an electric current that did not require some sort of fuel to generate that electron flow?
vsar
12/09/2014 8:55 PM
Not knowing enough I would think that magnetic "flow" is not friction less. What we measure as magnetic flux is the friction in the MagnoWorld.
But then:
http://physics.stackexchange.com/questions/18058/magnetic-fields-and-friction
http://physics.aps.org/articles/v5/102
http://en.wikipedia.org/wiki/Magnetic_flux
I think I know what you are trying to do. There is "free" energy out there, but as soon as you start harvesting it you have too deal with the losses.
When I say "free" energy I mean sun, wind, ocean waves. Its there and we make use of it but at a price. The law of conversation of energy still stands.
I'd keep looking for the moving/changing magnetic field. As I said before you can probably move the magnet the same way you move the coil and induce a current. So the answer to your question is yes it works but since you gotto move one or the other you have to input energy into the system. This means all you are after is a new not even principle for electricity generation. Maybe a contact less one of no mechanical movement (did you read up about the MHT, isnt that what you want?) but after all nothing to change that world!
12/19/2014 10:16 AM
If magnetec energy flow is 'frictionless,' then why do transformers (which convert electrical current into magnetic flux and then back into electrical current) get warm when in use?
12/08/2014 1:26 PM
I never said anywhere that it wouldn't take some form of electrical input to charge the magnets, that is a given, but my point is, can we use a little electricity to start a lot of energy flow, without mechanical means, just switches to send current to the magnets in sequence, to "manage" the ambient energy already available... isn't electrical energy ambient, we don't "create" it, it is always available, we just organize it into an electron flow? Or am I wrong there, too?
Good Answers: 122
12/08/2014 2:10 PM
No; other than static charges that exist at uncontrolled random locations and at random voltage levels, we actually create/generate all of the electricity we use in industry and in our homes.
The voltage level in any generation system is a direct function of the magnitude of magnetic flux created and the angle at which the magnetic lines intersect the winding conductors in a generator/alternator. (The closer to 90 degrees perpendicular the flux lines get, the greater the induced voltage becomes.)
We do have ambient electrical charges in the air all around us and in all materials due to the structure of all atoms and the number of corresponding conduction band electrons in each atom.
This charge is very small in magnitude and must have a force acting upon the atoms to concentrate and magnify the conduction affect such as when we experience lightning in order for us to be able to harness it as usable power.
If we could mimic the static charges that occur when clouds are building in the atmosphere and/or when they are being moved from place to place by the wind and if we could control the reaction, it would be possible to somewhat harness the magnetic field of the earth.
Look at a cloud cell that is producing lighting and realize the required physical surface area size of a device capable of generating even a small lightning bolt.
So far any and all attempts to do this has failed catastrophically as the voltage levels reach into the millions.
We do not yet have any insulators or wiring that can withstand the voltage pressure and we have no devices capable of storing the quantity of electrons created during a lightning strike.
Also; The down side to robbing atoms of their small electrical charges is that it changes the physical structure of the material which whether in a liquid, solid, or gas state, disintegrates rapidly.
There is research being done on creating a void immediately adjacent to an object such as a spacecraft which literally "sucks" the craft in the direction of the void but to my knowledge the research is not progressing rapidly.
Maybe at some point in the future (long after my days are over) we will master this principle but I am confident the procedure will require energy to create the affect and the amount of energy required will be predicated upon the physical location of the craft/device, the size/mass of it, and the dynamics of the process involved.
Will this be possible? I believe so but the probability is small.
12/08/2014 9:39 PM
You always get less out than you put in.
To start with, you don't just steer current from one electromagnet to another. When you apply voltage to an electromagnet, the current builds up relatively slowly. It takes energy to build up the magnetic field. To move the current to another magnet, you have to do something with the energy in that field, and supply energy to start up an new magnetic field. Any energy captured in "moving" the magnetic field is that much more energy you have to add.
Sorry, no free lunch today.
12/09/2014 11:43 AM
What you use a BiFilar coil (another of Tesla's patents)?
12/10/2014 7:11 AM
You could, but the magnetic field stays in the same place. I think the original question was whether you could move a magnetic field from one place to another by switching and draw energy off in a conductor in between without supplying that energy some other way. The answer is no.
Good Answers: 11
12/09/2014 4:51 AM
I'm more interested on the piece you always play. Seem fun to have a jamming session sometimes "bob dylan" or whatsoever.
12/09/2014 10:07 AM
I don't do covers, I write my own stuff. Almost exclusively.
Good Answers: 11
12/10/2014 12:28 AM
Wow, good stuff, awesome. What software are you using for your recording?
12/11/2014 9:50 AM
Audacity is free (I really enjoyed writing that line)
But I'm a Soundforger from its inception.
Hobbies - CNC - New Member
12/08/2014 4:10 PM
I think this is what the other poster is talking about.
https://www.youtube.com/watch?v=1K3yv9iqDQo
Is this what you are trying to get across?
Good Answers: 122
12/08/2014 7:25 PM
I looked at the video and it is a simple permanent magnet motor created with a bicycle wheel and several magnets.
He also has a remote power supply that he switches on in order to keep the wheel/motor rotating. (Remove the external power and the wheel stops.)
The wheel does not have any mechanical load applied other than bearing friction and the forces of gravity.
It would be interesting to add more permanent magnets, then spin the wheel up mechanically, and guess how long it would continue operating before coming to a complete stop.
12/08/2014 11:51 PM
I feel like sucking some eggs...
You're a pea sized dill.
12/09/2014 1:20 AM
Good Answers: 21
12/09/2014 1:30 AM
Iceberg Guy,
Your persistence smacks of having experienced some sort of revelation.
Don't smoke that stuff dude, thoughts arising only seem profound to the thinker, not the audience!
Regrets, but your moment was not a Eureka one.
12/09/2014 10:06 AM
all science is science fiction until it is proven...
12/09/2014 1:52 PM
"Your persistence smacks of having experienced some sort of revelation.
Don't smoke that stuff dude,"
ya got me there... although along with my cloudy delusions, I also maintain a consolation that most of the great advances in technology came despite the ridicule of the existing "current" scientific community. I guess I always wonder here, and there are certainly exceptions, how many "scientists" just say no, instead of "who knows?"
From Galileo to Tesla, it has always been those "no" scientists who refused to accept new ideas, and always said "no" based on their limitations. I still think a magnetic flow can be created without mechanical means by sequential charging of magnets in close proximity, and that it could be tapped by a stationary coil. I have never said it wouldn't take "input" to accomplish that, but the input I describe is just enough to charge the magnets in sequence, and run the computer that does it, whetehr those magnets would produce enough current to pay back the input, I guess only a working (or non-working model) would prove or disprove.
Call me deluded, call me arrogant, I'm sure some of you will, but that only means I'm in good company, if the history if science and its progress against internal skepticism is any indicator.
I still wonder if a magnetic field could be moved, the way the hadron collider moves particles... and I still think there is a way to tap it, even if I don;t know how. I've never said there is "free energy". I just think there is much cheaper versions of it available that have been obstructed by those who would profit off the more expensive versions.
Thanks to everyone for your input, we can close this discussion, I have heard enough, you won't convince me not to think about it so any other insults are futile.
As for those scientific sophists who felt compelled to ridicule, please, go suck an egg.
Good Answers: 11
12/11/2014 4:16 AM
You rule
12/09/2014 7:17 AM
Pluck a string on your guitar....listen to the sound decay.....why doesn't it ring forever?
12/09/2014 7:26 AM
Now play the same note on a Moog Synth.....the computer will sound it 'forever'.....until you unplug it.
12/09/2014 10:10 AM
so what bout THIS without the fluid, just the charge?
http://en.wikipedia.org/wiki/Magnetohydrodynamic_generator
Good Answers: 11
12/09/2014 11:13 AM
Not possible
12/09/2014 5:12 PM
I'm surprised Lyn Industries hasn't weighed in yet with some variant of the Macro Encabulator to automagically move the magnetic fields. Actually JEB, I've enjoyed the thread you created!!
12/09/2014 6:55 PM
...don't "magic" and "magnet" share the same Latin root root word?
12/11/2014 9:55 AM
Is the macro entabulator something akin to a flux capacitor?
Good Answers: 73
12/09/2014 9:33 PM
Perhaps you are thinking about superconductors. If a wire (conductor) is a superconductor (no resistance, therefore no loss) then a loop of wire will carry a current indefinitely. Of course, we can only approximate a superconductor by chilling the right kind of conductor (perhaps copper?) using liquid nitrogen to get it close. Take a look at this http://www.flixxy.com/magnetic-levitation-model-train.htm link for superconductors in a magnetic field.
12/09/2014 10:34 PM
all that being said, it made me wonder, is "space," especially deep space, a superconductor for light?
There's a biblical verse that says something about "the light shines in the darkness and the darkness resisted it not", with various translations like "apprehended" rather than "resisted" which made me wonder if that describes space as a superconductor for light.
if an electrical flow is transmitted through space, even denser space like our atmosphere, wouldn't it constitute a much likelier superconductor than much more "massive" copper or any other wire?
If Tesla's contention that electricity can be transmitted wirelessly holds true, would it also hold true for a magnetic field if it was directed or circulated?
Good Answers: 11
12/10/2014 12:32 AM
Wow, we will get along together better I guess. This is an amazing insight.
Sure is, space is a vacuum that will accommodate all particles(matter) and em wave.
12/10/2014 9:24 PM
Stop smoking man!
12/10/2014 10:50 PM
no
Good Answers: 73
12/10/2014 10:33 PM
Superconductivity only applies to electric and magnetic fields as far as we know. The speed of light is a constant, and it tends to spread out with distance. That is called divergence, not to be confused with the recent movie.
Here is something to think about. The speed of light is constant. But if you were traveling at 99% of the speed of light in your car (in space) and you turned on your headlights, what would happen?
12/10/2014 10:47 PM
So, then, how fast is a fly flying in a car traveling 75MPH, when it flies from the back window to the front window? If it normally flies 5MPH outside the car, then while doing the usual speed in a moving car, wouldn't it be flying 80 MPH "relative" to a hitchhiker standing by the road?
Is that fly like a photon is to a light wave, relative to the car?
12/11/2014 3:31 AM
1. Yes
2. No
I admit, better keep smoking then!
Good Answers: 11
12/11/2014 3:46 AM
Wow...heavy dude.
12/11/2014 9:53 AM
the future would flash bewfore your eyes?
Good Answers: 11
12/11/2014 10:37 PM
Yes JEP!!! hit it baby!
12/11/2014 10:15 AM
Only if you install one of these in your car.
In reply to #64
12/19/2014 10:26 AM
Dude! Where did you find that? I assume it sparkles/flashes/fluxes, right?
I want one for my car.
Good Answers: 44
In reply to #73
12/23/2014 9:40 PM
http://www.thinkgeek.com/product/1dbd/
Good Answers: 18
12/17/2014 12:49 AM
Do you mean something like this?
http://www.cheniere.org/references/MEG_Patent.pdf
In reply to #69
12/18/2014 12:47 PM
this is exactly what my layman's mind is suggesting, at least Ihave the consolation of knowing some serious engineers with imagination still exist. My whole idea is non-mechanical production of energy, and here it is in patent form. I had never heard of this before, BTW, while I am no engineer or physicist, my ideas do come from my head, even if I can't prove them.
At least I can ask questions.
So, why do do many of the "experts" here claim it just can't be done when, in fact, at least on a very small scale, it is being done?
Good Answers: 27
In reply to #70
12/18/2014 1:48 PM
Jep-
If I have to agree with what you have in your mind, I will include /focusing on something like telekinetics... it supposedly is like mind-over-matter energy utilization!
Practicing the art of Tai Chi comes to mind as another way I heard or think of that "can harness /produce /utilize" some form of energy that supposedly developed within! An inherent "inner energy" they claim?
What do you think?
vsar
Register to Reply 74 comments
adreasler (3); Anonymous Poster (1); cuba_pete (3); geraldpaxton (2); GW (6); Hilton (1); IdeaSmith (6); James Stewart (1); JEP (20); JIMRAT (1); JRaef (2); melanie135711 (1); NotUrOrdinaryJoe (2); Noudge79 (8); Original_Macgyver (2); Rixter (2); SHOCKHISCAN (3); StandardsGuy (1); SWB123 (1); Tornado (2); vsar (4); Winfield Hill (2)
