Previous in Forum: Low Pressure Heat Of Compression Air Dryer.   Next in Forum: Low Condenser Vacuum In 110MW Coal Based Thermal Power Plant
39 comments
Selection Of Pump
12/08/2014 2:08 AM
I want to pump 2500000 Kg/hr water from an open tank which is under atmospheric pressure. Temperature of water inside tank is around 34.9 Degree Celsius. Differential head reqd. is 35 meter. Mech. efficiency of pump to be 70% and motor efficiency to be 90%. Density of water @ 34.9 degree is not avilable. I want to select pump before procurement. How to find pump shaft power and motor power.
Re: Selection of pump
12/08/2014 2:26 AM
Sounds like homework.
Procurement would not even bother looking at temperatures!
You might want to find the power that is needed to get the water where you need it and apply your efficiencies and voila there will be the power.
With a bit of effort you can do this!
Watch out, its a trick question. The density of water at the given temperature is the most important missing parameter!
Have fun!
12/08/2014 3:01 AM
"Temperature of water inside tank is around 34.9 Degree" - get real! How accurate do you think the efficiency figures are? ±5%? Maybe, if you're very lucky.
Good Answers: 11
12/08/2014 7:20 AM
Read something about total dynamic head.
You may approximately use 1000kg/m3 density. if you want the exact find a steam tables on the net, find vf @ 34.9C Pressure at 14.7psi density is just the inverse of vf.
eff. =WHP/BHP
Good Answers: 92
12/08/2014 7:55 AM
Speak to your chosen pump supplier(s) and ask them. Be prepared to also provide information on inlet and outlet pipe sizing, layout and tank connection as well as any other flow restrictions. Please note that 34.9 C is close enough to 35 C for any practical engineering calculations that you should be able to find or calculate the density from steam tables (they often have this sort of information for feedwater). Lastly, unless this is homework pumping on the order of 700 litres of water per second seems to be a fairly important undertaking, enough to warrant more than the opinion of posters on an anonymous forum.
Good Answers: 11
12/09/2014 8:01 AM
issues on anti-trust is critical
Re: Selection Of Pump
12/08/2014 8:39 AM
Homework alert!
Your first assignment is to convert 2500000 Kg/hr into volume.
12/12/2014 5:54 AM
Thanks lyn, you are correct.I have changed mass flow rate to volumetric flow.Then I used rho*g*h formula to find pressure in bar.I will update, if I complete this issue properly.
12/12/2014 6:05 AM
One more step forward
Pump shaft power req. = Theoritical power req. devided by pump efficiency
12/12/2014 6:12 AM
Oh I am tired after this complex calculation. Somebody calling me from weld shop.Shop fellows might have executed seam overhead weld again on 30mm thick ASS pipe.Give me a break.
12/08/2014 8:51 AM
Because I don't believe you have confidence in yourself to read a pump curve and since you have to buy your pump, contact a pump supplier to ensure correct sizing.
Good Answers: 11
12/08/2014 8:51 AM
It could be either you or your instructor's fault.
Blame him for not teaching you the very best way that you would learn and/or yourself for not listening or not learning the basics ever since.
Change your mind, you could either be on track or off track on whatever you pursue.
The easiest way might not be beneficial for your future.
Reply Score 1 for Off Topic
12/08/2014 8:25 PM
Can I borrow your brain for few days as I am seriously looking for a Nobel prize.
Reply Off Topic (Score 6)
12/08/2014 8:28 PM
Contact the Wizard for a brain.
12/08/2014 9:06 PM
Thanks for the trillion dollar advice current nobel laureate.
Reply Off Topic (Score 7)
Good Answers: 11
12/09/2014 8:05 AM
Wow, i am not sure i have one its dilated suspended in space of nothingness.
12/08/2014 9:11 AM
Thanks all for the replies. There are some serious errors found in the given values in my OQ. If time permits, I will let you know the correct values.
12/08/2014 9:23 AM
Don't bust a gut.
12/08/2014 12:26 PM
Contact a pump supplier, directly.
Coming here just wastes our time and yours.
Your pump supplier (if they are any good) will insist on having the needed information and doing the calculations themselves.
That way, you'll get the pump you need, not the one you THINK you need.
If this is homework, we don't do homework here!
Anonymous Poster #2
12/08/2014 12:50 PM
12/08/2014 9:11 PM
CR4 ADMIN: Deleted Post
Vulgar/Rude/Improper Behavior: This post was deleted because it did not adhere to the behavioral policies of the site. Please review Section 14 of the CR4 Site FAQ and the CR4 Rules of Conduct.
Reply Score 2 for Off Topic
12/09/2014 9:13 AM
Anonymous#2 might have produced physically fit certificate to CR4 moderator!
Other possibilities,which need more analysis
1. He/She is an illiterate to understand the OQ.
2. He/she entered in this forum to purchase toys and vegetables.
3. He/she was under drug or liquor.
4. Activity of an illiterate kid
5. Coded message from a potential terrorisht?
Anonymous Poster #2
12/09/2014 9:21 AM
When you don't know enough to make an informed choice, this venerable selection technique is just as good as another.
[Sheesh lighten up a little. It will do you some good.]
12/09/2014 9:32 AM
It is none of your business to comment on what I have to do by showing a nonsense link. You are permitted to comment based on my OQ. If it is suitable I will select it after my analysis.If it is not suitable I will throw it in the trash bin.If you have nothing relevant to share, better sit back and watch the game.
Anonymous Poster #2
12/09/2014 11:58 AM
Excuse me. You have no authority here. Your poor etiquette here has already caused administration to act. If you insist on not even a polite joke in your presence then you have to pay people.
12/09/2014 12:39 PM
Oh really, I was not aware that this forum is only for jokes and jokers.Thanks for the enlightenment.administration? who are they?
12/09/2014 2:17 PM
You provide an object lesson for potential posters.
1. Don't post stupid questions.
2. Don't insult the people you ask for help.
3. Rudeness never wins friends, but may influence your enemies.
4. Never argue with a fool. On lookers may not be able to tell the difference.
12/10/2014 7:06 AM
Good Suggestions.
12/10/2014 9:50 AM
yES sIR
Anonymous Poster #3
12/11/2014 4:25 AM
girl alert probably...i love girls..who else does here?
12/11/2014 4:55 AM
Anonymous Poster #3
12/11/2014 5:23 AM
Nah, just kidding around. It's a humor seeing Anon#1 and 2 argue.
12/11/2014 6:07 AM
Oh, I thought that you are searching for girls in this forum.Everyday plenty of people are coming here for various requirements.So, it is very difficult to asses their actual requirement without proper communication.Actually,I was trying to help you.
Anonymous Poster #3
12/11/2014 9:45 AM
nice one, makes me smile though, with a thought "would i give it a try?lol
12/09/2014 12:09 PM
I suggest a dart board.
With child proof darts of course.
12/09/2014 12:38 PM
If your having a tantrum they should bounce off of the dart board instead of sticking. This would be good choice for random selections.
12/08/2014 2:08 PM
The shaft power is the flow rate multiplied by the rise in pressure divided by the pump efficiency.
The motor power is the shaft power divided by the motor efficiency.
The only tools you need are your pocket calculator and a telephone to talk to potential vendors.
Good moaning!
12/10/2014 12:59 PM
Assuming I did my algebra properly, you hope to move more water than the combined average water flow of the Dettifoss and the Jockfallet waterfalls with one pump and to pump this up by 35 meters. I want to know how big is this mythical open tank?
12/10/2014 1:08 PM
Well, are you familiar with Lake Superior?
03/28/2020 4:06 AM
Dear Friend, The calculation is as follows and your
GIVEN DATA:
FLOW : 25,00,000 Kgs./Hr. = 694.44 Kgs,/Sec. Head : 35 Metres Efficiency : Pump -70% Motor - 90% Water Temp.: 34.9 Deg.C Hence from Tables Density = 994.0357 Kgs/M^3 (Or) 0.994039
CALCULATIONS:
Assumed Data – Suction Velocity – 1.0 M/sec. Delivery Velocity – 2.0 M/Sec.
Power Required is (W X H) / 75 x (Pump Eff.) x (Motor Eff.) Since 75 Kg. M is one H.P. absolute shaft power.
Hence
(694.444) x (35)/ (75) (0,7) x (0.9) = 661,37 H.P = 496.028 KW
Rounded to 500 KWe
3. PIPE Size
a) Suction Pipe
Flow in (M^3/Sec) =
(Weight in Kg./Sec.)/1000)) /(Density) = Area x Velocity
(694.44 Kg.Sec)/(0.994) = {0.698635} M ^3/Sec. = Area x 1,0 M/sec
Therefore Area = 0.6986 sq. m = (( 22/7)/4) x D^2
Therefore Suction Pipe Dia., = 0.6369 Metre = 636.9 MM Rounded to 650 MM
b) Delivery Pipe: Velocity = 2.0 Metres.
Dia. Of Delivery pipe calculated similarly as 478.8 MM rounded to 480 MM
DHAYANANDHAN.S
DHAYANANDHAN.S
Reply to Forum Thread 39 comments
Anonymous Poster (19); Crabtree (1); dhayanandhan.s (1); IdeaSmith (1); JNB (1); JohnDG (2); lyn (5); Noudge79 (4); phoenix911 (2); redfred (2); SYED MD. ANWAR UL ISLAM (1)
