Previous in Forum: Annoying Header   Next in Forum: CR4 Communications
20 comments
Why Can't I Post Pictures?
12/16/2014 3:20 AM
Last week I could post pictures but lately I can't. I suspect they are there but I just can't see them.
Just today I was unable to see a circuit diagram posted by S.E.
Any ideas?
Win8.1, Google Chrome, red undies and dark blue socks.
Jim
Good Answers: 61
Re: why can't i post pictures?
12/16/2014 6:40 AM
Ah, but are they Winsocks?
This has been reported at least twice before and I went through the same process myself. In my case not using IE7 but Google Chrome instead, was the solution. But you are using Chrome - so now I'm totally confused. Dare I suggest trying Firefox?
Re: Why Can't I Post Pictures?
12/16/2014 11:03 AM
I think I'm getting the picture, but just to be sure, could you post
12/16/2014 7:55 PM
NO!!!!
Good Answers: 59
12/16/2014 12:14 PM
I'm aware of some users having trouble posting pictures, but not problems seeing posted images.
I'll add this to the list of things I'd like to have fixed in 2015!
12/16/2014 8:12 PM
I have tried to post pics by using the green camera and browse. I have tried by copy and paste using my browsers "normal" menu, to no avail. Another new thing is that when I push the 'enter' key it comes up with an I.E. splash screen asking "Do you want to allow this webpage to access your clipboard?" I answer 'yes'.
But strangely I get a message at other times that I.E. has stopped working. I just click "end program" as I don't use I.E. Maybe I should seek to repair I.E. and see what happens then.
My pics are taken with Sony devices and downloaded to my pc and laptop via Sony Media Go.
I will try to put a pic here now..
Though the green camera;
Now via copy and paste;
As you can see not a sausage.
For a long time now I have NOT been able to just select the emoticons here. I could right click and bypass custom menu and use my browsers normal menu to copy and paste the cr4 emoticon, like this;
well wad'ya know, it worked. Lets see if it stays once posted.
Jim
Good Answers: 203
12/17/2014 12:03 AM
I can cut and paste, Window 7 IE 11, If I copy it from another site such as the pipe wrenches below from Ridgid site. But I can not do the same if it is a jpg bmp or other format for pictures. I also can not copy and paste from Word which I used to be able to for pictures.
As for your posting all my problems are identical to yours. Please hurry and find a solution. I was trying to post a picture but gave up after several hours with no success. PLEASE!
Thanks for your posting and putting the problem into words.
Good Luck, Old Salt
Good Answers: 94
12/17/2014 4:14 AM
I had that problem with IE at home, I was using Firefox & the fix was to re-tell Windows that Firefox was my default browser. It already showed Firefox as default but I had to change that to IE then change again to Firefox.
Have you tried changing your socks?, could be some sort of conflict with the pants.
12/17/2014 6:04 PM
There definitely IS conflict with the pants. My wife wears them.
Good Answers: 94
12/18/2014 4:02 AM
Does that mean you're allowed to wear hers?
12/18/2014 4:14 AM
I can't even get hers off. And no, I don't mean off me. Did I read your mind?
12/18/2014 10:38 AM
I blame North Korean hackers!
Good Answers: 25
12/17/2014 5:56 AM
I could, posted twice. First time there was small square I let it be there and clicked again on browser and got it.
12/17/2014 9:14 AM
How to post pictures? I don't see a button that says images,,like on Craigslist.
I am using a tablet with Android. There is a message below screen that says, Formatting Tags: Images: Is this an algebra equation? Group the variables and terms ? Remove the brackets and simplify?
Good Answers: 59
12/17/2014 10:10 AM
The CR4 text editor has a toolbar that displays in Chrome, Firefox, and Internet Explorer:
The green camera icon in the image above is what you click on to post pictures.
The toolbar not visible in some mobile devices, or on Safari or other browsers.
12/17/2014 6:33 PM
Just did this from Firefox using the green camera.
But i can't copy and paste. I get the usual bypass "custom" menu splash screen but i don't the "next right click will bring up your browsers normal menu" splash screen" But as you see that process works for emoticons. They also work the way they are supposed to; left click on tab then left click on image. Easy. When the browsers normal menu appears the paste function is enabled for emoticons but not for pictures. The Undo, Cut, Copy, Paste, & Delete functions are all disabled. I will now make Firefox default browser and go to your site from the email as per normal and see what happens.
Jim
12/17/2014 6:59 PM
Post a picture?
Copy and paste;
Green camera;
O.K. so it is only when going from email to the CR4 site that I have a problem.
Jim No emoticon by L click, L click
Copy Paste
12/17/2014 7:09 PM
I am here via copy link and Chrome.
green camera;
Copy and paste;
No go. emoticons work normally.
Jim
12/17/2014 7:29 PM
drag and drop;
Resize worked.
Green camera;
No resize required.
My workaround is to copy the link in your email and paste into Firefox. I couldn't make Firefox my default browser for email so this the best i can do.
Jim
Good Answers: 59
12/18/2014 7:29 AM
Unfortunately, CR4 doesn't behave the same in all browsers. This is what I've observed:
Internet Explorer - most things should work, can resize and realign images after inserting them
Firefox - most things should work, can resize and realign images after inserting them
Chrome - most things work, can't change an image after inserting it
I'm not sure why you can't disable the right click menu, but you can use keyboard shortcuts to copy, paste, etc:
  • CTRL+Z = undo
  • CTRL+Y = redo
  • CTRL+C = copy
  • CTRL+X = cut
  • CTRL+V = paste
12/19/2014 11:43 AM
It would be most helpful if CR4 had a convenient way to resize displayed discussions. Mine does wild things depending on who did what to the discussion. Now my text is so small that I am getting eye strain from attempting to read it.
Register to Reply 20 comments
energyconversion (1); James Stewart (1); jhowdy (1); JIMRAT (8); Nigh (2); old salt (1); SavvyExacta (3); SolarEagle (1); suresh sharma (1); tonyhemet (1)
